ADP-SMAM-RPSF-G
In-Series Adapter, Straight, SMA, Plug Side A, SMA, Jack Side B, 1 Position
ADP-SMAM-RPSF-G
ACTIVE
TE Internal #: ADP-SMAM-RPSF-G
Position
View on TE.com >
Connectors > Connector Accessories > Connector Adapters & Connector Savers
Connector Interface Adapter Type: In-Series Adapter
Body Orientation: Straight
Side A Interface: SMA
Side A Gender: Plug
Side B Interface: SMA
Features
Product Type Features
In-Series Adapter
Side A Interface
SMA
Side A Gender
Plug
Side B Interface
SMA
Side B Gender
Jack
Configuration Features
Number of Positions
1
Electrical Characteristics
Impedance
50 Ω
Body Features
Hermetically Sealed
No
Body Plating Material
Gold
Body Material
Brass
Contact Features
RF Connector Center Contact Plating Material
Gold
RF Connector Center Contact Material
Brass
Mechanical Attachment
RF Contact Captivation Method
Housing Features
For support call+1 800 522 6752
Mechanical
01/02/2024 11:39PM | Page 1
ADP-SMAM-RPSF-G
Housing Features
Body Orientation
Straight
Usage Conditions
Operating Temperature Range
-65 – 165 °C[-85 – 329 °F]
Packaging Features
Packaging Quantity
100
Packaging Method
Bag
Other
Dielectric Material
PTFE
Product Compliance
For compliance documentation, visit the product page on TE.com>
EU RoHS Directive 2011/65/EU
Compliant
EU ELV Directive 2000/53/EC
Not Yet Reviewed
China RoHS 2 Directive MIIT Order No 32, 2016
No Restricted Materials Above Threshold
EU REACH Regulation (EC) No. 1907/2006
Current ECHA Candidate List: JUNE 2023
(235)
Candidate List Declared Against: JUNE
2023 (235)
Does not contain REACH SVHC
Halogen Content
Low Halogen - Br, Cl, F, I < 900 ppm per
homogenous material. Also BFR/CFR/PVC
Free
Solder Process Capability
Not reviewed for solder process capability
Product Compliance Disclaimer
This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge
based on the information they provided. This information is subject to change. The part numbers that TE has identified as
EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent
chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these
limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products
will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part
numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous
materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits
as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in
articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for
substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished
product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An
Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the
product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling
based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be
updating its statements accordingly.
Compatible Parts
01/02/2024 11:39PM | Page 2
ADP-SMAM-RPSF-G
Compatible Parts
TE Part # CONSMA001-C-G
TE Part # CONSMA002-L-G
TE Part # CONSMA008-G
TE Part # CONSMA011-G
SMA Jack 50 Ohm PCB Through Hole
SMA Jack 50 Ohm Through Hole PCB
SMA Jack 50 Ohm Cable Crimp
Customers Also Bought
TE Part #1-350777-2
TE Part #1-350778-2
TE Part #2-6609107-0
TE Part #282845-2
02P UMNL V0 PLUG HSG RED
02P UMNL V0 CAP HSG RED
PS0SXSS60=C1048
TERM-BLOK,PCB MNT,90DG,2P,7.62
TE Part #ADP-RPSM-SMAF-G
TE Part #L9000106-01
TE Part #ANT-433-CW-RH-SMA
TE Part #ANT-916-WRT-SMA
RP-SMA Plug to SMA Jack
Antenna 2.45GHz WRT Monopole SMA
Antenna 1/4 Wave Short 433MHz SMA
Antenna Dome Compact 916MHz
RG174 SMA
TE Part #20012609-01
PRESS XDCR M323M-000005-150PG
Documents
Product Drawings
SMA Plug to RP-SMA Jack
English
Datasheets & Catalog Pages
Standard vs. Reverse Polarity (RP) SMA Connectors
English
ADAPTER, SMA PLUG (MALE PIN) TO RPSMA JACK (MALE PIN), GOLD
01/02/2024 11:39PM | Page 3
ADP-SMAM-RPSF-G
English
The FCC Road Part 15 From Concept to Approval
English
RF Coaxial Connector Gender Naming
English
RF 101 Information for the RF Challenged
English
01/02/2024 11:39PM | Page 4
