ADS7804UE4
ADS7804UE4
    ROCHESTER(罗切斯特)
    SOIC28
    SAR ADC, 12-BIT, PARALLEL ACCESS
ADS7804UE4 数据手册
AD S ADS7804 780 4 ADS 780 4 SBAS019A – JANUARY 1992 – REVISED MAY 2003 12-Bit 10µs Sampling CMOS ANALOG-to-DIGITAL CONVERTER FEATURES DESCRIPTION ● ● ● ● ● ● ● ● The ADS7804 is a complete 12-bit sampling analog-to-digital (A/D) converter using state-of-the-art CMOS structures. It contains a complete 12-bit, capacitor-based, SAR A/D converter with S/H, reference, clock, interface for microprocessor use, and three-state output drivers. ● ● ● ● 100kHz min SAMPLING RATE STANDARD ±10V INPUT RANGE 72dB min SINAD WITH 45kHz INPUT ±0.45 LSB max INL DNL: 12 Bits “No Missing Codes” SINGLE +5V SUPPLY OPERATION PIN-COMPATIBLE WITH 16-BIT ADS7805 USES INTERNAL OR EXTERNAL REFERENCE COMPLETE WITH S/H, REF, CLOCK, ETC. FULL PARALLEL DATA OUTPUT 100mW max POWER DISSIPATION 28-PIN 0.3" PLASTIC DIP AND SO PACKAGES Clock The ADS7804 is specified at a 100kHz sampling rate, and guaranteed over the full temperature range. Laser-trimmed scaling resistors provide an industrystandard ±10V input range, while the innovative design allows operation from a single +5V supply, with power dissipation under 100mW. The 28-pin ADS7804 is available in plastic 0.3" DIP and SO packages, both fully specified for operation over the industrial –40°C to +85°C range. Successive Approximation Register and Control Logic R/C CS BYTE BUSY CDAC 20kΩ ±10V Input 10kΩ 4kΩ Comparator Output Latches and Three State Drivers Three State Parallel Data Bus CAP Buffer Internal +2.5V Ref 4kΩ REF Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet. Copyright © 1992-2003, Texas Instruments Incorporated PRODUCTION DATA information is current as of publication date. Products conform to specifications per the terms of Texas Instruments standard warranty. Production processing does not necessarily include testing of all parameters. www.ti.com ABSOLUTE MAXIMUM RATINGS ELECTROSTATIC DISCHARGE SENSITIVITY Analog Inputs: VIN ............................................................................. ±25V CAP ................................... +VANA +0.3V to AGND2 –0.3V REF .......................................... Indefinite Short to AGND2 Momentary Short to VANA Ground Voltage Differences: DGND, AGND1, AGND2 ................. ±0.3V VANA ....................................................................................................... 7V VDIG to VANA ..................................................................................... +0.3V VDIG ....................................................................................................... 7V Digital Inputs ........................................................... –0.3V to +VDIG +0.3V Maximum Junction Temperature ................................................... +165°C Internal Power Dissipation ............................................................. 