Miniature limit switch
C 50 R 1Ö/1S
Material no.: 1046962 (material no. old: 49009001)
Product features
Dimensions
• Thermoplastic enclosure
• Actuator: Roller plunger R
Notes
• With roller plunger turned 90° available on request
Technical data
Applied standards
EN ISO 13849-1, EN 60947-5-1
Connection
screw connection terminals
Enclosure
thermoplastic, glass-fibre reinforced, shockproof, selfextinguishing UL 94 V-0
Cable cross-section
max. 1.5 mm²
Actuator
plunger: brass
Tightening torque
enclosure mounting screws: approx. 1 Nm
cover screws: approx. 0.6 Nm
Rated impulse withstand voltage Uimp
4 kV
Rated insulation voltage Ui
400 V
Conventional thermal current Ithe
4A
Degree of protection
IP30 (IEC/EN 60529)
Rated operating current/voltage Ie/Ue
4 A/400 VAC
B10d (10 % load)
70 000 ‒ with an actuating angle of 30°
Utilisation category
AC-15
TM
max. 20 years
Short-circuit protection
4 A gG/gN fuse
Degree of pollution
3
Ambient temperature
‒20 °C … +75 °C
Contact material
silver
Mechanical life
70 000 operations ‒ with an actuating angle of 30°
Switching system
slow action, positive break NC contacts A
Operation cycles
max. 1800/h
Switching elements
1 NC/1 NO contact, type Zb
Repeat accuracy of switching points
± 0.1 mm
Errors and omissions excepted.
steute Technologies GmbH & Co. KG
www.steute-controltec.com
Brückenstraße 91
32584 Löhne, Germany
+49 5731 745-0
controltec@steute.com
Page: 1 / 2
15.12.2023
C 50 R 1Ö/1S
Technical data (contd.)
Contact opening
max. 2 x 4 mm
Weight
22 g
Approvals
d
Contact diagram
11
23
Switching diagram
2,5
24
1
3
5
23-24
11-12
T Positive break travel/angle
Brückenstraße 91
+49 5731 745-0
Page: 2 / 2
15.12.2023
很抱歉,暂时无法提供与“STE-1046962C050”相匹配的价格&库存,您可以联系我们找货
