ANT-LTE-MON-SMA-E
ANT-LTE-MON-SMA-E
    LINXTECHNOLOGIES(灵思)
    600MHz,700MHz,800MHz,850MHz,900MHz,1.575GHz,1.7GHz,1.8GHz,1.9GHz,2.1GHz,2.3GHz,2.5GHz,3.3GHz,3.5GHz,...
ANT-LTE-MON-SMA-E 数据手册
ANT-LTE-MON-SMA-E Terminal/Duck Antenna, Wide Band, LTE / Cellular, External Mount, Connector, SMA, Omnidirectional, Single Port, Gain 3 < 6 dBi ANT-LTE-MON-SMA-E  ACTIVE TE Internal #: ANT-LTE-MON-SMA-E Terminal/Duck Antenna, Wide Band, LTE / Cellular, External Mount, Connector, SMA, Omnidirectional, Single Port, Gain 3 < 6 dBi View on TE.com > Antennas Wireless Application: Cat-M/NB-IoT, Cellular, LTE Mounting Location: External Mounting Type: Connector Antenna Termination: SMA Antenna Type: Terminal/Duck Features Product Type Features Antenna Termination SMA Configuration Features Antenna Style Whip Mounting Location External Antenna Type Terminal/Duck Band Type Wide Band Port Configuration Single Port Electrical Characteristics VSWR (Max) EU RoHS Directive 2011/65/EU Compliant with Exemptions EU ELV Directive 2000/53/EC Not Yet Reviewed China RoHS 2 Directive MIIT Order No 32, 2016 Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Not Yet Reviewed Halogen Content Low Halogen - Br, Cl, F, I < 900 ppm per homogenous material. Also BFR/CFR/PVC Free Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling  For support call+1 800 522 6752 01/02/2024 11:45PM | Page 2 ANT-LTE-MON-SMA-E Terminal/Duck Antenna, Wide Band, LTE / Cellular, External Mount, Connector, SMA, Omnidirectional, Single Port, Gain 3 < 6 dBi Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be updating its statements accordingly. Compatible Parts TE Part # CONSMA001 TE Part # CONSMA002-L-G TE Part # CONSMA002-SMD-G TE Part # CONSMA008-G SMA Jack 50 Ohm PCB Through Hole SMA Jack 50 Ohm PCB Through Hole SMA Jack 50 Ohm PCB Surface Mount SMA Jack 50 Ohm Through Hole PCB Customers Also Bought TE Part #2-2232875-1 TE Part #3-1879075-0 TE Part #D5151-00000G-001PD TE Part #1802162-9 GIC6.0MM CONNECTOR PLUG HOUSING 2POS Power Resistor: Aluminum Housed, 75 Watt PRESS XDCR D5151-00000G-001PD 1-PORT MATENET HDR 90DEG SEALED, COD Z TE Part #ANT-B20-CW-QW-SMA TE Part #ANT-B20-PW-QW-UFL TE Part #EK5168-000 TE Part #10218306-00 Antenna 1/4 Wave Whip LTE B20 SMA Antenna 1/4 Wave Whip LTE B20 1.32 UFL CI-DRS-100-3P-MOD-01 PRESS XDCR M30J1-000105-300PG Documents Product Drawings Antenna MON-E LTE/GPS Swivel SMA English Datasheets & Catalog Pages VHETH Antenna Series Ground Plane Optimization English Sub-6 Cellular LTE-5G NR Frequency Band Guide English Considerations for Operation within the 260-470MHz Band English  Understanding Antenna Specifications and Operation For support call+1 800 522 6752 01/02/2024 11:45PM | Page 3 ANT-LTE-MON-SMA-E Terminal/Duck Antenna, Wide Band, LTE / Cellular, External Mount, Connector, SMA, Omnidirectional, Single Port, Gain 3 < 6 dBi Understanding Antenna Specifications and Operation English Antennas Design, Application and Performance English The FCC Road Part 15 From Concept to Approval English RF 101 Information for the RF Challenged English LTE Cellular and GPS/GNSS Connectorized Monopole Whip Antenna English Virtual Antenna English Microsplatch Ground Plane Optimization English  For support call+1 800 522 6752 01/02/2024 11:45PM | Page 4
ANT-LTE-MON-SMA-E 价格&库存
很抱歉,暂时无法提供与“ANT-LTE-MON-SMA-E”相匹配的价格&库存,您可以联系我们找货
