Power MUX 2 Click
PID: MIKROE-4575
Power MUX 2 Click is a compact add-on board that contains a highly configurable power
mux. This board features the TPS2120, a dual-input single-output power multiplexer with an
automatic switchover feature from Texas Instruments. This Click board™ prioritizes the main
supply when present and quickly switches to auxiliary supply when the main supply drops.
During switchover, the voltage drop is controlled to block reverse current before it happens
and provide uninterrupted power to the load with minimal hold-up capacitance. This Click
board™ is suitable for applications as a backup and standby power, input source selection, and
various systems having multiple power sources.
Power MUX 2 Click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
Power Switch
Applications
Can be used for applications as a backup and
sources.
On-board modules
TPS2120 - highly configurable power mux with
an automatic switchover feature from Texas
Instruments TPL0501 - 256-taps digital
potentiometer from Texas Instruments
Key Features
Low power consumption, automatic
switchover, output current limit, uninterrupted
power solution, and more.
Interface
SPI
ClickID
No
Compatibility
mikroBUS™
Click board size
M (42.9 x 25.4 mm)
Input Voltage
3.3V or 5V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click Boards™
Downloads
TPL0501 datasheet
TPS2120 datasheet
Power MUX 2 click 2D and 3D files
Power MUX 2 click schematic
Power MUX 2 click example on Libstock
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-4575”相匹配的价格&库存,您可以联系我们找货
