ANT-GNFPC-SHL1100UF
ANT-GNFPC-SHL1100UF
    LINXTECHNOLOGIES(灵思)
    1.561GHz,1.575GHz,1.601GHz,1.602GHz Beidou,Galileo,GLONASS,GNSS,GPS 扁平插接线 RF 天线 3.2dBi,3.2dBi,2.6dBi...
ANT-GNFPC-SHL1100UF 数据手册
2-2399610-1 PCB Mount Header, Bus Bar-to-Wire, 2 Position, Header & Push-Push Assembly, Silver, Through Hole - Screw, Sealable, PowerTube HVP-HD 1400 2-2399610-1  ACTIVE PowerTube | PowerTube HVP-HD 1400 TE Internal #: 2-2399610-1 PCB Mount Header, Bus Bar-to-Wire, 2 Position, Header & PushPush Assembly, Silver, Through Hole - Screw, Sealable, PowerTube HVP-HD 1400 View on TE.com > Connectors > PCB Connectors > PCB Headers & Receptacles Connector System: Bus Bar-to-Wire Number of Positions: 2 Number of Rows: 1 Termination Method to Printed Circuit Board: Through Hole - Screw Header Type: Header & Push-Push Assembly Features Product Type Features Connector System Bus Bar-to-Wire Header Type Header & Push-Push Assembly Sealable Yes Connector & Contact Terminates To Bus Bar PCB Connector Assembly Type PCB Mount Header Configuration Features Number of Positions 2 Number of Rows 1 Electrical Characteristics Operating Voltage 1000 VAC Body Features Primary Product Color Black Contact Features  Mating Pin Diameter For support call+1 800 522 6752 14 mm[.55 in] 01/02/2024 08:52PM | Page 1 2-2399610-1 PCB Mount Header, Bus Bar-to-Wire, 2 Position, Header & Push-Push Assembly, Silver, Through Hole - Screw, Sealable, PowerTube HVP-HD 1400 Mating Pin Diameter 14 mm[.55 in] Contact Mating Area Plating Material Silver Contact Type Pin Contact Current Rating (Max) 500 A Termination Features Termination Method to Printed Circuit Board Through Hole - Screw Mechanical Attachment Mating Alignment Type Polarization Connector Mounting Type Panel Mount Usage Conditions Operating Temperature (Max) 140 °C[284 °F] Operating Temperature Range -40 – 140 °C[-40 – 284 °F] Operation/Application Circuit Application Power & Signal Industry Standards Degree of Protection IPX9K UL Flammability Rating UL 94V-0 Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant EU ELV Directive 2000/53/EC Compliant China RoHS 2 Directive MIIT Order No 32, 2016 No Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Candidate List Declared Against: JUNE 2022 (224) SVHC > Threshold: Dodecamethylcyclohexasiloxane (D6) (.11% in Component Part) Decamethylcyclopentasiloxane (D5) (.11% in Component Part) Article Safe Usage Statements: Wash thoroughly after handling. Recycle if possible and dispose of the article by following all applicable governmental regulations relevant to your geographic location.  Halogen Content Not Yet Reviewed for halogen content Solder Process Capability Not reviewed for solder process capability For support call+1 800 522 6752 01/02/2024 08:52PM | Page 2 2-2399610-1 PCB Mount Header, Bus Bar-to-Wire, 2 Position, Header & Push-Push Assembly, Silver, Through Hole - Screw, Sealable, PowerTube HVP-HD 1400 Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked. Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulation, the information TE provides on SVHC in articles for this part number is based on the latest European Chemicals Agency (ECHA) ‘Guidance on requirements for substances in articles’ posted at this URL: https://echa.europa.eu/guidance-documents/guidance-onreach Compatible Parts  TE Part # 1-2399663-1 TE Part # 1-2399663-2 TE Part # 1-2399663-3 TE Part # 2-2399663-1 Pre-ASSY,Finger Access,Code K Pre-ASSY,Finger Access,Code L Pre-ASSY,Finger Access,Code M Pre-ASSY,Tool Access,Code A TE Part # 2-2399663-2 TE Part # 2-2399663-3 TE Part # 2-2399663-4 TE Part # 2-2399663-5 Pre-ASSY,Tool Access,Code B Pre-ASSY,Tool Access,Code C Pre-ASSY,Tool Access,Code D Pre-ASSY,Tool Access,Code E TE Part # 2-2399663-6 TE Part # 2-2399663-7 TE Part # 2-2399663-8 TE Part # 2-2399663-9 Pre-ASSY,Tool Access,Code F Pre-ASSY,Tool Access,Code G Pre-ASSY,Tool Access,Code H Pre-ASSY,Tool Access,Code J For support call+1 800 522 6752 01/02/2024 08:52PM | Page 3 2-2399610-1 PCB Mount Header, Bus Bar-to-Wire, 2 Position, Header & Push-Push Assembly, Silver, Through Hole - Screw, Sealable, PowerTube HVP-HD 1400 TE Part # 2399663-2 TE Part # 2399663-3 TE Part # 2399663-4 TE Part # 2399663-5 Pre-ASSY,Finger Access,Code B Pre-ASSY,Finger Access,Code C Pre-ASSY,Finger Access,Code D Pre-ASSY,Finger Access,Code E TE Part # 2399663-6 TE Part # 2399663-7 TE Part # 2399663-8 TE Part # 2399663-9 Pre-ASSY,Finger Access,Code F Pre-ASSY,Finger Access,Code G Pre-ASSY,Finger Access,Code H Pre-ASSY,Finger Access,Code J Also in the Series PowerTube HVP-HD 1400 Automotive Connector Caps & Covers Automotive Connector EMC Shielding (3) (4) Connector Seals & Cavity Plugs(3) Other Automotive Connector Accessories(6) Automotive Housings(24) Automotive Terminals(3) PCB Headers & Receptacles(180) Customers Also Bought  TE Part #1-2103124-5 TE Part #1-2203769-1 TE Part #2035334-3 TE Part #2-2394071-4 HEADER ASSY, Ag SHIELD, KEY E, HVA280-2P 2POS, MCON 1.2 CB REC 1p TL SEALED CONTACT,FEMALE0.64, 20 TO 22 AWG 2POS,HVP1000,ASSY,90DEG,COD G/H For support call+1 800 522 6752 01/02/2024 08:52PM | Page 4 2-2399610-1 PCB Mount Header, Bus Bar-to-Wire, 2 Position, Header & Push-Push Assembly, Silver, Through Hole - Screw, Sealable, PowerTube HVP-HD 1400 TE Part #2-2399607-5 TE Part #2399610-1 TE Part #2399610-2 TE Part #2399607-1 2POS,HVP1400,ASSY,180DEG,COD J /K 2POS,HVP1400,ASSY,90DEG,COD A/B 2POS,HVP1400,ASSY,90DEG,COD C/D 2POS,HVP1400,ASSY,180DEG,COD A /B TE Part #1SNA115408R2500 TE Part #2428372-1 MB4/6.L4 2POS RING TONGUE,HOUSING ASSY Documents Product Drawings 2POS,HVP1400,ASSY,90DEG,COD A/B English CAD Files Customer View Model ENG_CVM_CVM_2-2399610-1_B.3d_igs.zip English Customer View Model ENG_CVM_CVM_2-2399610-1_B.3d_stp.zip English Customer View Model ENG_CVM_CVM_2-2399610-1_B.2d_dxf.zip English 3D PDF 3D By downloading the CAD file I accept and agree to the Terms and Conditions of use. Datasheets & Catalog Pages HIVONEX CONNECTORS & CHARGING SOLUTIONS English Product Specifications Application Specification English  For support call+1 800 522 6752 01/02/2024 08:52PM | Page 5
ANT-GNFPC-SHL1100UF 价格&库存
很抱歉,暂时无法提供与“ANT-GNFPC-SHL1100UF”相匹配的价格&库存,您可以联系我们找货
