ADP-BNCF-BNCF
ADP-BNCF-BNCF
    LINXTECHNOLOGIES(灵思)
    同轴连接器(RF) - 适配器 BNC 插孔,母插口 至 BNC 插孔,母插口 50 欧姆
ADP-BNCF-BNCF 数据手册
ADP-BNCF-BNCF In-Series Adapter, Straight, BNC, Jack Side A, BNC, Jack Side B, 2 Position ADP-BNCF-BNCF  ACTIVE TE Internal #: ADP-BNCF-BNCF In-Series Adapter, Straight, BNC, Jack Side A, BNC, Jack Side B, 2 Position View on TE.com > Connectors > Connector Accessories > Connector Adapters & Connector Savers Connector Interface Adapter Type: In-Series Adapter Body Orientation: Straight Side A Interface: BNC Side A Gender: Jack Side B Interface: BNC Features Product Type Features Connector Interface Adapter Type In-Series Adapter Side A Interface BNC Side A Gender Jack Side B Interface BNC Side B Gender Jack Connector System Cable-to-Cable Sealable No Configuration Features Number of Positions 2 Electrical Characteristics Impedance 50 Ω Body Features Hermetically Sealed No Body Plating Material Nickel Body Material Brass Contact Features Contact Mating Area Plating Material Gold Mechanical Attachment  RF Contact Captivation Method For support call+1 800 522 6752 Mechanical 01/02/2024 11:39PM | Page 1 ADP-BNCF-BNCF In-Series Adapter, Straight, BNC, Jack Side A, BNC, Jack Side B, 2 Position RF Contact Captivation Method Mechanical Housing Features Body Orientation Straight Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant with Exemptions EU ELV Directive 2000/53/EC Not Yet Reviewed China RoHS 2 Directive MIIT Order No 32, 2016 Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Candidate List Declared Against: JUNE 2023 (235) SVHC > Threshold: Pb (3.6% in Component Part) Article Safe Usage Statements: Do not eat, drink or smoke when using this product. Wash thoroughly after handling. Recycle if possible and dispose of the article by following all applicable governmental regulations relevant to your geographic location. Halogen Content Low Bromine/Chlorine - Br and Cl < 900 ppm per homogenous material. Also BFR /CFR/PVC Free Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be updating its statements accordingly. Compatible Parts  For support call+1 800 522 6752 01/02/2024 11:39PM | Page 2 ADP-BNCF-BNCF In-Series Adapter, Straight, BNC, Jack Side A, BNC, Jack Side B, 2 Position TE Part # CAT-076-BNCJKISG50 TE Part # 5227671-1 BNC RF Connector: Jack Assembly, Isolated Ground Protection, 50 Ohm BNC PCB VERTICAL W/PINS Customers Also Bought TE Part #3-215877-1 TE Part #5-794677-4 TE Part #5069774002 TE Part #374209-E 8/8 PCB MOD.JACK SE 24POS MICRO MNL ASSY,R/A,THRU CGPT-38/19-X-SP SRCP 1,27 4 F 1 IDC22 137 E1 162 1,27 TR TE Part #ADP-BNCM-BNCF-T TE Part #5-1393225-3 TE Part #5-1393225-4 TE Part #5-1416200-2 BNC Plug to BNC Jack (2) Tee RY900053 (RYA51024) RY900054 (RYA31024) V23061A1007X116 TE Part #6-1393225-2 TE Part #6-1393225-6 RY900064 (RYA51012) RY900068 (RYA51024) Documents Product Drawings BNC Jack to BNC Jack English Datasheets & Catalog Pages The FCC Road Part 15 From Concept to Approval English RF Coaxial Connector Gender Naming English  RF 101 Information for the RF Challenged For support call+1 800 522 6752 01/02/2024 11:39PM | Page 3 ADP-BNCF-BNCF In-Series Adapter, Straight, BNC, Jack Side A, BNC, Jack Side B, 2 Position RF 101 Information for the RF Challenged English BNC Jack to BNC Jack Adapter English  For support call+1 800 522 6752 01/02/2024 11:39PM | Page 4
ADP-BNCF-BNCF 价格&库存
很抱歉,暂时无法提供与“ADP-BNCF-BNCF”相匹配的价格&库存,您可以联系我们找货
