ADP-SMAM-UFLF
ADP-SMAM-UFLF
    LINXTECHNOLOGIES(灵思)
    同轴连接器(RF) - 适配器 SMA 插头,公引脚 至 U.FL 插孔,公引脚 50 欧姆
ADP-SMAM-UFLF 数据手册
ADP-SMAM-UFLF Between Series Adapter, Straight, SMA, Plug Side A, MHF, Jack Side B, 1 Position ADP-SMAM-UFLF  ACTIVE TE Internal #: ADP-SMAM-UFLF Between Series Adapter, Straight, SMA, Plug Side A, MHF, Jack Side B, 1 Position View on TE.com > Connectors > Connector Accessories > Connector Adapters & Connector Savers Connector Interface Adapter Type: Between Series Adapter Body Orientation: Straight Side A Interface: SMA Side A Gender: Plug Side B Interface: MHF Features Product Type Features Connector Interface Adapter Type Between Series Adapter Side A Interface SMA Side A Gender Plug Side B Interface MHF Side B Gender Jack Configuration Features Number of Positions 1 Electrical Characteristics Impedance 50 Ω Body Features Body Plating Material Nickel Body Material Brass Contact Features RF Connector Center Contact Plating Material Gold RF Connector Center Contact Material Brass Housing Features Body Orientation Straight Usage Conditions  Operating Temperature Range For support call+1 800 522 6752 -55 – 125 °C[-67 – 193 °F] 01/02/2024 11:39PM | Page 1 ADP-SMAM-UFLF Between Series Adapter, Straight, SMA, Plug Side A, MHF, Jack Side B, 1 Position Operating Temperature Range -55 – 125 °C[-67 – 193 °F] Operation/Application Operating Frequency 0 – 6 GHz Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant with Exemptions EU ELV Directive 2000/53/EC Not Yet Reviewed China RoHS 2 Directive MIIT Order No 32, 2016 Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Not Yet Reviewed Halogen Content Not Yet Reviewed for halogen content Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be updating its statements accordingly. Compatible Parts TE Part # CONSMA001-C-G TE Part # CONSMA002-L-G TE Part # CONSMA008-G TE Part # CONSMA011-G SMA Jack 50 Ohm PCB Through Hole SMA Jack 50 Ohm PCB Through Hole SMA Jack 50 Ohm Through Hole PCB SMA Jack 50 Ohm Cable Crimp Customers Also Bought  For support call+1 800 522 6752 01/02/2024 11:39PM | Page 2 ADP-SMAM-UFLF Between Series Adapter, Straight, SMA, Plug Side A, MHF, Jack Side B, 1 Position TE Part #T4043014031-000 TE Part #1-1705950-2 TE Part #2199230-1 TE Part #ADP-SMAF-UFLM M8.FMLE.PNLFRONT.3POS.STRPCB Modular Jack SE, 6/4, Gold flash M.2 0.5PITCH 4.2H KEY B GOLDFLASH SMA Jack to U.FL/MHF1 Plug TE Part #L9000109-01 TE Part #4-2176477-3 TE Part #5-1532004-0 TE Part #2118826-1 Antenna Dome 2.4GHz RG174 216 RA73F 2A 1K5 0.1% 1K RL 033-0240-0001=ADAPTER,S-93RCP CABLE ASSY SMA - IPEX MHF4L, 1.13, SMA 300MM TE Part #2118826-3 TE Part #6221-BCE-T-025-001 CABLE ASSY SMA - IPEX MHF4L, 1.13, 2.5 kPa Gauge Sensor 180MM Documents Datasheets & Catalog Pages ADAPTER, SMA PLUG (MALE PIN) TO MHF JACK (FEMALE SOCKET) English Standard vs. Reverse Polarity (RP) SMA Connectors English The FCC Road Part 15 From Concept to Approval English RF Coaxial Connector Gender Naming English RF 101 Information for the RF Challenged English  For support call+1 800 522 6752 01/02/2024 11:39PM | Page 3
ADP-SMAM-UFLF 价格&库存
很抱歉,暂时无法提供与“ADP-SMAM-UFLF”相匹配的价格&库存,您可以联系我们找货
