UTSX6--E--B
MATERIAL :
E
Solder
cup
SHELL
PLUG
SHELL : PA UL94 V0, UL746C F1 Black color
COUPLING RING: PA UL94 V0, UL746C F1 Black color
INSERT (UTSX0-----) : PA UL94 V0, UL746C F1
INSERT (UTSX0--E---) : Polychloroprene UL94 HB
O'RING : NITRIL
MATING SEAL : SILICON
CONTACTS: brass + coated depending on P/N
MATING
SEAL
8
7
PERFORMANCE CHARACTERISTICS :
F
7
UTSX6-----P
A
A
B
C
D
E
F
G
H
UTSX6-----
COMMON QUOTES FOR ALL VERSION
8
Operating temperature: -40
C up to 105C
Insulation resistance: 5000 min
M
under 500V
Corrosion salt spray: 500 hours
Durability: 250 matings and unmatings
Insert
Sealing conditions: SEE TABLE
6
THREAD
O'RING
6
NOTA:
1- Contact to be ordered separately for version
UTSX0----- : refer to corresponding catalogue.
2- Insert arrangement refer to:
C
4
UTSX6-----S
5
D
UTX_LAYOUT (Standard Version)
UTX-HS_LAYOUT (HiSeal Version)
G
5
Solder
cup
CountryJurisdiction& Control List
FR
NOT LISTED
4
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
P/N : CROSS REF TABLE
INSERT
3
SEALING
CONDITIONS
B.2; Validé
SIDE VIEW FOR EACH VERSION
Sealing in MATED conditions with COUNTERPART
Sealing in MATED conditions with COUNTERPART:
and UNMATED conditions:
-IP6x : No ingress of dust
-IPx8 1 bar during 1 week: immersion under
10 m of water.
10 m of water.
-IPx9K : exposure to high pressure water of
cleaning equipement (IEC 60529)
2
MAX
SHELL
SIZE
A
B
min
C
D
E
10
1
12
33.3
24
25.5
24
23.5
14
0.2
F
MAX
G
SHELL TYPE
6 Plug
SHELL SIZE
10
12
14
TYPE OF
LAYOUT
Standard layout (No digit)
E : HISEAL Handsolder contacts
ORIENTATIONS
Normal (no digit)
W,X,Y,Z
INSERT
ARRANGEMENT
See NOTA 2
TYPE OF
CONTACTS
P: MALE
S: FEMALE
B
15/09/2021
ISS
DATE
Designed by:
THREAD
CLASS 2A
TITLE
Scale
20.3
26.2
9/16-24 UNEF
23.5
29.7
11/16-24 UNEF
26.7
34.6
13/16-20 UNEF
2/1
G
F
* P/N for example
Mass column deleted
Latest modification - by:
J.GAMBIER
Date:
E
D
C
A2
3
25782C
Q.LECOMTE
20/07/2020
CUSTOMER DRAWING
MOD N
2
PLUG T6 WITHOUT BACKSHELL - SIZE 10 12 & 14, Standard and Hiseal version
CONNECTEUR UTSX
Dimensions in mm
General linear
Tolerances:
0.2
www.souriau.com
FORMAT
H
UTSX 6 14 E 19 P -
BASIC SERIES
SOURIAU DRG N°
UTSX-0004A-C
B
NPRDS / PROJECT
GBB
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“UTSX61419P”相匹配的价格&库存,您可以联系我们找货
