ANT-LPL-FPC-100
ANT-LPL-FPC-100
    LINXTECHNOLOGIES(灵思)
    750MHz,876MHz,1.96GHz,2.35GHz,2.44GHz,2.59GHz,3.55GHz 4G,5G,LTE 扁平插接线 RF 天线 696MHz ~ 960MHz,1.71GHz ...
ANT-LPL-FPC-100 数据手册
ANT-LPL-FPC-100 Flexible PCB (FPC) Antenna, Wide Band, LTE / Cellular / 5G, Internal/Embedded Mount, Adhesive, MHF / MHF1 / UMCC, Omnidirectional, Single Port ANT-LPL-FPC-100  ACTIVE TE Internal #: ANT-LPL-FPC-100 Flexible PCB (FPC) Antenna, Wide Band, LTE / Cellular / 5G, Internal/Embedded Mount, Adhesive, MHF / MHF1 / UMCC, Omnidirectional, Single Port View on TE.com > Antennas Wireless Application: 5G, Cat-M/NB-IoT, Cellular, LTE Mounting Location: Internal/Embedded Mounting Type: Adhesive Antenna Termination: MHF, MHF1, U.FL, UMCC Antenna Type: Flexible PCB (FPC) Features Product Type Features Antenna Termination MHF, MHF1, U.FL, UMCC Configuration Features Antenna Style Patch Mounting Location Internal/Embedded Antenna Type Flexible PCB (FPC) Band Type Wide Band Port Configuration Single Port Electrical Characteristics VSWR (Max) 6 dBi Body Features Product Weight  Mechanical Attachment For support call+1 800 522 6752 1.5 g[.05291 oz] 01/02/2024 11:45PM | Page 1 ANT-LPL-FPC-100 Flexible PCB (FPC) Antenna, Wide Band, LTE / Cellular / 5G, Internal/Embedded Mount, Adhesive, MHF / MHF1 / UMCC, Omnidirectional, Single Port Mechanical Attachment Polarization Linear Mounting Type Adhesive Dimensions Cable Length .1 m[.33 ft] Product Width 20 mm[.79 in] Product Length 110 mm[4.33 in] Product Height .2 mm[.01 in] Operation/Application Directionality Omnidirectional Industry Standards Wireless Application 5G, Cat-M/NB-IoT, Cellular, LTE Primary Application 5G, Cellular, LTE Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant EU ELV Directive 2000/53/EC Not Yet Reviewed China RoHS 2 Directive MIIT Order No 32, 2016 No Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Not Yet Reviewed Halogen Content Low Halogen - Br, Cl, F, I < 900 ppm per homogenous material. Also BFR/CFR/PVC Free Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling  For support call+1 800 522 6752 01/02/2024 11:45PM | Page 2 ANT-LPL-FPC-100 Flexible PCB (FPC) Antenna, Wide Band, LTE / Cellular / 5G, Internal/Embedded Mount, Adhesive, MHF / MHF1 / UMCC, Omnidirectional, Single Port Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be updating its statements accordingly. Compatible Parts TE Part # CONMHF1-SMD-G-T TE Part # CONMHF1-SMD-T TE Part # CONUFL001-SMD TE Part # CONUFL001-SMD-T U.FL/MHF1 Jack 50 Ohm PCB Surface Mount U.FL/MHF1 Jack 50 Ohm PCB Surface Mount Conn UFL MHF Straight PCB Mount Jack U.FL/MHF1 Jack 50 Ohm PCB Surface Mount Customers Also Bought TE Part #640455-6 TE Part #1-338313-2 TE Part #1-2308107-0 TE Part #6-520314-6 06P MTA100 HDR ASSY SQ R/A POL 9POS.HD-20 REC.ASSY DDR4 DIMM 288 PIN TH TYPE TRIOMATE ASSY H 16P L=2.54LDFR TE Part #2118727-4 TE Part #2344655-6 TE Part #ANT-5GW-FPC-V100UF TE Part #ANT-916-CW-HW STD SHIELD COVER, AL-29.96X19. 10X2.00MM PCB ANT, MHF 4, 100mm, Wi-Fi TRIPLE BAND Antenna 5GW FPC LV 20x120 100 UFL Antenna 1/2 Wave Dipole Whip 916MHz RPS TE Part #ANT-LPC-FPC-100 TE Part #CONSMA011 Antenna Vert 5G LTE FPC 100 SMA Jack 50 Ohm Cable Crimp Documents Datasheets & Catalog Pages VHETH Antenna Series Ground Plane Optimization English  Sub-6 Cellular LTE-5G NR Frequency Band Guide For support call+1 800 522 6752 01/02/2024 11:45PM | Page 3 ANT-LPL-FPC-100 Flexible PCB (FPC) Antenna, Wide Band, LTE / Cellular / 5G, Internal/Embedded Mount, Adhesive, MHF / MHF1 / UMCC, Omnidirectional, Single Port Sub-6 Cellular LTE-5G NR Frequency Band Guide English Considerations for Operation within the 260-470MHz Band English Understanding Antenna Specifications and Operation English Antennas Design, Application and Performance English The FCC Road Part 15 From Concept to Approval English RF 101 Information for the RF Challenged English LTE/LPWA Flexible Embedded Dipole Antenna English Virtual Antenna English Microsplatch Ground Plane Optimization English  For support call+1 800 522 6752 01/02/2024 11:45PM | Page 4
ANT-LPL-FPC-100 价格&库存
很抱歉,暂时无法提供与“ANT-LPL-FPC-100”相匹配的价格&库存,您可以联系我们找货
