0,1
MATERIAL :
UTGX7--E---
0.6 0.05 for contact #20
1 0.05 for contact #16
H
COMMON QUOTES FOR ALL VERSION
A
(without marking)
7
UTGX7-----P
G
Solder
cup
Insert
UTGX7-----S
F
NUT
5
THREAD
-IP68 1 bar during 1 week: immersion
under 10 m of water. (IEC 60529)
-IP69K : exposure to high pressure water
of cleaning equipement(DIN 40050)
PANEL THICKNESS
Q
P
4,2
P/N : CROSS REF TABLE
T
3
2
SHELL
SIZE A
10
1
12
14
B
C
27.00 22.15
31.75 27.15
34.90 30.20
D
0.3
0.2 MAX
E
F
G
0.25
H
MIN /
MAX
MAX
J
K
0.25
L
MIN /
MAX
M
19.15
2.2
24.5
15.2
6.57
11.5/13.4
7.8
6.57
N
0.15
17.9
11.5/13.4
21.3
22.7
24.4
25.9
22.31
2
P
16.6
15.20
18.1
0.1
Q
0.1
0.1
0.1
0.1
R
S
T
U
3.98
3
9.85
9.20
5.31
4.92
12.17 11.37
6.56
5.29
13.10 12.23
7.06
0.1
UNEF CLASS
2A
V
THREAD
SHELL SIZE
10
12
14
TYPE OF
LAYOUT
Standard layout (No digit)
D : HISEAL Dispolder contacts
E : HISEAL Handsolder contacts
ORIENTATIONS
Normal (no digit)
W,X,Y,Z
INSERT
ARRANGEMENT
See NOTA 2
TYPE OF
CONTACTS
P: MALE
S: FEMALE
14/02/2020
3.1
11/16 24
10
7/8 20
15
1"20
Scale
3/2
FORMAT
G
F
E
D
C
A2
3
SPECIFICATION
: Without Hold on
32: With Hold on (see definition in table)
Update drawing
25253J
Latest modification - by:
J.FEURPRIER
PE.LANDAIS Date:10/05/2019
CUSTOMER DRAWING
MOD N
2
JAM NUT RECEPTACLE - SIZE 10 12 & 14 - Standard and Hiseal version
UTGX CONNECTOR
Dimensions in mm
General linear
Tolerances:
0.2
www.souriau.com
* -1mm FOR LAYOUT 12D14
H
DATE
TITLE
MASS
Jam nut
receptacle
7
Designed by:
20% (g.)
* P/N for example
SHELL TYPE
ISS
0.2
UTGX 7 14 D 19 P - --
BASIC SERIES
B
0.2 MAX
5
4
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
U
0.2
6
V : Drill diameter
For hold down clip( x2)
HATTING AREA:
Contact on PCB
2/1
7
CountryJurisdiction& Control List
FR
NOT LISTED
R
Hold on
ECHELLE
3 LOCKING
PINS RING
D
CONNECTOR FRONT VIEW : SPECIFICATION 32
N
4
PANEL CUT OUT and DRILLING
PATTERN DEFINITION
SHELL
RECEPTACLE
S
SEALING
CONDITION
Sealing in MATED conditions with COUNTERPART
and UNMATED conditions:
PERFORMANCE CHARACTERISTICS :
1- Contact to be ordered separately for version
UTGX7----- : refer to corresponding catalogue.
2- Insert arrangement refer to:
UTO-CONTACT-L-C02 (Female insulator)
UTO-DHP-003-C01 (Female insulator #20)
UTO-DHP-002-C01 (Female insulator #16)
UTO-CONTACT-L-C01 (Male insulator)
UTO-DHP-003-C01 (Male insulator #20)
UTO-DHP-001-C01 (Male insulator #16)
C144-UTS1-A (HiSeal Version)
C
6
Solder
cup
O'RING
COUNTERPART:
8
NOTA:
E
L
K
- SHELL : PA UL94 V0, UL746C F1 Black color
- 3 LOCKING PINS RING : Nickel plated Brass +
stainless Steel
- INSERT (UTGX7-----) : PA UL94 V0, UL746C F1
- INSERT (UTGX7--D/E---) : Polychloroprene
- NUT : Aluminium alloy + Anodic oxidation
- O'RING : Nitril
- CONTACTS : brass + coated depending on P/N
Operating temperature: -40
C up to 105C
Insulation resistance: 5000 min
M
Corrosion salt spray: 500 hours
Durability: 500 matings and unmatings
Sealing conditions: SEE TABLE
B
M
A
J
B
UTGX7--D---
C
D
E
F
G
H
UTGX7-----
8
B.5; Validé
SIDE VIEW FOR EACH VERSION
SOURIAU DRG N°
UTGX-0002A-C
B
NPRDS / PROJECT
GBB
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“UTGX71210P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+66.414261+8.03629
- 10+57.5590610+6.96479
- 25+50.7889325+6.14559
