Thermo 23 Click
PID: MIKROE-4979
Thermo 23 Click is a compact add-on board that provides an accurate temperature
measurement. This board features the TMP144, a high-precision digital temperature sensor
from Texas Instruments. The temperature sensor in the TMP144 is the chip itself, that houses
temperature sensor circuitry, 12-bit analog-to-digital converter (ADC), a control logic, and a
serial interface block in one package. Characterized by its high accuracy (up to ±0.5°C typical)
and high resolution of 0.0625°C, this temperature sensor provides temperature data to the
host controller with a configurable interface which can be seen as both UART or SMAART Wire™
interface. This Click board™ is appropriate for thermal management of various consumer,
industrial, and environmental applications with many temperature measurement zones that
need to be monitored.
Thermo 23 Click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
Temperature & humidity
Applications
Can be used for thermal management of
various consumer, industrial, and
temperature measurement zones that need to
be monitored
On-board modules
TMP144 - high-precision digital temperature
sensor from Texas Instruments
Key Features
Low power consumption, high precision, UART
interface, temperature sensor in the TMP144 is
the chip itself, resolution of 0.0625°C,
shutdown and one-shot mode, high accuracy,
and more
Interface
UART
ClickID
No
Compatibility
mikroBUS™
Click board size
S (28.6 x 25.4 mm)
Input Voltage
3.3V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click Boards™
Downloads
Thermo 23 click example on Libstock
Thermo 23 click 2D and 3D files
TMP144 datasheet
Thermo 23 click schematic
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-4979”相匹配的价格&库存,您可以联系我们找货
