MATERIAL :
UTGX7-----PSCR
7
- SHELL : PA UL94 V0, UL746C F1 Black color
- 3 LOCKING PINS RING : Nickel plated Brass +
stainless Steel
- INSERT : PA UL94 V0, UL746C F1
- NUT : Aluminium alloy + Anodic oxidation
- O'RING : Nitril
- CONTACT SPRING: copper alloy
- CONTACT BODY : brass, gold and nickel plated
- SCREW : stainless steel
A
(without marking)
G
B
Operating temperature: -40
C up to 105C
Insulation resistance: 5000 min
M
Corrosion salt spray: 500 hours
Durability: 500 matings and unmatings
Sealing conditions: SEE TABLE
5
SEALING
CONDITION
F
C
5
THREAD
SHELL
RECEPTACLE
4
CountryJurisdiction
& Control List
FR
NOT LISTED
4
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
P/N : CROSS REF TABLE
UTGX
7 14 7 P SCR
* P/N
for example
J
BASIC SERIES
SHELL TYPE
DETAIL CONTACT
2
0.2
SHELL
SIZE A
0.2
B
31.75 27.15
1
34.90 30.20
0.3
C
19.3
0.2
D
19.15
22.31
0.3
E
2.2
0.2 MAX
F
24.5
MAX
0.2
0.15
G
H
J
K
46.5
38.3
21.4
22.7
52.5
44.4
24.5
25.9
2
L
3
UNEF CLASS
2A
10% (g.)
THREAD
MASS
7/8 20
30
1"20
37
Torquing screw
advised : 20 N.cm
Cable section acceptance:
0,5 mm2 to 2,5 mm2
3
PANEL CUT OUT
3 LOCKING
PINS RING
D
PANEL THICKNESS
L
K
14
1- Contact to be ordered separately for version
UTGX7----- : refer to corresponding catalogue.
2- Insert arrangement refer to:
C008-UTS1-A(female insulator)
C007-UTS1-A (male insulator)
E
UTGX7-----SSCR
6
NUT
-IP68 1 bar during 1 week: immersion
under 10 m of water. (IEC 60529)
-IP69K : exposure to high pressure water
of cleaning equipement(DIN 40050)
7
6
NOTA:
O'RING
Sealing in MATED conditions with
COUNTERPART:
8
PERFORMANCE CHARACTERISTICS :
H
12
A
B
C
D
E
F
G
H
SIDE VIEW FOR EACH VERSION
8
A.2; Validé
COMMON QUOTES FOR ALL VERSION
G
F
SHELL SIZE
12
14
INSERT
ARRANGEMENT
See NOTA 2
A
23/10/19
ISS
DATE
Designed by:
TITLE
Scale
3/2
SCREW TERMINATION
TYPE OF
CONTACTS
P: MALE
S: FEMALE
New drawing
25253D
Latest modification - by:
J.FEURPRIER Date:23/10/19
CUSTOMER DRAWING
MOD N
E
D
C
FORMAT
A2
2
JAM NUT RECEPTACLE WITH SCREW CONTACT- SIZE 12 & 14
UTGX CONNECTOR
Dimensions in mm
General linear
Tolerances:
0.2
NPRDS / PROJECT
GBB
This document is the property of
SOURIAU
www.esterline-connection-technologies.com
It must not be reproduced or
communicated without permission
Wire strip length = 5,8 mm
H
7
3
Jam nut
receptacle
SOURIAU DRG N°
UTGX-0007A-C
B
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“UTGX7124PSCR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+195.854691+23.75777
- 10+169.7354410+20.58943
- 25+149.7675725+18.16726
