Flash 10 Click
PID: MIKROE-5289
Flash 10 Click is a compact add-on board representing a highly reliable memory solution. This
board features the AT25FF321A, an SPI configurable 32Mbit (2Mx16) serial Flash memory
solution from Dialog Semiconductor. The AT25FF321A is an ideal solution for systems in which
program code is shadowed from Flash memory into embedded or external RAM (code shadow)
for execution and where small amounts of data are stored and updated locally in the Flash
memory. It has a flexible and optimized erase architecture for code and data storage
applications, non-volatile protection, and four specialized 128-byte OTP security registers to
store a unique device ID and locked key storage. This memory can withstand many write cycles
(minimum 100k) and has a data retention period greater than 20 years. This Click board™ is
suitable for storage and data transfer in consumer devices, enterprise systems, and industrial
applications.
Flash 10 Click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
FLASH
Applications
Can be used for storage and data transfer in
industrial applications
On-board modules
AT25FF321A - serial Flash memory solution
Key Features
32Mbit (16x2Mbit physical block) flash
memory, optimized erase architecture for code
and data storage applications, flexible nonvolatile block protection, high performance,
write protection, data endurance and
retention, low power consumption, and more
Interface
QSPI,SPI
ClickID
No
Compatibility
mikroBUS™
Click board size
S (28.6 x 25.4 mm)
Input Voltage
3.3V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click Boards™
Downloads
AT25FF321A datasheet
Flash 10 click 2D and 3D files
Flash 10 click schematic
Flash 10 click example on Libstock
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-5289”相匹配的价格&库存,您可以联系我们找货
