ANT-MAG-RPSF-NM-1
Remote Mount, Magnet, N-type, Single Port
ANT-MAG-RPSF-NM-1
ACTIVE
TE Internal #: ANT-MAG-RPSF-NM-1
View on TE.com >
Antennas
Mounting Location: Remote
Mounting Type: Magnet
Antenna Termination: N-type
Port Configuration: Single Port
Features
Product Type Features
Antenna Termination
N-type
Configuration Features
Mounting Location
Remote
Port Configuration
Single Port
Mechanical Attachment
Mounting Type
Magnet
Product Compliance
For compliance documentation, visit the product page on TE.com>
EU RoHS Directive 2011/65/EU
Compliant with Exemptions
EU ELV Directive 2000/53/EC
Not Yet Reviewed
China RoHS 2 Directive MIIT Order No 32, 2016
Restricted Materials Above Threshold
EU REACH Regulation (EC) No. 1907/2006
Current ECHA Candidate List: JUNE 2023
(235)
Not Yet Reviewed
Halogen Content
Not Yet Reviewed for halogen content
Solder Process Capability
Not reviewed for solder process capability
Product Compliance Disclaimer
This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge
based on the information they provided. This information is subject to change. The part numbers that TE has identified as
EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent
chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these
limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products
For support call+1 800 522 6752
01/02/2024 11:46PM | Page 1
ANT-MAG-RPSF-NM-1
will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part
numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous
materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits
as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in
articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for
substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished
product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An
Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the
product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling
based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be
updating its statements accordingly.
Compatible Parts
TE Part # CONN001-W
TE Part # CONN002-W
TE Part # CONN003-W
TE Part # CONN008-W
N Type Jack 50 Ohm PCB Through
Hole
N Type Jack 50 Ohm Panel Mount
N Type Plug 50 Ohm Panel Mount
Crimp
TE Part # CONREVSMA001-G
TE Part # CONREVSMA002-SMD-G
TE Part # L9000251-01
TE Part # L9000254-01
RP-SMA Jack 50 Ohm PCB Through
Hole
RP-SMA RA Jack 50 Ohm PCB Surface
Mount
RP-SMA Jack 50 Ohm .062 PCB Edge
Mount
RP-SMA Jack 50 Ohm .031 PCB Edge
Mount
TE Part # CONREVSMA008-G
Hole
Documents
Product Drawings
Magnetic Base RPS Jack MR195 1M N Plug
English
Datasheets & Catalog Pages
The FCC Road Part 15 From Concept to Approval
English
RF Coaxial Connector Gender Naming
01/02/2024 11:46PM | Page 2
ANT-MAG-RPSF-NM-1
English
RF 101 Information for the RF Challenged
English
Magnetic Remote Antenna Base
English
01/02/2024 11:46PM | Page 3
很抱歉,暂时无法提供与“ANT-MAG-RPSF-NM-1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+163.17450
- 5+157.74888
- 10+153.02100
