CONSMA020.042-G
CONSMA020.042-G
    LINXTECHNOLOGIES(灵思)
    SMA 连接器 插孔,母形插口 50 欧姆 板边缘,末端装入式 焊接
CONSMA020.042-G 数据手册
CONSMA020.042-G SMA RF Interface, Jack, 50 Ω, Threaded, 18 GHz Operating Frequency, Cable-toBoard, 1 Position, Printed Circuit Board, Board Mount, Brass, Gold CONSMA020.042-G  ACTIVE TE Internal #: L9000278-01 SMA RF Interface, Jack, 50 Ω, Threaded, 18 GHz Operating Frequency, Cable-to-Board, 1 Position, Printed Circuit Board, Board Mount, Brass, Gold View on TE.com > Connectors > RF Connectors > Coax Connectors RF Interface: SMA RF Connector Style: Jack Impedance: 50 Ω RF Connector Coupling Mechanism: Threaded Operating Frequency: 18 GHz Features Product Type Features Connector Product Type Connector Assembly RF Interface SMA RF Connector Style Jack Connector System Cable-to-Board Sealable No Connector & Contact Terminates To Printed Circuit Board Configuration Features Number of Positions 1 Number of Coaxial Contacts 1 Electrical Characteristics Impedance 50 Ω Body Features Body Material Brass Body Plating Material Gold Mechanical Attachment  RF Connector Coupling Mechanism Threaded Connector Mounting Type Board Mount Operation/Application For support call+1 800 522 6752 01/03/2024 12:25AM | Page 1 CONSMA020.042-G SMA RF Interface, Jack, 50 Ω, Threaded, 18 GHz Operating Frequency, Cable-toBoard, 1 Position, Printed Circuit Board, Board Mount, Brass, Gold Operation/Application Operating Frequency 18 GHz Circuit Application Signal Other Dielectric Material Polytetrafluoroethylene (PTFE) Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant EU ELV Directive 2000/53/EC Not Yet Reviewed China RoHS 2 Directive MIIT Order No 32, 2016 No Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Candidate List Declared Against: JUNE 2023 (235) Does not contain REACH SVHC Halogen Content Low Halogen - Br, Cl, F, I < 900 ppm per homogenous material. Also BFR/CFR/PVC Free Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be updating its statements accordingly. Compatible Parts  For support call+1 800 522 6752 01/03/2024 12:25AM | Page 2 CONSMA020.042-G SMA RF Interface, Jack, 50 Ω, Threaded, 18 GHz Operating Frequency, Cable-toBoard, 1 Position, Printed Circuit Board, Board Mount, Brass, Gold TE Part # CONSMA007 TE Part # CONSMA007-G TE Part # CONSMA007-R178 TE Part # CONSMA007-R58 SMA Plug 50 Ohm Cable Crimp SMA Plug 50 Ohm Cable Crimp SMA Plug 50 Ohm Cable Crimp SMA Plug 50 Ohm Cable Crimp Customers Also Bought TE Part #1-5499206-2 TE Part #825457-3 TE Part #8-2176089-7 TE Part #2176323-9 A/L UNIV HDR 64P VERT LG LAT MOD II HSG R.A. 3 POS RP 1J 0.166W 93K1 0.1% 25PPM 1K RL SMV 2W 470K 5% TE Part #CONSMA008-G TE Part #L9000277-01 TE Part #L9000279-01 TE Part #EB1UM-00000P-05KPA SMA Jack 50 Ohm Through Hole PCB SMA Jack 50 Ohm .031 PCB Edge Mount SMA Jack 50 Ohm .062 PCB Edge Mount PRESS XDCR EB1UM-00000P-05KPA Documents Product Drawings SMA Jack 50 Ohm .042 PCB Edge Mount English Datasheets & Catalog Pages SMA Jack PCB Edge-Mount Connector English  For support call+1 800 522 6752 01/03/2024 12:25AM | Page 3
CONSMA020.042-G 价格&库存
很抱歉,暂时无法提供与“CONSMA020.042-G”相匹配的价格&库存,您可以联系我们找货
