MUX 4 Click
PID: MIKROE-4754
MUX 4 Click is a compact add-on board that contains a precise analog multiplexing IC. This
board features the 74HC4851, 8-channel analog multiplexer/demultiplexer with injectioncurrent effect control from Nexperia USA Inc. This Click board™ comes with three digital select
inputs, active-LOW enable input, eight independent inputs/outputs, and a common
input/output. It also features an injection-current effect control, which has excellent value in
automotive applications where voltages above the supply voltage are common. This Click
board™ is suitable for a wide range of analog or digital mux/demux applications, from
industrial and instrumentation, consumer, communications, and automotive systems.
MUX 4 Click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
DAC
Applications
Can be used for a wide range of analog or
On-board modules
74HC4851 - precise 8-channel analog
multiplexer/demultiplexer from Nexperia USA
Inc
Key Features
Low power consumption, injection-current
effect control, high speed, pin-controllable,
eight channels, common I/O channel signal
selection, and more
Interface
Analog,GPIO
ClickID
No
Compatibility
mikroBUS™
Click board size
M (42.9 x 25.4 mm)
Input Voltage
3.3V or 5V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click boards™
Downloads
74HC4851 datasheet
MUX 4 click 2D and 3D files
MUX 4 click schematic
MUX 4 click example on Libstock
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-4754”相匹配的价格&库存,您可以联系我们找货
