4-2394060-3
Bus Bar-to-Wire, 1 Position, 36 mm [1.417 in] Centerline, Header & Push-Push
Assembly, Silver, Through Hole - Screw, Sealable, PowerTube HVP-HD 1000
4-2394060-3
ACTIVE
PowerTube | PowerTube HVP-HD 1000
TE Internal #: 4-2394060-3
Push-Push Assembly, Silver, Through Hole - Screw, Sealable,
View on TE.com >
Connectors > PCB Connectors > PCB Headers & Receptacles
Connector System: Bus Bar-to-Wire
Number of Positions: 1
Number of Rows: 1
Centerline (Pitch): 36 mm [ 1.417 in ]
Termination Method to Printed Circuit Board: Through Hole - Screw
Features
Product Type Features
Connector System
Bus Bar-to-Wire
Header Type
Header & Push-Push Assembly
Sealable
Yes
Connector & Contact Terminates To
Bus Bar
Configuration Features
Number of Positions
1
Number of Rows
1
Electrical Characteristics
Operating Voltage
1000 VAC
Body Features
Primary Product Color
Blue
Contact Features
Mating Pin Diameter
10 mm[.393 in]
Contact Mating Area Plating Material
Silver
For support call+1 800 522 6752
01/02/2024 10:25PM | Page 1
4-2394060-3
Silver
Contact Type
Pin
Contact Current Rating (Max)
500 A
Termination Features
Mechanical Attachment
Mating Alignment Type
Polarization
Connector Mounting Type
Panel Mount
Housing Features
Centerline (Pitch)
36 mm[1.417 in]
Usage Conditions
Operating Temperature (Max)
140 °C[284 °F]
Operating Temperature Range
-40 – 140 °C[-40 – 284 °F]
Operation/Application
Circuit Application
Power & Signal
Industry Standards
Degree of Protection
IPX9K
UL Flammability Rating
UL 94V-0
Product Compliance
For compliance documentation, visit the product page on TE.com>
EU RoHS Directive 2011/65/EU
Compliant
EU ELV Directive 2000/53/EC
Compliant
China RoHS 2 Directive MIIT Order No 32, 2016
No Restricted Materials Above Threshold
EU REACH Regulation (EC) No. 1907/2006
Current ECHA Candidate List: JUNE 2023
(235)
Candidate List Declared Against: JUNE
2023 (235)
Does not contain REACH SVHC
Halogen Content
Low Halogen - Br, Cl, F, I < 900 ppm per
homogenous material. Also BFR/CFR/PVC
Free
Solder Process Capability
Not reviewed for solder process capability
Product Compliance Disclaimer
01/02/2024 10:25PM | Page 2
4-2394060-3
This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge
based on the information they provided. This information is subject to change. The part numbers that TE has identified as
EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent
chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these
limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products
will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked. Additionally, the part
numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous
materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits
as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulation, the information TE provides
on SVHC in articles for this part number is based on the latest European Chemicals Agency (ECHA) ‘Guidance on
requirements for substances in articles’ posted at this URL: https://echa.europa.eu/guidance-documents/guidance-onreach
Compatible Parts
TE Part # 1-2394085-1
TE Part # 1-2394085-2
TE Part # 1-2394085-3
TE Part # 2-2394085-1
Pre-ASSY,Finger Access,Code K
Pre-ASSY,Finger Access,Code L
Pre-ASSY,Finger Access,Code M
Pre-ASSY,Tool Access,Code A
TE Part # 2-2394085-2
TE Part # 2-2394085-3
TE Part # 2-2394085-4
TE Part # 2-2394085-5
Pre-ASSY,Tool Access,Code B
Pre-ASSY,Tool Access,Code C
Pre-ASSY,Tool Access,Code D
Pre-ASSY,Tool Access,Code E
TE Part # 2-2394085-6
TE Part # 2-2394085-7
TE Part # 2-2394085-8
TE Part # 2-2394085-9
Pre-ASSY,Tool Access,Code F
Pre-ASSY,Tool Access,Code G
Pre-ASSY,Tool Access,Code H
Pre-ASSY,Tool Access,Code J
TE Part # 2394085-2
TE Part # 2394085-3
TE Part # 2394085-4
TE Part # 2394085-5
Pre-ASSY,Finger Access,Code B
Pre-ASSY,Finger Access,Code C
Pre-ASSY,Finger Access,Code D
Pre-ASSY,Finger Access,Code E
01/02/2024 10:25PM | Page 3
4-2394060-3
TE Part # 2394085-6
TE Part # 2394085-7
TE Part # 2394085-8
TE Part # 2394085-9
Pre-ASSY,Finger Access,Code F
Pre-ASSY,Finger Access,Code G
Pre-ASSY,Finger Access,Code H
Pre-ASSY,Finger Access,Code J
Also in the Series PowerTube HVP-HD 1000
Automotive Connector Caps & Covers
Automotive Connector EMC Shielding
(3)
(6)
Connector Seals & Cavity Plugs(3)
Other Automotive Connector
Automotive Housings(24)
Automotive Terminals(3)
PCB Headers & Receptacles(180)
Accessories(6)
Customers Also Bought
TE Part #TAA754A5501-001
TE Part #TAB62346501-002
TE Part #2383445-3
TE Part #2383853-2
M12A5-FR-PUR-0.5M
M12B2-FS-PUR TORSION-1.0M
DIA 10MM,TERMINAL,FAM SLD
/UNSLD,CB
H&S 70mm, Shielt Sleeve
TE Part #2395861-3
TE Part #4-2394060-1
TE Part #4-2394060-2
TE Part #8-2394060-1
H&S 70mm, Inner housing
1POS,HVP1000,ASSY,180DEG,COD A
1POS,HVP1000,ASSY,180DEG,COD B
01/02/2024 10:25PM | Page 4
4-2394060-3
TE Part #8-2394060-2
TE Part #2407666-1
BLIND PLUG BLOCK ASSEMBLY,
FINGER UNLOCK
Documents
CAD Files
3D PDF
3D
Customer View Model
ENG_CVM_CVM_4-2394060-3_B.2d_dxf.zip
English
Customer View Model
ENG_CVM_CVM_4-2394060-3_B.3d_igs.zip
English
Customer View Model
ENG_CVM_CVM_4-2394060-3_B.3d_stp.zip
English
By downloading the CAD file I accept and agree to the Terms and Conditions of use.
Datasheets & Catalog Pages
HIVONEX CONNECTORS & CHARGING SOLUTIONS
English
Product Specifications
Application Specification
English
01/02/2024 10:25PM | Page 5
