Expand 9 Click
PID: MIKROE-4853
Expand 9 Click is a compact add-on board that contains a multi-port I/O expander. This board
features the SX1509QB, the world’s lowest voltage level shifting GPIO expander from Semtech
Corporation. The SX1509QB comes in a 16-channel configuration and allows easy serial
expansion of I/O through a standard I2C serial interface. It also has a built-in level shifting
feature making it highly flexible in power supply systems where communication between
incompatible I/O voltages is required, an integrated LED driver for enhanced lighting, and a
keypad scanning engine to implement keypad applications up to 8x8 matrix. This Click board™
provides a simple solution when additional I/Os are needed, suitable for low-power portable
equipment, keypad scanning, driving LEDs, and many more.
Expand 9 Click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
Port expander
Applications
Can be used for low-power portable
and many more
On-board modules
SX1509QB - 16-channel lowest voltage level
Corporation
Key Features
Low power consumption, integrated LED driver
for enhanced lighting, on-chip keypad
scanning engine, interrupt and reset feature,
selectable I2C slave address, and more
Interface
I2C
ClickID
No
Compatibility
mikroBUS™
Click board size
L (57.15 x 25.4 mm)
Input Voltage
3.3V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click boards™
Downloads
AP2112 datasheet
SX1509QB datasheet
Expand 9 click 2D and 3D files
Expand 9 Click schematic
Expand 9 click example on Libstock
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-4853”相匹配的价格&库存,您可以联系我们找货
