ANT-8/9-SPS1-1
Antenna LPWA 868/915 Puck RG174 1M SMA
ANT-8/9-SPS1-1
OBSOLETE
TE Internal #: L9000143-01
TE Internal Description: Antenna LPWA 868/915 Puck RG174 1M
SMA
View on TE.com >
Antennas
Wireless Application: LoRaWAN, LPWAN, Wi-Fi
Mounting Location: External
Mounting Type: Panel
Antenna Termination: SMA
Antenna Type: Dome/Puck
Features
Product Type Features
Antenna Termination
SMA
Configuration Features
Antenna Style
Disk-Puck
Mounting Location
External
Antenna Type
Dome/Puck
Band Type
Dual Band
Port Configuration
Single Port
Electrical Characteristics
VSWR (Max)
EU RoHS Directive 2011/65/EU
Compliant with Exemptions
EU ELV Directive 2000/53/EC
Not Yet Reviewed
China RoHS 2 Directive MIIT Order No 32, 2016
Restricted Materials Above Threshold
EU REACH Regulation (EC) No. 1907/2006
Current ECHA Candidate List: JUNE 2023
(235)
Not Yet Reviewed
Halogen Content
Not Yet Reviewed for halogen content
Solder Process Capability
Not reviewed for solder process capability
Product Compliance Disclaimer
This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge
based on the information they provided. This information is subject to change. The part numbers that TE has identified as
EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent
chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these
limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products
will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part
numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous
materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits
as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in
articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for
substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished
product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An
Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the
product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling
based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be
updating its statements accordingly.
For support call+1 800 522 6752
01/03/2024 12:24AM | Page 2
ANT-8/9-SPS1-1
Customers Also Bought
TE Part #GA3K3A1A
TE Part #7-1393239-5
TE Part #8-1393224-9
TE Part #ANT-5GW-SPS1-1
DISCRETE 3K OHMS,+/-0.1C FROM
0C TO 70C
RT31L024
RY533024
Antenna 5G LTE IP67 Puck RG174 1M
SMA
TE Part #CONREVSMA001-G
TE Part #CONSMA001-C-G
TE Part #L9000266-01
TE Part #CONSMA007-G
RP-SMA Jack 50 Ohm PCB Through
Hole
SMA Jack 50 Ohm PCB Through Hole
SMA Jack 50 Ohm .062 PCB Edge
Mount
SMA Plug 50 Ohm Cable Crimp
TE Part #6-1393224-3
TE Part #ANT-W63-SPS1-1
RY213048
Antenna WIFI6 IP67 Puck RG174 1M
SMA
Documents
Product Drawings
English
Datasheets & Catalog Pages
VHETH Antenna Series Ground Plane Optimization
English
Sub-6 Cellular LTE-5G NR Frequency Band Guide
English
Considerations for Operation within the 260-470MHz Band
English
Understanding Antenna Specifications and Operation
English
Considerations for Operation within the 902-928MHz Band
English
Antennas Design, Application and Performance
01/03/2024 12:24AM | Page 3
ANT-8/9-SPS1-1
English
English
Antenna Color Codes
English
The FCC Road Part 15 From Concept to Approval
English
RF 101 Information for the RF Challenged
English
Virtual Antenna
English
Microsplatch Ground Plane Optimization
English
Panel Mount 868/915 MHz LPWA Antenna
English
01/03/2024 12:24AM | Page 4
很抱歉,暂时无法提供与“ANT-8/9-SPS1-1”相匹配的价格&库存,您可以联系我们找货
