UTSX6JC-----P
8
7
Operating temperature: -40
C up to 105C
Insulation resistance: 5000 min
M
Corrosion salt spray: 500 hours
Durability: 250 matings and unmatings
Sealing conditions: SEE TABLE
WIRING AREA (between insert and backshell seal)
E4
E3
6
NOTA:
1- Contact to be ordered separately for version
UTSX6----- : refer to corresponding catalogue.
2- Insert arrangement refer to:
4
3
COMMON QUOTES FOR ALL VERSION
Sealing in MATED conditions with COUNTERPART:
-IP6x : No ingress of dust
-IPx8 1 bar during 1 week: immersion under 10 m of water.
-IPx9K : exposure to high pressure water of cleaning equipement
(IEC 60529)
COUPLING RING
THREAD
BACKSHELL
BODY
(IEC 60529)
BACKSHELL
SEAL
BACKSHELL
NUT
SHELL
PLUG
MATING
SEAL
O'RING
B MAX
cleaning equipement
CountryJurisdiction& Control List
FR
NOT LISTED
A MAX
INSERT
MAX
MAX
STANDARD
P/N : CROSS REF TABLE
SHELL TYPE
HEXAGON backshell nut
MAX
THREAD
CLASS 2A
1
E1
E2
E3
E4
1.5 / 5
18.5
1
21
34.1
29
33.5
9/16-24 UNEF
5 / 12
3 / 9
24
2
25
38.1
33
37.5
11/16-24 UNEF
7 / 14
5 / 12
26
2.5
29
42.1
36
40.5
13/16-20 UNEF
C
10
26.2
66
2.5 / 8
12
29.7
69
14
34.6
75.5
G
F
E
D
Plug
Normal (no digit)
W,X,Y,Z
JC
SHELL SIZE
10
12
14
TYPE OF
CONTACTS
P: MALE
S: FEMALE
TYPE OF
LAYOUT
Standard layout (No digit)
E : HISEAL Handsolder contacts
INSERT
ARRANGEMENT
See NOTA 2
B
15/09/2021
ISS
DATE
TITLE
Scale
3/2
Mass column deleted
25782C
Latest modification - by:
J.GAMBIER
Date:
Q.LECOMTE
29/10/2020
C
A2
CUSTOMER DRAWING
MOD N
3
2
PLUG T6 WITH BACKSHELL JC - SIZE 10 12 & 14, Standard and Hiseal version
UTSX CONNECTOR
Dimensions in mm
General linear
Tolerances:
0.2
www.souriau.com
FORMAT
H
6
* P/N for example
BACKSHELL
Designed by:
Tightening
torque (N.m)
B
UTSX 6 JC 14 E 19 P
BASIC SERIES
D
A
4
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
2
SHELL
SIZE
REDUCING
SEAL (NOTA.3)
5
3- This part shall be used at the place of the
Sealing in MATED conditions with COUNTERPART and UNMATED conditions:standard seal to accomodate with different cable
4- Plug, backshell and the reducing seal are delivered a
a kit. The backshell already includes the standard seal.
HEXAGON D
(See tightening torque in table)
5
UTX_LAYOUT (Standard Version)
UTX-HS_LAYOUT (HiSeal Version)
CAPACITY
C
6
CONDITIONS
SHELL :PA UL94 V0, UL746C F1 Black color
COUPLING RING: PA UL94 V0 F1 Black color
BACKSHELLS : PA UL94 V0 F1 Black color
BACKSHELL Seal : CR
INSERT (UTSX0-----) : PA UL94 V0, UL746C F1
INSERT (UTSX0--E---) : Polychloroprene UL94 HB
O'RING : NITRIL
MATING SEAL : SILICON
CONTACTS: brass + coated depending on P/N
PERFORMANCE CHARACTERISTICS :
UTSX6JC-----S
7
SEALING
A
UTSX6JC--E--WIRING AREA (between insert and backshell seal)
E2
E1
B
C
D
E
F
G
H
UTSX6JC-----
MATERIAL :
8
B.2; Validé
SIDE VIEW FOR EACH VERSION
SOURIAU DRG N°
UTSX-0005A-C
B
NPRDS / PROJECT
GBB
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“UTSX6JC1210SX”相匹配的价格&库存,您可以联系我们找货
