8D513M26PB
8D513M26PB
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    针位圆形连接器
8D513M26PB 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal ØS 29.4 Max Z' 31.5 Max VV THREAD M18x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Composite -Shell Plating : Nickel -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D513M26PB -Delivered with Souriau contacts and Accessories -Temperature Range -Salt Spray : -65°C to +200°C : 2000 hours -Mass : 17.9 g ± 10% A 18-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D 5 - 13 M 26 P SCALE B NA SHELL TYPE : Plug with RFI Shielding CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 13 PLATING : M = Jurisdiction & Control List Not Listed ORIENTATION : B SOURIAU Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : PIN(500 Matings) Nickel CONTACT LAYOUT : 13-26 FORMAT A3 SOURIAU DRG N° 8D513M26PB-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D513M26PB A 18-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Composite Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D513M26PB-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D513M26PB 价格&库存
很抱歉,暂时无法提供与“8D513M26PB”相匹配的价格&库存,您可以联系我们找货
