RF Meter 3 Click
PID: MIKROE-4906
RF Meter 3 Click is a compact add-on board that collects information, analyzes RF power, and
displays information in an easy-to-read digital format. This board features the LT5581, a lowpower monolithic precision RMS power detector from Analog Devices. The RMS detector uses a
proprietary technique to accurately measure the RF power in a range from 2GHz up to 2.6GHz,
well-suited for signals with high crest factors. It outputs a DC voltage in linear scale
proportional to an RF input signal power in dBm. This Click board™ is suitable for precision
power measurement and control for various RF standards, including GSM/EDGE, CDMA,
CDMA2000, W-CDMA, TD-SCDMA, UMTS, LTE, and WiMAX.
RF Meter 3 Click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
RF meter
Applications
Can be used for precision power measurement
On-board modules
LT5581 - RMS power detector with a 40dB
dynamic range from Analog Devices
Key Features
Accurate power measurement of high crest
factor waveforms, 40dB log linear dynamic
range, exceptional accuracy over temperature,
low power consumption, log-linear DC output
vs input RF power in dBm, and more
Interface
Analog
ClickID
No
Compatibility
mikroBUS™
Click board size
S (28.6 x 25.4 mm)
Input Voltage
3.3V or 5V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click Boards™
Downloads
RF Meter 3 click 2D and 3D files
RF Meter 3 click schematic
RF Meter 3 click example on Libstock
LT5581 datasheet
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-4906”相匹配的价格&库存,您可以联系我们找货
