O'ring
B
(specification 05 only)
A
A
B
Housing
C
D
E
E
F
G
H
D
8
MATERIAL :
Housing : Zinc alloy nickel plated
Insert : PA 66 UL94 V0
Mating gasket : sealing IP67:Nitril
sealing IP68:Silicone
O'ring : nitril
Thread
Insert
8
PERFORMANCE CHARACTERISTICS :
A
7
B
A.8; Validé
C
Operating temperature : -40 C up to 105 C
Insulation resistance : 5000 M min
Withstanding voltage: 2000Vrms
(1500 Vrms for 102w2 and 103w3 layouts)
Corrosion salt spray : 96 hours
Durability : 500 matings and unmatings
Sealing IP67 / IP68 3 bar/30min as per IEC60529
Sealing IP69K as per DIN40050
ROHS compliant
7
NOTES :
6
Seal gasket
F(4x)
G
5
4
3
Part Number
(Note 8)
UT00102W2--HUT00103W3--HUT00103--HUT00104--HUT001044--HUT00124--HUT00128--HUT00142G1--HUT00147--HUT00148--HUT001412--HUT001492--H-
Thread
(for information)
UT001619--H-
15/16-20
UNEF Class 2A
31.05
24.61
UT001823--H-
1" 1/16-18
UNEF Class 2A
33.35
26.97
UT002028--HUT002030--HUT002235--HUT002238--H-
1" 3/16-18
UNEF Class 2A
36.55
29.36
1" 5/16-18
UNEF Class 2A
39.80
31.75
UT002448--H-
1" 7/16-18
UNEF Class 2A
42.90
34.92
9/16-24
UNEF Class 2A
11/16-24
UNEF Class 2A
A
0.3 B
23.85
26.20
0.2
18.26
C Max
Male
Female
31.50
28.60
0.2 E
0.35 F
0.15 G
0.2
33.20
25.50
UT00 14 2G1 P
20.62
W
23.01
33.20
32.50
25.50
31.50
11.35
Shell size :
1.60
Insert arrangement : See Note 7
3.10
Contact :
7.50
Insert polarisation : No letter : Standard version
W, X, Y, Z : Differents orientation
25.50
29.30
H : IP67 version
H6 : IP68 version
Sealing version :
Specification :
34.70
4
P : Male
S : Female
14.55
05 : O'ring rear on the receptacle
3
2.40
15.35
3.80
2
FEMALE CONNECTOR
A
20/04/2015
ISS
DATE
Designed by:
TITLE
SOCKET (S)
Scale
2/1
_CREATION OF THE DRAWING
24021
_Cancel & replace UT00-C01
Latest modification - by:
COUTY L.
COUTY L.
Date : 20/04/2015
CUSTOMER DRAWING
General linear
Tolerances:
0.1
NPRDS / PROJECT
UT0
1
FORMAT
A2
G
F
E
D
C
MOD N
2
RECEPTACLE
UT0 CONNECTOR
WWW.SOURIAU.COM
H
H6 05
Receptacle UT0 : Type 0
MALE CONNECTOR
PIN (P)
6
5
36.00
13/16-20
UNEF Class 2A
D
-1- Contact identification and orientation of connector, refer to:
UT0-CONTACT-L-C01 (Male)
UT0-CONTACT-L-C02 (Female)
-3- Contact to be ordered separately refer to : UT0 catalog
-4- Dimension P for front panel mounting (see to panel cut out)
-5- Dimension R for rear panel mounting (see to panel cut out)
-6- To achieved Sealing condition : Add UTFD-- Sealing Gasket
-7- Insert arrangement refer to : UT0-DHP-001-C01 (Male)
UT0-DHP-002-C01 (Female)
-8- This drawing covers p/n termination : -H / -H6 / -H05 / -H605
-9- Packaging: connector is individually packed in a plastic bag
SOURIAU DRG N°
C001-UT00-A
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 2
B
A
CLASSIFICATION : NOT EXPORT CONTROLLED
1
A
B
C
D
E
F
G
H
N(4x)
In case the connectors are equipped
with dipsolder contacts
8
8
P
G
7
M
A.8; Validé
Panel Cut Out
7
R
CONTACT RM20M12E83x (Male)
or RC20M12E83x (Female)
6
M
5
Part Number
UT00102W2--HUT00103W3--HUT00103--HUT00104--HUT001044--HUT00124--HUT00128--HUT00142G1--HUT00147--HUT00148--HUT001412--HUT001492--HUT001619--HUT001823--HUT002028--HUT002030--HUT002235--HUT002238--HUT002448--H-
Contacts to be ordered separately
4
FEMALE CONTACTS
MALE CONTACTS
Part Number
min
G
max
Part Number
3
UT00104P-H-
UT00104S-H-
UT001044P-H-
UT001044S-H-
UT00124P-H-
UT00128S-H-
UT00128P-H-
UT001412S-H-
UT001412P-H-
UT001492S-H-
UT001492P-H-
UT001619S-H-
UT001619P-H-
8.1
10.3
min
7.5
G
max
9.2
-Dimension
-Dimension
M
18.26
2
UT002030S-H-
UT002030P-H-
UT002235S-H-
UT002235P-H-
UT002238S-H-
UT002238P-H-
UT002448S-H-
0.1
R
14.20
17.30
3.20
18.40
21.85
23.01
3.20
21.50
25.00
24.61
26.97
3.20
3.20
24.60
27.80
28.10
31.35
29.36
3.20
30.95
34.50
31.75
3.20
34.10
37.70
34.92
3.90
37.30
40.90
A
04/11/2014
ISS
DATE
7.1
TITLE
Scale
3/1
1
FORMAT
A2
F
E
D
3
24021
COUTY L.
COUTY L.
Date : 04/11/2014
CUSTOMER DRAWING
C
MOD N
2
RECEPTACLE
UT0 CONNECTOR
General linear
Tolerances:
0.1
NPRDS / PROJECT
UT0
WWW.SOURIAU.COM
G
0.1
20.62
UT002448P-H-
H
P
3.20
Designed by:
5.3
0.1
4
UT001823S-H-
UT002028P-H-
N
5
UT002028S-H-
UT001823P-H-
0.2
6
SOURIAU
SOURIAU DRG N°
C001-UT00-A
B
A
SHEET
2 / 2
1
很抱歉,暂时无法提供与“UT001412SH6”相匹配的价格&库存,您可以联系我们找货
