ANT-W63WS6-IPW1-RPS
ANT-W63WS6-IPW1-RPS
    LINXTECHNOLOGIES(灵思)
    2.44GHz,5.025GHz,5.5GHz 802.11ac/ax/be/b/g/n,Bluetooth,WLAN,Zigbee™ 片式,倾斜 RF 天线 2.4GHz ~ 2.485GHz,5....
ANT-W63WS6-IPW1-RPS 数据手册
ANT-W63WS6-IPW1-RPS Terminal/Duck Antenna, Triple Band, Wi-Fi, External Mount, Connector, N-type, Omnidirectional, Single Port, Gain > 6 dBi ANT-W63WS6-IPW1-RPS  ACTIVE TE Internal #: L9000365-01 Terminal/Duck Antenna, Triple Band, Wi-Fi, External Mount, Connector, N-type, Omnidirectional, Single Port, Gain > 6 dBi View on TE.com > Antennas Wireless Application: Wi-Fi Mounting Location: External Mounting Type: Connector Antenna Termination: N-type Antenna Type: Terminal/Duck Features Product Type Features Antenna Termination N-type Configuration Features Antenna Style Dipole Mounting Location External Antenna Type Terminal/Duck Band Type Triple Band Port Configuration Single Port Signal Characteristics Nominal Frequency Range 2400 – 7125 Peak Gain > 6 dBi Mechanical Attachment Mounting Type Connector Operation/Application Directionality Omnidirectional Industry Standards  Wireless Application Wi-Fi Primary Application Wi-Fi Product Compliance For support call+1 800 522 6752 01/03/2024 12:25AM | Page 1 ANT-W63WS6-IPW1-RPS Terminal/Duck Antenna, Triple Band, Wi-Fi, External Mount, Connector, N-type, Omnidirectional, Single Port, Gain > 6 dBi Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant with Exemptions EU ELV Directive 2000/53/EC Compliant with Exemptions China RoHS 2 Directive MIIT Order No 32, 2016 Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Candidate List Declared Against: JUNE 2023 (235) SVHC > Threshold: Pb (2.82% in Component Part) Article Safe Usage Statements: Do not eat, drink or smoke when using this product. Wash thoroughly after handling. Recycle if possible and dispose of the article by following all applicable governmental regulations relevant to your geographic location. Halogen Content Not Low Halogen - contains Br or Cl > 900 ppm. Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be updating its statements accordingly. Compatible Parts  TE Part # CONREVSMA001-G TE Part # CONREVSMA002-SMD-G TE Part # L9000251-01 TE Part # L9000254-01 RP-SMA Jack 50 Ohm PCB Through Hole RP-SMA RA Jack 50 Ohm PCB Surface Mount RP-SMA Jack 50 Ohm .062 PCB Edge Mount RP-SMA Jack 50 Ohm .031 PCB Edge Mount For support call+1 800 522 6752 01/03/2024 12:25AM | Page 2 ANT-W63WS6-IPW1-RPS Terminal/Duck Antenna, Triple Band, Wi-Fi, External Mount, Connector, N-type, Omnidirectional, Single Port, Gain > 6 dBi TE Part # CONREVSMA008-G RP-SMA Jack 50 Ohm PCB Through Hole Customers Also Bought TE Part #86479-3 TE Part #2008563-1 TE Part #8-1879512-5 TE Part #HPP845E131R5 10 MODII HDR DRRA UNSHRD .100 Connector,1 Pos SMT Poke-In CRGH0805 1% 1M0 0.33W HTU21DF RH/T SENSOR IC B5000 TE Part #L9000029-01 TE Part #1SNA166523R1200 TE Part #1SNA166529R2000 TE Part #1SNA166566R2500 Antenna 1/4 Wave R-Angle 2.4GHz RPS CC-R-VA FIC-2/4-R M10-R-C5A TE Part #1SNA166573R2400 FIM10-R Documents Product Drawings Antenna Wifi6/6E IP67 Blade RPSMA English Datasheets & Catalog Pages VHETH Antenna Series Ground Plane Optimization English Sub-6 Cellular LTE-5G NR Frequency Band Guide English  Considerations for Operation within the 260-470MHz Band For support call+1 800 522 6752 01/03/2024 12:25AM | Page 3 ANT-W63WS6-IPW1-RPS Terminal/Duck Antenna, Triple Band, Wi-Fi, External Mount, Connector, N-type, Omnidirectional, Single Port, Gain > 6 dBi Considerations for Operation within the 260-470MHz Band English Understanding Antenna Specifications and Operation English Antennas Design, Application and Performance English Antenna Color Codes English The FCC Road Part 15 From Concept to Approval English RF 101 Information for the RF Challenged English Hinged Blade WiFi 6/6E/7 Antenna English Virtual Antenna English Microsplatch Ground Plane Optimization English  For support call+1 800 522 6752 01/03/2024 12:25AM | Page 4
ANT-W63WS6-IPW1-RPS 价格&库存
很抱歉,暂时无法提供与“ANT-W63WS6-IPW1-RPS”相匹配的价格&库存,您可以联系我们找货
