COM-09906
COM-09906
    SPARKFUNELECTRONICS
    圆柱型(12.0mm 直径)
    LASER DIODE 532NM 5MW 12MM DIA
COM-09906 数据手册
Green Laser Module 1. Specification: 1-1 Wavelength 1-2 Output power 532nm 5mw(Laser spot) (Measure under the temperature 25ºC±3ºC) 1-3 Specs. Parameter Fixed focus, dot shape facula, ( facula pattern: TEMOO ) continuous output 1-4 Standard Dimension:φ12×66mm 1-5 Beam Dimension 6 Meter distance Output Laser spot 18mm ±2.0mm 1-6 Input Power Source DC3.2V 1-7 Consumption Current Less than 300mA 1-8 Body Brass 1-9 Life Time More than5000hours 1-10 Beam of Light Emanative Angle: 1.2mrad 1-11 Work material:Nd:YVO4+KTP 2. . Environment Condition: 2-1 Storage Temperature and Humidity -25ºC~70ºC / 93~95 Rh (Storage in 3 weeks ) 2-2 Operating Temperature and Humidity 0ºC~40ºC /20~ 80 Rh (No Condense) 3. Reliability test: 3-1 vibration test: depend on customer 3-2 voltage test: 2.8 to 3.2V 3-3temperature test:0℃ to 50℃ 1
COM-09906 价格&库存
很抱歉,暂时无法提供与“COM-09906”相匹配的价格&库存,您可以联系我们找货