825mW Lead Temperature (soldering, 10s) ............................................... +300°C This integrated circuit can be damaged by ESD. Texas Instruments recommends that all integrated circuits be handled with appropriate precautions. Failure to observe proper handling and installation procedures can cause damage. ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet its published specifications. PACKAGE/ORDERING INFORMATION PRODUCT MAXIMUM LINEARITY ERROR (LSB) MINIMUM SIGNAL-TO(NOISE+DISTORTION) RATIO (LSB) PACKAGE-LEAD (DESIGNATOR)(1) SPECIFIED TEMPERATURE RANGE PACKAGE MARKING ORDERING NUMBER TRANSPORT MEDIA, QUANTITY ADS7804P ±0.9 70 DIP-28 (NT) –40°C to +85°C ADS7804P ADS7804P Tube, 13 ADS7804PB ±0.45 72 DIP-28 (NT) –40°C to +85°C ADS7804PB ADS7804PB Tube, 13 ADS7804U ±0.9 70 SO-28 (DW) –40°C to +85°C ADS7804U " " " " " " ADS7804U ADS7804U/1K Tube, 28 Tape and Reel, 1000 ADS7804UB ±0.45 72 SO-28 (DW) –40°C to +85°C ADS7804UB " " " " " " ADS7804UB ADS7804UB/1K Tube, 28 Tape and Reel, 1000 NOTE: (1) For the most current specifications and package information, refer to our web site at www.ti.com. ELECTRICAL CHARACTERISTICS At TA = –40°C to +85°C, fS = 100kHz, and VDIG = VANA = +5V, using internal reference, unless otherwise specified. ADS7804P, U PARAMETER CONDITIONS MIN TYP RESOLUTION DC ACCURACY Integral Linearity Error Differential Linearity Error No Missing Codes Transition Noise(2) Full Scale Error(3,4) Full Scale Error Drift Full Scale Error(3,4) Full Scale Error Drift Bipolar Zero Error(3) Bipolar Zero Error Drift Power Supply Sensitivity (VDIG = VANA = VD) AC ACCURACY Spurious-Free Dynamic Range Total Harmonic Distortion Signal-to-(Noise+Distortion) Signal-to-Noise Full-Power Bandwidth(6) SAMPLING DYNAMICS Aperture Delay Aperture Jitter Transient Response Overvoltage Recovery(7) 2 MAX MIN TYP 12 ANALOG INPUT Voltage Ranges Impedance Capacitance THROUGHPUT SPEED Conversion Time Complete Cycle Throughput Rate ADS7804PB, UB ±10V 23 35 5.7 Acquire and Convert ✻ 8 10 ±7 ±2 ±2 +4.75V < VD < +5.25V FS Step Bits V kΩ pF ✻ ✻ µs µs kHz ±0.45 ±0.45 LSB(1) LSB Bits LSB % ppm/°C % ppm/°C mV ppm/°C LSB ✻ ✻ Ensured 0.1 45kHz 45kHz 45kHz 45kHz ✻ ✻ ±0.9 ±0.9 fIN = fIN = fIN = fIN = UNITS ✻ ✻ ✻ 100 Ext. 2.5000V Ref Ext. 2.5000V Ref MAX ±0.5 ±5 ±0.5 ±0.25 ±0.25 ✻ ±10 ±10 ✻ ±0.5 ✻ ✻ 80 ✻ –80 70 70 72 72 250 ✻ 40 Sufficient to meet AC specs 2 150 ✻ ns ✻ ✻ ✻ dB(5) dB dB dB kHz µs ns ADS7804 www.ti.com SBAS019A ELECTRICAL CHARACTERISTICS (Cont.) At TA = –40°C to +85°C, fS = 100kHz, and VDIG = VANA = +5V, using internal reference, unless otherwise specified. ADS7804P, U PARAMETER REFERENCE Internal Reference Voltage Internal Reference Source Current (Must use external buffer.) Internal Reference Drift External Reference Voltage Range for Specified Linearity External Reference Current Drain CONDITIONS Output Capacitance TYP 2.48 2.5 1 2.3 8 2.5 Ext. 2.5000V Ref DIGITAL INPUTS Logic Levels VIL VIH IIL IIH DIGITAL OUTPUTS Data Format Data Coding VOL VOH Leakage Current MIN Power Dissipation TEMPERATURE RANGE