B
A
(Without marking)
UTSX0-----P
7
INSERT
Solder
cup
NOTA:
L
Lenght receptacle
D
0.6 0.05 for contact #20
1 0.05 for contact #16
1- Contact to be ordered separately for version
UTSX0----- : refer to corresponding catalogue.
2- Insert arrangement refer to:
UTX_LAYOUT (Standard Version)
UTX-HS_LAYOUT (HiSeal Version)
3- Gasket to be ordered separately for version
4- In rear mount : Color coding ring is impossible
THREAD
F
6
UTSX0-----S
SHELL
RECEPTACLE
INSERT
INSERT
REAR
FRONT
mounting
mounting
0.1
SHELL
SIZE
10
12
14
P
3.2
0.15
0.1
17.9
Q
R
SCALE 2/1
FRONT mounting
(See nota 4)
Screw head
thickness +
panel thickness
18.3
18.3
22.3
18.3
20.6
20.6
25.1
21.5
23.0
23.0
Screw head
thickness
REAR mounting
T
Q
P/N : CROSS REF TABLE
T
2.8
Gasket (See nota 3)
Gasket (See nota 3)
2
0.4
A
0.2
B
1
10
23.8
18.26
12
26.2
20.62
14
28.6
23.01
0.1
C
0.2
0.2
D
E
0.2
F
MAX
G
H
15.2
3.2
11.35
2.3
19.15
22.31
19.5
12.1
J1
15.8 /
17.7
J2
18.1/
MAX
K1
15.8/
17.7
L
K2
M
N
G
F
SHELL SIZE
10
12
14
TYPE OF
LAYOUT
Standard layout (No digit)
D : HISEAL Dispolder contacts
E : HISEAL Handsolder contacts
ORIENTATIONS
Normal (no digit)
W,X,Y,Z
INSERT
ARRANGEMENT
See NOTA 2
TYPE OF
CONTACTS
P: MALE
S: FEMALE
B
15/09/2021
ISS
DATE
Scale
1/1
9/16-24 UNEF
18.1/
11.5
11.5
11/16-24 UNEF
D
* P/N for example
Mass column deleted / nota 4 added /
Latest modification - by:
J.GAMBIER
Q.LECOMTE
Date: 06/07/2020
FORMAT
C
A2
3
25782C
Panel cut out definition board modified
CUSTOMER DRAWING
MOD N
2
SQUARE FLANGE RECEPTACLE T0 - SIZE 10 12 14 - Standard and Hiseal version
UTSX CONNECTOR
Dimensions in mm
General linear
Tolerances:
0.2
www.souriau.com
13/16-20 UNEF
E
Square flange
0 receptacle
TITLE
THREAD
CLASS 2A
* -1mm FOR LAYOUT 12D14
H
UTSX 0 14 D 19 P -
SHELL TYPE
Designed by:
MIN /
MAX
4
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
BASIC SERIES
S
SHELL
SIZE
CountryJurisdiction& Control List
FR
NOT LISTED
T
MAX
S
15.2
P (x4)
5
3 LOCKING
PINS
REAR mounting FRONT mounting
PANEL CUT OUT DEFINITION
6
E
R
3
PANEL CUT OUT
DEFINITION
4
SEALING
CONDITIONS
5
Sealing in MATED conditions withSealing in MATED conditions with COUNTERPART and UNMATED
COUNTERPART:
conditions:
-IP6x : No ingress of dust
-IPx8 1 bar during 1 week:
immersion under 10 m of water.
-IPx8 1 bar during 1 week: immersion
-IPx9K : exposure to high presunder 10 m of water.
sure water of cleaning
-IPx9K : exposure to high pressure water
equipement (IEC 60529)
of cleaning equipement (IEC 60529)
7
Operating temperature: -40
C up to 105C
Insulation resistance: 5000 min
M
under 500V
Corrosion salt spray: 500 hours
Durability: 250 matings and unmatings
Sealing conditions: SEE TABLE
C (x4)
N
K1
SHELL : PA UL94 V0, UL746C F1 Black color
8
INSERT (UTSX0-----) : PA UL94 V0, UL746C F1 Black color
INSERT (UTSX0--D/E---) : Polychloroprene UL94 HB
CONTACTS: brass + coated depending on P/N
PERFORMANCE CHARACTERISTICS :
K2
A
INSERT
Solder
cup
B
B
INSERT
H
MATERIAL :
A
(Without marking)
M
J1
INSERT
COMMON QUOTES FOR ALL VERSION
UTSX0--E---
J2
C
UTSX0--D---
G
D
E
F
G
H
UTSX0----8
B.2; Validé
SIDE VIEW FOR EACH VERSION
SOURIAU DRG N°
UTSX-0001A-C
B
NPRDS / PROJECT
GBB
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“UTSX014E15SZ”相匹配的价格&库存,您可以联系我们找货
