3D Hall 8 Click
PID: MIKROE-4498
3D Hall 8 Click is a compact add-on board containing an ultra-small 3D-magnetic sensor for
industrial and consumer applications. This board features the TLI493D-W2BW, a low-power 3D
Hall sensor from Infineon. This magnetic sensor combines high-accuracy magnetic field
measurements with exceptionally low power consumption (minimum 7nA). It features an I2C
interface, enabling it to be easily configured by MCU whit the measurement data provided in
digital format. It also provides the functionality to Wake-Up a sleeping system. This Click
board™ is suitable for a wide range of magnetic sensing, including robotics position sensing,
angle measurement at the end of the shaft and out of shaft configurations, and many more.
3D Hall 8 Click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
Magnetic
Applications
Can be used for a wide range of magnetic
more.
On-board modules
TLI493D-W2BW - low-power 3D Hall sensor
with an I2C interface and Wake-Up feature
from Infineon
Key Features
Low power 3D Hall sensor, Wake-Up function,
power down mode with 7nA (typ.) power
consumption, 12-bit resolution for each
measurement direction plus 10-bit
temperature sensor, and more.
Interface
I2C
ClickID
No
Compatibility
mikroBUS™
Click board size
S (28.6 x 25.4 mm)
Input Voltage
3.3V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click boards™
Downloads
TLI493D-W2BW datasheet
3D Hall 8 click 2D and 3D files
3D Hall 8 click schematic
3D Hall 8 click example on Libstock
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-4498”相匹配的价格&库存,您可以联系我们找货
