CSE-SMBM-152-SMBM
SMB Cable Assembly, .5 ft [.15 m], Red Cable, 4 GHz Operating Frequency, 50 Ω,
FEP, 25 AWG, .098 in [2.49 mm] Diameter, SMB Plug, SMB Plug
CSE-SMBM-152-SMBM
ACTIVE
TE Internal #: CSE-SMBM-152-SMBM
Frequency, 50 Ω, FEP, 25 AWG, .098 in [2.49 mm] Diameter, SMB
Plug, SMB Plug
View on TE.com >
Cable Assemblies > RF Cable Assemblies
Connector Type (End A): SMB Plug
Jacket Material: FEP
Cable Assembly Length: .15 m [ .5 ft ]
Cable Color: Red
Operating Temperature Range: -50 – 200 °C [ -58 – 392 °F ]
Features
Product Type Features
Coax Cable Type
RG-316
SMB Plug
Connector Type (End B)
SMB Plug
Cable Assembly Type
SMB
Configuration Features
Number of Connectorized Ends
2
Electrical Characteristics
Impedance
50 Ω
Body Features
Body Plating Material
Gold
Jacket Material
FEP
Cable Color
Red
Contact Features
Center Contact Plating
Gold
Dimensions
Wire Size
25 AWG
Outside Cable Diameter
2.49 mm[.098 in]
Usage Conditions
For support call+1 800 522 6752
01/03/2024 12:01AM | Page 1
CSE-SMBM-152-SMBM
Usage Conditions
-50 – 200 °C[-58 – 392 °F]
Operation/Application
Shielded
Yes
Operating Frequency
4 GHz
Other
Dielectric Material
PTFE
.15 m[.5 ft]
Product Compliance
For compliance documentation, visit the product page on TE.com>
EU RoHS Directive 2011/65/EU
Compliant
EU ELV Directive 2000/53/EC
Not Yet Reviewed
China RoHS 2 Directive MIIT Order No 32, 2016
No Restricted Materials Above Threshold
EU REACH Regulation (EC) No. 1907/2006
Current ECHA Candidate List: JUNE 2023
(235)
Candidate List Declared Against: JUNE
2023 (235)
Does not contain REACH SVHC
Halogen Content
Low Halogen - Br, Cl, F, I < 900 ppm per
homogenous material. Also BFR/CFR/PVC
Free
Solder Process Capability
Not reviewed for solder process capability
Product Compliance Disclaimer
This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge
based on the information they provided. This information is subject to change. The part numbers that TE has identified as
EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent
chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these
limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products
will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part
numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous
materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits
as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in
articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for
substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished
product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An
Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the
product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling
based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be
updating its statements accordingly.
Compatible Parts
01/03/2024 12:01AM | Page 2
CSE-SMBM-152-SMBM
Compatible Parts
TE Part # CONSMB001-1-G
TE Part # CONSMB001-G
TE Part # CONSMB001-SMD-G
SMB Jack 50 Ohm PCB Through Hole
SMB Jack 50 Ohm PCB Surface Mount
Customers Also Bought
TE Part #1241150-4
TE Part #1241050-3
TE Part #60598-3
TE Part #3-2176342-1
4P MOD II BREAK AWAY HDR , SMD,
BLISTER
2x3P MOD II BREAK AWAY HDR,SMD,
BLISTER
058PIN REC IS 22-20 010PTPPHBZ
CRGCQ 0805 100K 5%
TE Part #7-2176307-6
TE Part #3-1123723-2
TE Part #ADP-SMAF-SMAF-B-G
TE Part #CSE-SMBM-305-SMBM
RP 1E 0.1W 75K 0.1% 25PPM 5K RL
3.96 EP HDR ASSY 2P(BLUE)
SMA Jack to SMA Jack Bulkhead
SMB to SMB 305mm RG316
Documents
Product Drawings
SMB to SMB 152mm RG316
English
Datasheets & Catalog Pages
The FCC Road Part 15 From Concept to Approval
English
RF Coaxial Connector Gender Naming
English
RF 101 Information for the RF Challenged
English
SMB Plug to SMB Plug Cable Assembly
English
01/03/2024 12:01AM | Page 3
