A79620-001
A79620-001
    OMNETICS
    12 矩形电缆组件 插头和插座到各根导线 1.50'(457.20mm)
A79620-001 数据手册
PART NO. MATERIALS & SPECIFICATIONS INSULATOR THERMOPLASTIC PER ASTM D5138 SOCKET - COPPER ALLOY PER MIL-DTL-32139 2 ECO DATE APP D 104492 05-22-18 HV 1 .025 0.64 .125 3.18 CONTACT FINISH GOLD PLATE PER ASTM B488, TYPE II (HARD GOLD), CODE C, CLASS 1.27 WIRE 32 AWG, 7 STRAND, TYPE ET PER NEMA HP3 12 .175 4.45 11 CURRENT RATING 1 AMP MAX PER MILDTL-32139 .040 1.02 CONTACT RESISTANCE 71 MILLIOHM MAX (71mV DROP MAX) @ 1.0 AMPS PER MIL-DTL-32139 CONTACT # PERFORMANCE PRODUCT FAMILY TESTED TO AND PASSED THE PERFORMANCE SPECIFICATIONS OF TABLE VIII OF MIL-DTL-32139 ACTUAL SIZE EXCLUDING WIRE LENGTH .170 4.32 18.00±.38 457.2±9.7 COLOR 1, 11 BLACK 2, 12 BROWN 3 RED 4 ORANGE 5 YELLOW 6 GREEN 7 BLUE 8 VIOLET 9 GRAY 10 WHITE .070 1.78 32 AWG (7-40) PTFE, COLOR CODED .080 2.03 INTERNAL USE ONLY SHEET 2 OF 2 IS MANUFACTURING LOADING DIAGRAM NOTE: THIRD ANGLE PZN SLDW DIMENSIONS IN [ ] ARE IN MILLIMETERS UNLESS OTHERWISE NOTED AND ARE FOR REFERENCE ONLY REV .06 1.5 .020 0.51 CONTACT MATERIAL PINS - BERYLLIUM COPPER PER ASTM B194, ALLOY C17200 A79620-001 -TOLERANCESUNLESS OTHERWISE NOTED DIMENSIONS IN INCHES 2 PL DEC 3 PL DEC 4 PL DEC ANGLES .01 .005 .0005 1 RoHS CAGE CODE DWG NO. THIS DRAWING CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION WHICH IS THE PROPERTY OF OMNETICS CONNECTOR CORP. THIS DOCUMENT MAY NOT, IN WHOLE OR IN PART, BE DUPLICATED, OR DISCLOSED FOR ANY PURPOSE, WITHOUT WRITTEN PERMISSION FROM OMNETICS CONNECTOR CORP. DFTM. NJS 08-24-09 TITLE: (12) CONTACT POLARIZED DATE CHK'D. APP'D. DATE DATE MALE/FEMALE NANO CONNECTOR 7260 COMMERCE CIRCLE EAST MINNEAPOLIS, MN 55432 WWW.OMNETICS.COM 61873 A79620-001 SHEET 1 OF 2 REV SCALE: 10:1 D
A79620-001 价格&库存
很抱歉,暂时无法提供与“A79620-001”相匹配的价格&库存,您可以联系我们找货
