MIKROE-4596
MIKROE-4596
    MIKRO
    AD5206 数字电位器 数据采集 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4596 数据手册
DIGI POT 8 Click PID: MIKROE-4596 DIGI POT 8 Click is a compact add-on board used as a digitally controlled potentiometer. This board features the AD5206, 6-channel 256-position digitally controlled variable resistor device from Analog Devices. Each channel of the AD5206 contains a fixed resistor with a wiper contact that taps the fixed resistor value of 100kΩ at a point determined by a digital code loaded into the SPI-compatible serial-input register. This Click board™ can be used as mechanical potentiometer replacements, voltage-to-current conversions, gain and offset adjustment, and many other applications. DIGI POT 8 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Digital potentiometer Applications Can be used as mechanical potentiometer replacements, voltage-to-current conversions, gain and offset adjustment, and many other applications On-board modules AD5206 - 6-channel 256-position digitally controlled device that performs the same electronic adjustment function as a potentiometer or variable resistor from Analog Devices Key Features 256 positions, 6 independently programmable channels, potentiometer replacement, terminal resistance of 100kΩ, SPI compatible, and more Interface Analog ClickID No Compatibility mikroBUS™ Click board size L (57.15 x 25.4 mm) Input Voltage 3.3V Resources mikroBUS™ mikroSDK Click board™ Catalog Click Boards™ Downloads DIGI POT 8 click 2D and 3D files DIGI POT 8 click schematic DIGI POT 8 click example on Libstock AD5206 datasheet Powered by TCPDF (www.tcpdf.org)
MIKROE-4596 价格&库存
很抱歉,暂时无法提供与“MIKROE-4596”相匹配的价格&库存,您可以联系我们找货
