ANT-W63-WRT-MHF4-150 数据手册
Dome/Puck Antenna, Triple Band, Wi-Fi, External Mount, Panel, MHF4,
Omnidirectional, Single Port, Gain > 6 dBi
ACTIVE
TE Internal #: L9000236-01
MHF4, Omnidirectional, Single Port, Gain > 6 dBi
View on TE.com >
Antennas
Wireless Application: Vehicular, Wi-Fi
Mounting Location: External
Mounting Type: Panel
Antenna Termination: MHF4
Antenna Type: Dome/Puck
Features
Product Type Features
Antenna Termination
MHF4
Configuration Features
Mounting Location
External
Antenna Type
Dome/Puck
Band Type
Triple Band
Port Configuration
Single Port
Signal Characteristics
Nominal Frequency Range
2400 – 7125
Peak Gain
> 6 dBi
Mechanical Attachment
Mounting Type
Panel
Operation/Application
Directionality
Omnidirectional
Industry Standards
Vehicular, Wi-Fi
Primary Application
Wi-Fi
Product Compliance
For compliance documentation, visit the product page on TE.com>
For support call+1 800 522 6752
01/03/2024 12:25AM | Page 1
EU RoHS Directive 2011/65/EU
Compliant with Exemptions
EU ELV Directive 2000/53/EC
Not Yet Reviewed
China RoHS 2 Directive MIIT Order No 32, 2016
Restricted Materials Above Threshold
EU REACH Regulation (EC) No. 1907/2006
Current ECHA Candidate List: JUNE 2023
(235)
Not Yet Reviewed
Halogen Content
Not Yet Reviewed for halogen content
Solder Process Capability
Not reviewed for solder process capability
Product Compliance Disclaimer
This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge
based on the information they provided. This information is subject to change. The part numbers that TE has identified as
EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent
chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these
limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products
will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part
numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous
materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits
as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in
articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for
substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished
product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An
Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the
product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling
based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be
updating its statements accordingly.
Compatible Parts
TE Part # CONMHF4-SMD-G-T
MHF4 Jack 50 Ohm PCB Surface
Mount
Customers Also Bought
TE Part #81665-4
TE Part #66099-4
TE Part #2-36151-2
TE Part #1487594-2
ECONOSEAL, FLANGE GASKET
III+ PIN,1-16,30AU/FL,LP
PIDG R 22-16 COMM 22-18MIL 6
USB, A-B, 28/28, BLACK, 0.25M
01/03/2024 12:25AM | Page 2
TE Part #32456
TE Part #7-520366-2
TE Part #1546670-4
TE Part #5-747905-5
PIDG HK 22-16 COMM 22-18 MIL 8
ULTRAFAST 110 ASSY REC 26-22
TPBR LP
4P .437" DR BARRIER,W/BND SCRW
9 Rcpt Solder Cup, 30 gold, Ro
TE Part #CSJ-SGFB-100-MHF4
TE Part #VFT69383B2NJN-518Q
SMA to MHF4 100mm 0.81 OD
VEHICULAR,MIMO,3 PORTS LTE1,
LTE2,GNSS,BL
Documents
Product Drawings
Antenna Dome Wifi6/6E 0.81 150 MHF4
English
Datasheets & Catalog Pages
External Panel-Mount WiFi 6 Antenna
English
VHETH Antenna Series Ground Plane Optimization
English
Sub-6 Cellular LTE-5G NR Frequency Band Guide
English
Considerations for Operation within the 260-470MHz Band
English
Understanding Antenna Specifications and Operation
English
Antennas Design, Application and Performance
English
The FCC Road Part 15 From Concept to Approval
English
RF 101 Information for the RF Challenged
English
Virtual Antenna
English
Microsplatch Ground Plane Optimization
English
01/03/2024 12:25AM | Page 3
01/03/2024 12:25AM | Page 4
