8D725F11PA
8D725F11PA
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    11 针位圆形连接器 插座,公形引脚 压接
8D725F11PA 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal A 58.7±0.3 B 42.85+0.1/-0.15 R 32.5Max S 55.6±0.4 W 3+0.9/-0.1 VV THREAD M37x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Aluminium -Shell Plating : Nickel -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D725F11PA -Delivered with Souriau contacts and Accessories -Temperature Range -Salt Spray : -65°C to +200°C : 48 hours A -Mass : 62.16 g ± 10% ISS 03-10-2016 First Release DATE Designed By: TITLE BASIC SERIES: 8D 7 - 25 F 11 P SCALE A NA SHELL TYPE : Jam nut Receptacle CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 25 PLATING : F = Jurisdiction & Control List Not Listed ORIENTATION : A SOURIAU Latest modification - by CUSTOMER DRAWING Date: Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : PIN(500 Matings) Nickel CONTACT LAYOUT : 25-11 FORMAT A3 MOD N° SOURIAU DRG N° 8D725F11PA-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout Panel cutout Dim B ØC Nominal 43.43+0/-0.25 44.7+0.25/-0 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D725F11PA A 03-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D725F11PA-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D725F11PA 价格&库存
很抱歉,暂时无法提供与“8D725F11PA”相匹配的价格&库存,您可以联系我们找货
