UT06148SH
UT06148SH
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    UT0 CIRCULAR CONNECTOR UT0PLUG
UT06148SH 数据手册
A B C D E F G H MATERIAL : 19 0,25 Coupling nut 8 Housing : Zinc alloy nickel plated Coupling Nut : Aluminium alloy, nickel plated Insert : PA 66 UL94 V0 Coupling spring : Stainless steel O'ring : Nitril Thread A Insert 6 B O-seal 5 Part Number (Note 3) UT06102W2--HUT06103W3--HUT06103--HUT06104--H- COUPE Thread A for information 9/16-24 UNEF Class 2A E-E B 0.15 20.00 NOTES : UT06128--H- C 0.20 D Max Male Female 35 33 35 27 23.60 4 34 UT06147--H- 33 25.5 35 33 13/16-20 UNEF Class 2A 26.80 29.30 3 UT061619--H- 15/16-20 UNEF Class 2A 30.00 32.45 UT061823--H- 1" 1/16-18 UNEF Class 2A 33.30 35.25 UT062028--HUT062030--HUT062235--HUT062238--HUT062448--H- 1" 3/16-18 UNEF Class 2A 36.55 38.80 1" 5/16-18 UNEF Class 2A 39.50 42.00 1" 7/16-18 UNEF Class 2A 42.60 45.05 25.5 16.40 19.50 Sealing version : H : IP67 version Sealing version : No letter : Standard version 02 : Coupling nut is black anodized 27.5 2 A 20/04/2015 ISS DATE Designed by: SOCKET (S) TITLE Scale 2/1 _CREATION OF THE DRAWING 24021 _Cancel & replace UT06-C01 Latest modification - by: COUTY L. COUTY L. Date: 21/10/2013 CUSTOMER DRAWING 1 FORMAT A2 F E D C MOD N 2 PLUG UT0 PLUG CONNECTOR General linear Tolerances: 0.1 NPRDS / PROJECT UT0 WWW.SOURIAU.COM G 3 27.99 31.16 PIN (P) H 4 24.80 FEMALE CONNECTOR MALE CONNECTOR 02 Contact : P : Male S : Female Insert polarisation : No letter : Standard version W, X, Y, Z : Differents orientation 21.65 33 H Insert arrangement : See Note 1 UT061412--HUT061492--H- W 5 Shell size : 13.10 34 6 Receptacle UT0 : Type 6 25.5 26.10 7 10.15 UT06 10 2W2 P UT06142G1--HUT06148--H- E 0.20 21.80 33 11/16-24 UNEF Class 2A -1- Contact identification and orientation of connector, refer to : UT0-CONTACT-L-C01 (Male) UT0-CONTACT-L-C02 (Female) -2- Contact to be ordered separately refer to : UT0 catalog -3- This drawing covers p/n termination : -H / -H6 -4- Packaging: connector is individually packed in a plastic bag Coupling spring UT061044--HUT06124--H- Operating temperature : -40 C up to 105 C Insulation resistance : 5000 M min Withstanding voltage: 2000Vrms (1500 Vrms for 102w2 and 103w3 layouts) Corrosion salt spray : 48 hours or 96 hours ( spéc. 02 ) Durability : 500 matings and unmatings Sealing in mated conditions : IP67 / IP68 3 bars/30min as per IEC60529 ( depending on counterpart used ) Sealing in mated conditions : IP69K as per DIN40050 ROHS compliant C 7 Housing 8 PERFORMANCE CHARACTERISTICS : E A.9; Validé D SOURIAU DRG N° C001-UT06-A This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 1 B A CLASSIFICATION: NOT EXPORT CONTROLLED 1
UT06148SH 价格&库存
很抱歉,暂时无法提供与“UT06148SH”相匹配的价格&库存,您可以联系我们找货
