MATERIALS & SPECIFICATIONS
PART NO.
A28100-009
.160
4.06
HOUSING:
ALUMINUM 6061-T6, NICKEL
PLATE PER AMS-C-26074
1
INSULATOR:
LIQUID CRYSTAL POLYMER (LCP)
PER ASTM D5138
DATE
G
96463
01-30-10
A
A
APP
TLM
.345
8.76
.105
2.67
B
.0575
1.46
.140
3.56
.125
3.18
A
6
TERMINATION:
SOLDER COATED WITH SN63A PER
J-STD-006 OR AMS-P-81728
ECO
5
2X #0-80
UNF-2B
CONTACT:
BERYLLIUM COPPER PER ASTM
B194, C17200, GOLD PLATED
PER ASTM B488, (HARD GOLD)
TYPE II CODE C, CLASS 1.27
REV
.040
1.02
9
.095
2.41
.0125
0.32
.220
5.59
SECTION A-A
.270
6.86
CURRENT RATING:
1 AMP MAX PER MIL-DTL-32139
CONTACT RESISTANCE:
71 MILLIOHM MAX (71mV DROP
MAX) @ 1.0 AMPS PER MILDTL-32139
.100
2.54
.017 (TYP)
0.43
PERFORMANCE:
PRODUCT FAMILY TESTED TO AND
PASSED THE PERFORMANCE
SPECIFICATIONS OF TABLE VIII OF
MIL-DTL-32139
.042 MIN
1.07
(TYP)
.375
9.53
.270
6.86
2X #0-80
UNF-2B
.018
0.46
.187
4.75
2X
.085
2.16
.031
0.79
1
.070
1.78
6
.075
1.91
.270
6.86
.050
1.27
SUGGESTED PAD LAYOUT
.050
1.27
1
.006 A (TYP)
.010 (TYP)
0.25
SOLDER COATED
.170
4.32
MNPO
SLDW
DETAIL B
SCALE 6 : 1
THIRD ANGLE
-TOLERANCESUNLESS OTHERWISE NOTED
DIMENSIONS IN INCHES
2 PL DEC
3 PL DEC
4 PL DEC
ANGLES
.01
.005
.0005
1
ACTUAL SIZE
THIS DRAWING CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION WHICH IS THE PROPERTY OF
OMNETICS CONNECTOR CORP. THIS DOCUMENT MAY NOT, IN WHOLE OR IN PART, BE DUPLICATED, OR
DISCLOSED FOR ANY PURPOSE, WITHOUT WRITTEN PERMISSION FROM OMNETICS CONNECTOR CORP.
DFTM. AAS 05-05-04 TITLE:
DATE
CHK'D.
APP'D.
DATE
DATE
(9) PIN MALE
Bi-Lobe® CONNECTOR
61873
MNETICS
O
A28100-009
CAGE CODE
DWG NO.
CONNECTOR CORPORATION
7260 COMMERCE CIRCLE EAST
MINNEAPOLIS, MN 55432
WWW.OMNETICS.COM
SHEET 1 OF 1
SCALE: 3:1
REV
G
很抱歉,暂时无法提供与“A28100-009”相匹配的价格&库存,您可以联系我们找货
