CONSMA003.031-L-G
CONSMA003.031-L-G
    LINXTECHNOLOGIES(灵思)
    SMA 连接器 插座,母插槽 50 欧姆 板边缘,末端突出式,面板安装 焊接
CONSMA003.031-L-G 数据手册
CONSMA003.031-L-G SMA RF Interface, Jack, 50 Ω, Threaded, 0 – 18 GHz Operating Frequency, 1 Position, Printed Circuit Board, Board Mount, -65 – 165 °C [-85 – 329 °F] CONSMA003.031-L-G  ACTIVE TE Internal #: L9000264-01 SMA RF Interface, Jack, 50 Ω, Threaded, 0 – 18 GHz Operating Frequency, 1 Position, Printed Circuit Board, Board Mount, -65 – 165 °C [-85 – 329 °F] View on TE.com > Connectors > RF Connectors > Coax Connectors RF Interface: SMA RF Connector Style: Jack Impedance: 50 Ω RF Connector Coupling Mechanism: Threaded Operating Frequency: 0 – 18 GHz Features Product Type Features Connector Product Type Connector Assembly RF Interface SMA RF Connector Style Jack Sealable No Connector & Contact Terminates To Printed Circuit Board Configuration Features PCB Mount Orientation Edge Number of Positions 1 Number of Coaxial Contacts 1 Electrical Characteristics Impedance 50 Ω Body Features Cable Connector Orientation Straight Body Material Brass Body Material Finish Plated Body Plating Material Gold Contact Features RF Connector Center Contact Plating Material  RF800 Connector For support call+1 522 6752 Center Contact Material Gold Beryllium Copper 01/03/2024 12:25AM | Page 1 CONSMA003.031-L-G SMA RF Interface, Jack, 50 Ω, Threaded, 0 – 18 GHz Operating Frequency, 1 Position, Printed Circuit Board, Board Mount, -65 – 165 °C [-85 – 329 °F] RF Connector Center Contact Plating Material Gold RF Connector Center Contact Material Beryllium Copper Termination Features Termination Method to Wire & Cable Solder Mechanical Attachment RF Connector Coupling Mechanism Threaded Connector Mounting Type Board Mount RF Contact Captivation Method Mechanical Detent Without Usage Conditions Operating Temperature Range -65 – 165 °C[-85 – 329 °F] Operation/Application Operating Frequency 0 – 18 GHz Circuit Application Signal Packaging Features Packaging Quantity 90 Packaging Method Tray Other Lockwasher Material Brass Dielectric Material PTFE Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant with Exemptions EU ELV Directive 2000/53/EC Not Yet Reviewed China RoHS 2 Directive MIIT Order No 32, 2016 Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Not Yet Reviewed Halogen Content Not Yet Reviewed for halogen content Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent  For support call+1 800 522 6752 01/03/2024 12:25AM | Page 2 CONSMA003.031-L-G SMA RF Interface, Jack, 50 Ω, Threaded, 0 – 18 GHz Operating Frequency, 1 Position, Printed Circuit Board, Board Mount, -65 – 165 °C [-85 – 329 °F] based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be updating its statements accordingly. Compatible Parts TE Part # L9000274-01 TE Part # NT-SMA-G TE Part # NT-SMA-N TE Part # WS-SMA-G SMA Plug 50 Ohm .031 PCB Edge Mount Connector Nut For SMA Connectors Gold Nut Nickel SMA Connectors RoHS Connector Lockwasher For SMA Connectors TE Part # WS-SMA-N TE Part # OR-SMA-R Washer Nickel SMA Connector RoHS Rubber O-Ring SMA Connectors RoHS Customers Also Bought  TE Part #6609017-9 TE Part #327043 TE Part #181953-1 TE Part #1-1423673-2 6EC1=F7284 S0 PG SPD 22-16 COMM 22-18 MIL 6 250 FASTON,TAB,BR W51-A122B1-10=CKTBKR,THERM,ROC For support call+1 800 522 6752 01/03/2024 12:25AM | Page 3 CONSMA003.031-L-G SMA RF Interface, Jack, 50 Ω, Threaded, 0 – 18 GHz Operating Frequency, 1 Position, Printed Circuit Board, Board Mount, -65 – 165 °C [-85 – 329 °F] TE Part #2-1676480-2 TE Part #L9000263-01 TE Part #L9000281-01 CRG0402 1% 1K0 SMA Jack 50 Ohm .031 PCB Edge Mount SMA Jack 50 Ohm .031 PCB Edge Mount Documents Product Drawings SMA Jack 50 Ohm .031 PCB Edge Mount English SMA Jack 50 Ohm .031 PCB Edge Mount English Datasheets & Catalog Pages SMA FEMALE EDGE MOUNT FOR 0.031INCH THICK BOARD, EXTENDED English  For support call+1 800 522 6752 01/03/2024 12:25AM | Page 4
CONSMA003.031-L-G 价格&库存
很抱歉,暂时无法提供与“CONSMA003.031-L-G”相匹配的价格&库存,您可以联系我们找货
