Angle 6 Click
PID: MIKROE-5282
Angle 6 Click is a compact add-on board that detects the absolute angular position of a
permanent magnet, typically a diametrically magnetized cylinder on a rotating shaft. This
board features the MAQ470GQE, a 12-bit contactless angle sensor with PWM output from
Monolithic Power Systems. It supports a wide range of magnetic field strengths and spatial
configurations, with both end-of-shaft and off-axis (side-shaft mounting), supported
configurations. Fast data acquisition and processing provides accurate angle measurement at
speeds from 0 to 60,000 rpm, alongside magnetic field strength detection with programmable
thresholds. This Click board™ offers a highly reliable and contactless method to measure
various applications' angles, position, and speed.
Angle 6 Click supports the mikroSDK compliant library, which includes functions that simplify
software development. This Click board™ comes as a thoroughly tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
Magnetic
Applications
Can be used as a highly reliable and
contactless method to measure various
On-board modules
MAQ470GQE - 12-bit contactless angle sensor
with PWM output from Monolithic Power
Systems
Key Features
Fast data acquisition, SPI serial interface,
magnetic field strength detection, contactless
sensing for long life, supported both end-ofshaft and off-axis, and many more
Interface
PWM,SPI
ClickID
No
Compatibility
mikroBUS™
Click board size
S (28.6 x 25.4 mm)
Supply Voltage
3.3V
Resources
mikroBUS™
mikroSDK
Click boards™
Downloads
Angle 6 click 2D and 3D files
Angle 6 click schematic
MAQ470GQE datasheet
Angle 6 click example on Libstock
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-5282”相匹配的价格&库存,您可以联系我们找货
