A
B
C
D
E
F
G
H
MATERIAL :
19 0,25
Coupling nut
8
Housing : Zinc alloy nickel plated
Coupling Nut : Aluminium alloy, nickel plated
Insert : PA 66 UL94 V0
Coupling spring : Stainless steel
O'ring : Nitril
Thread A
Insert
6
B
O-seal
5
Part Number
(Note 3)
UT06102W2--HUT06103W3--HUT06103--HUT06104--H-
COUPE
Thread A
for information
9/16-24 UNEF Class 2A
E-E
B
0.15
20.00
NOTES :
UT06128--H-
C
0.20
D Max
Male
Female
35
33
35
27
23.60
4
34
UT06147--H-
33
25.5
35
33
13/16-20 UNEF Class 2A
26.80
29.30
3
UT061619--H-
15/16-20 UNEF Class 2A
30.00
32.45
UT061823--H-
1" 1/16-18 UNEF Class 2A
33.30
35.25
UT062028--HUT062030--HUT062235--HUT062238--HUT062448--H-
1" 3/16-18 UNEF Class 2A
36.55
38.80
1" 5/16-18 UNEF Class 2A
39.50
42.00
1" 7/16-18 UNEF Class 2A
42.60
45.05
25.5
16.40
19.50
Sealing version :
H : IP67 version
Sealing version :
No letter : Standard version
02 : Coupling nut is black anodized
27.5
2
A
20/04/2015
ISS
DATE
Designed by:
SOCKET (S)
TITLE
Scale
2/1
_CREATION OF THE DRAWING
24021
_Cancel & replace UT06-C01
Latest modification - by:
COUTY L.
COUTY L.
Date: 21/10/2013
CUSTOMER DRAWING
1
FORMAT
A2
F
E
D
C
MOD N
2
PLUG
UT0 PLUG CONNECTOR
General linear
Tolerances:
0.1
NPRDS / PROJECT
UT0
WWW.SOURIAU.COM
G
3
27.99
31.16
PIN (P)
H
4
24.80
FEMALE CONNECTOR
MALE CONNECTOR
02
Contact : P : Male
S : Female
Insert polarisation : No letter : Standard version
W, X, Y, Z : Differents orientation
21.65
33
H
Insert arrangement : See Note 1
UT061412--HUT061492--H-
W
5
Shell size :
13.10
34
6
Receptacle UT0 : Type 6
25.5
26.10
7
10.15
UT06 10 2W2 P
UT06142G1--HUT06148--H-
E 0.20
21.80
33
11/16-24 UNEF Class 2A
-1- Contact identification and orientation of connector, refer to :
UT0-CONTACT-L-C01 (Male)
UT0-CONTACT-L-C02 (Female)
-2- Contact to be ordered separately refer to : UT0 catalog
-3- This drawing covers p/n termination : -H / -H6
-4- Packaging: connector is individually packed in a plastic bag
Coupling spring
UT061044--HUT06124--H-
Operating temperature : -40 C up to 105 C
Insulation resistance : 5000 M min
Withstanding voltage: 2000Vrms
(1500 Vrms for 102w2 and 103w3 layouts)
Corrosion salt spray : 48 hours or 96 hours ( spéc. 02 )
Durability : 500 matings and unmatings
Sealing in mated conditions : IP67 / IP68 3 bars/30min as per IEC60529
( depending on counterpart used )
Sealing in mated conditions : IP69K as per DIN40050
ROHS compliant
C
7
Housing
8
PERFORMANCE CHARACTERISTICS :
E
A.9; Validé
D
SOURIAU DRG N°
C001-UT06-A
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
B
A
CLASSIFICATION: NOT EXPORT CONTROLLED
1
很抱歉,暂时无法提供与“UT06142G1SH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+541.149511+65.64308
