A22020-001
A22020-001
    OMNETICS
    缆线组件 1.50'(457.20mm)
A22020-001 数据手册
PART NO. MATERIALS & SPECIFICATIONS INSULATOR: LIQUID CRYSTAL POLYMER (LCP) PER ASTM D5138. SOCKET # A22020-001 REV ECO DATE APP C 96877 07-13-10 TLM COLOR CONTACT: COPPER ALLOY PER MIL-DTL-83513. GOLD PLATE PER ASTM B488, (HARD GOLD) TYPE II CODE C, CLASS 1.27 1 BLACK 2 BROWN 3 RED TERMINATION: 26 AWG (7-34) TYPE E PER NEMA HP3, COLOR CODED PER TABLE. 4 ORANGE 5 YELLOW ACTUAL SIZE EXCLUDING WIRE LENGTH LATCH BOX: BERYLLIUM COPPER PER ASTM B194 NICKEL PLATE PER AMS-C-26074. CURRENT CAPACITY: 3 AMP MAX. CONTACT RESISTANCE: 26 MILLIOHMS (65mV) MAX @ 2.5 AMPS. PERFORMANCE: PRODUCT FAMILY TESTED TO AND PASSED THE PERFORMANCE SPECIFICATIONS OF TABLE VII OF MIL-DTL-83513. .025 0.64 (TYP) .050 1.27 (TYP) +.38 -.00 +9.7 457.2 0 18.00 .355 9.02 .006 0.15 .153 3.89 1 3 .043 1.10 5 26 AWG (7-34) PTFE, COLOR CODED LOADING VIEW LESS EPOXY A 4 .220 5.59 SECTION A-A REF: OMNETICS THIRD ANGLE MCS INTERNAL USE ONLY USE MFG LOADING PROCEDURE MC-5S A -TOLERANCESUNLESS OTHERWISE NOTED DIMENSIONS IN INCHES SLDW 2 PL DEC 3 PL DEC 4 PL DEC ANGLES .01 .005 .0005 1 THIS DRAWING CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION WHICH IS THE PROPERTY OF OMNETICS CONNECTOR CORP. THIS DOCUMENT MAY NOT, IN WHOLE OR IN PART, BE DUPLICATED, OR DISCLOSED FOR ANY PURPOSE, WITHOUT WRITTEN PERMISSION FROM OMNETICS CONNECTOR CORP. DFTM. TEP 05-15-07 TITLE: (5) SOCKET FEMALE DATE CHK'D. MICRO CIRCULAR DATE CONNECTOR W/ LATCH APP'D. DATE 61873 MNETICS O A22020-001 CAGE CODE DWG NO. CONNECTOR CORPORATION 7260 COMMERCE CIRCLE EAST MINNEAPOLIS, MN 55432 WWW.OMNETICS.COM SHEET 1 OF 1 REV SCALE: 4:1 C
A22020-001 价格&库存
很抱歉,暂时无法提供与“A22020-001”相匹配的价格&库存,您可以联系我们找货
