ARR-NF-NM-B
ARR-NF-NM-B
    LINXTECHNOLOGIES(灵思)
    N JACK TO N PLUG BULKHEAD LIGHTN
ARR-NF-NM-B 数据手册
ARR-NF-NM-B In-Series Adapter, Straight, N Type, Jack Side A, N Type, Jack Side B, 2 Position ARR-NF-NM-B  ACTIVE TE Internal #: ARR-NF-NM-B In-Series Adapter, Straight, N Type, Jack Side A, N Type, Jack Side B, 2 Position View on TE.com > Connectors > Connector Accessories > Connector Adapters & Connector Savers Connector Interface Adapter Type: In-Series Adapter Body Orientation: Straight Side A Interface: N Type Side A Gender: Jack Side B Interface: N Type Features Product Type Features Connector Interface Adapter Type In-Series Adapter Side A Interface N Type Side A Gender Jack Side B Interface N Type Side B Gender Jack Connector System Cable-to-Cable Sealable Yes Configuration Features Number of Positions 2 Electrical Characteristics Impedance 50 Ω Body Features Seal Material Silicone Hermetically Sealed No Body Plating Material Nickel Body Material Brass Contact Features Contact Mating Area Plating Material  Mechanical Attachment For support call+1 800 522 6752 Gold 01/02/2024 11:48PM | Page 1 ARR-NF-NM-B In-Series Adapter, Straight, N Type, Jack Side A, N Type, Jack Side B, 2 Position Mechanical Attachment RF Contact Captivation Method Mechanical Connector Mounting Type Panel Mount Housing Features Body Orientation Straight Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant with Exemptions EU ELV Directive 2000/53/EC Not Yet Reviewed China RoHS 2 Directive MIIT Order No 32, 2016 Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Not Yet Reviewed Halogen Content Not Yet Reviewed for halogen content Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be updating its statements accordingly. Compatible Parts  For support call+1 800 522 6752 01/02/2024 11:48PM | Page 2 ARR-NF-NM-B In-Series Adapter, Straight, N Type, Jack Side A, N Type, Jack Side B, 2 Position TE Part # CONN007-1-W TE Part # CONN007-2-W TE Part # CONN007-3-W TE Part # CONN007-4-W N Type Plug 50 Ohm Cable Crimp N Type Plug 50 Ohm Cable Crimp N Type Plug 50 Ohm Cable Crimp N Type Plug 50 Ohm Cable Crimp Customers Also Bought TE Part #166916-000 TE Part #T4112002041-000 TE Part #CX6254-000 TE Part #647878-1 RMW-63/19-1200/ADH-0 M12,FEMALE,RA,A CODE,4P,PG9, GOLD RHW-34/8-1200/ADH-0 SERIES 50 & 75 CONTACT,8 AWG TE Part #34162 TE Part #1622461-1 TE Part #9-1879354-6 TE Part #8-1879354-9 TERMINAL,PG R 16-14 1/4 LR1 1% 3K3 RR03 5% 3K0 AMMO RR03 5% 1K5 AMMO TE Part #9-1879354-1 TE Part #9-1879354-4 RR03 5% 1K8 AMMO RR03 5% 2K4 AMMO Documents Product Drawings Arrestor Blkhd N Jack to N Plug English Datasheets & Catalog Pages Standard vs. Reverse Polarity (RP) SMA Connectors English N Plug to N Jack Sealed Bulkhead Lightning Arrester English  The FCC Road Part 15 From Concept to Approval For support call+1 800 522 6752 01/02/2024 11:48PM | Page 3 ARR-NF-NM-B In-Series Adapter, Straight, N Type, Jack Side A, N Type, Jack Side B, 2 Position The FCC Road Part 15 From Concept to Approval English RF Coaxial Connector Gender Naming English RF 101 Information for the RF Challenged English  For support call+1 800 522 6752 01/02/2024 11:48PM | Page 4
ARR-NF-NM-B 价格&库存
很抱歉,暂时无法提供与“ARR-NF-NM-B”相匹配的价格&库存,您可以联系我们找货
