MIKROE-4353
MIKROE-4353
    MIKRO
    LTC2990 电流,温度,电压监视器 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4353 数据手册
VCT Monitor Click PID: MIKROE-4353 VCT Monitor Click is a compact add-on board that contains a highly integrated monitoring solution without compromising accuracy. This board features the LTC2990, an I2C configurable high-performance temperature, voltage, and current monitor from Analog Devices. The LTC2990 incorporates a 14-bit ADC and a 10ppm/°C voltage reference to provide sub-millivolt voltage resolution, as well as +1°C accuracy internally and +0.5°C accuracy remotely when making temperature measurements. This Click board™ is suitable for applications like supply voltage monitoring and remote diode temperature measurement, e.g., in industrial systems where thermal management is crucial for maximizing performance. VCT Monitor Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Current sensor,Measurements Applications Can be used for applications like supply voltage monitoring and remote diode temperature measurement, e.g., in industrial systems where thermal management is crucial for maximizing performance. On-board modules VCT Monitor Click is based on the LTC2990, a high-performance temperature, voltage, and current monitor with the I2C serial interface from Analog Devices. Key Features Low power consumption, high precission Interface I2C ClickID No Compatibility mikroBUS™ Click board size M (42.9 x 25.4 mm) Input Voltage 3.3V or 5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads VCT Monitor click 2D and 3D files VCT Monitor click example on Libstock VCT Monitor click schematic LTC2990 datasheet Powered by TCPDF (www.tcpdf.org)
MIKROE-4353 价格&库存
很抱歉,暂时无法提供与“MIKROE-4353”相匹配的价格&库存,您可以联系我们找货
