ADC 10 Click
PID: MIKROE-4488
ADC 10 Click is a compact add-on board that contains a high-performance data converter. This
board features the ADS122U04, a 24-bit precision ΔΣ analog-to-digital converter with UART
compatible interface from Texas Instruments. It features two differential or four single-ended
inputs through a flexible input multiplexer, a programmable gain amplifier up to 128, two
programmable excitation current sources, a voltage reference, an oscillator, and a temperature
sensor. The ADS122U04 offers conversions at data rates up to 2000 samples-per-second with
single-cycle settling. This Click board™ is suitable for measuring small sensor signals, such as
resistance temperature detectors (RTDs), thermocouples, thermistors, and resistive bridge
sensors.
ADC 10 Click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
ADC
Applications
Can be used for measuring small sensor
signals, such as resistance temperature
and resistive bridge sensors.
On-board modules
ADS122U04 - 24-bit precision ΔΣ analog-todigital converter with UART compatible
interface from Texas Instruments MCP1501 high-precision voltage reference from
Microchip LT6656 - high-precision voltage
reference from Analog Devices
Key Features
Low power consumption, programmable gain
and data rates, two differential or four singleended inputs, internal and external voltage
references, internal temperature sensor, and
more
Interface
UART
ClickID
No
Compatibility
mikroBUS™
Click board size
M (42.9 x 25.4 mm)
Input Voltage
3.3V or 5V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click boards™
Downloads
ADC 10 click 2D and 3D files
ADC 10 click schematic
ADS122U04 datasheet
ADC 10 click example on Libstock
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-4488”相匹配的价格&库存,您可以联系我们找货