Specified Performance Derated Performance Storage Thermal Resistance (θJA) Plastic DIP SO MAX MIN TYP –0.3 +2.0 MAX UNITS V µA 2.52 ✻ ✻ ✻ ✻ 2.7 ✻ ✻ ✻ ppm/°C V ✻ µA ✻ ✻ ✻ ✻ V V µA µA ✻ 100 +0.8 VD +0.3V ±10 ±10 ✻ ✻ Parallel 12 Bits Binary Two’s Complement ISINK = 1.6mA ISOURCE = 500µA High-Z State, VOUT = 0V to VDIG High-Z State +0.4 Must be ≤ VANA ±5 ✻ V V µA 15 15 pF 83 83 ✻ ✻ ns ns ✻ ✻ V V mA mA ✻ mW ✻ ✻ ✻ °C °C °C ✻ +4 DIGITAL TIMING Bus Access Time Bus Relinquish Time POWER SUPPLIES Specified Performance VDIG VANA +IDIG +IANA ADS7804PB, UB +4.75 +4.75 +5 +5 0.3 16 fS = 100kHz +5.25 +5.25 ✻ ✻ ✻ ✻ ✻ ✻ 100 –40 –55 –65 +85 +125 +150 75 75 ✻ ✻ ✻ ✻ ✻ °C/W °C/W NOTES: (1) LSB means Least Significant Bit. For the 12-bit, ±10V input ADS7804, one LSB is 4.88mV. (2) Typical rms noise at worst case transitions and temperatures. (3) As measured with fixed resistors shown in Figure 4. Adjustable to zero with external potentiometer. (4) Full scale error is the worst case of –Full Scale or +Full Scale untrimmed deviation from ideal first and last code transitions, divided by the transition voltage (not divided by the full-scale range) and includes the effect of offset error. (5) All specifications in dB are referred to a full-scale ±10V input. (6) Full-Power Bandwidth defined as Full-Scale input frequency at which Signal-to-(Noise + Distortion) degrades to 60dB, or 10 bits of accuracy. (7) Recovers to specified performance after 2 x FS input overvoltage. ADS7804 SBAS019A www.ti.com 3 PIN CONFIGURATION VIN 1 28 VDIG AGND1 2 27 VANA REF 3 26 BUSY CAP 4 25 CS AGND2 5 24 R/C D11 (MSB) 6 23 BYTE D10 7 22 DZ ADS7804 DIGITAL I/O D9 8 21 DZ D8 9 20 DZ D7 10 19 DZ D6 11 18 D0 (LSB) D5 12 17 D1 D4 13 16 D2 DGND 14 15 D3 PIN # NAME 1 VIN DESCRIPTION 2 AGND1 3 REF Reference Input/Output. 2.2µF tantalum capacitor to ground. Reference Buffer Capacitor. 2.2µF tantalum capacitor to ground. Analog Input. See Figure 7. Analog Ground. Used internally as ground reference point. 4 CAP 5 AGND2 6 D11 (MSB) O Data Bit 11. Most Significant Bit (MSB) of conversion results. Hi-Z state when CS is HIGH, or when R/C is LOW. 7 D10 O Data Bit 10. Hi-Z state when CS is HIGH, or when R/C is LOW. 8 D9 O Data Bit 9. Hi-Z state when CS is HIGH, or when R/C is LOW. 9 D8 O Data Bit 8. Hi-Z state when CS is HIGH, or when R/C is LOW. 10 D7 O Data Bit 7. Hi-Z state when CS is HIGH, or when R/C is LOW. 11 D6 O Data Bit 6. Hi-Z state when CS is HIGH, or when R/C is LOW. 12 D5 O Data Bit 5. Hi-Z state when CS is HIGH, or when R/C is LOW. 13 D4 O Data Bit 4. Hi-Z state when CS is HIGH, or when R/C is LOW. 14 DGND 15 D3 O Data Bit 3. Hi-Z state when CS is HIGH, or when R/C is LOW. 16 D2 O Data Bit 2. Hi-Z state when CS is HIGH, or when R/C is LOW. 17 D1 O Data Bit 1. Hi-Z state when CS is HIGH, or when R/C is LOW. 18 D0 (LSB) O Data Bit 0. Lease Significant Bit (LSB) of conversion results. Hi-Z state when CS is HIGH, or when R/C is LOW. 19 DZ O LOW when CS LOW, R/C HIGH. Hi-Z state when CS is HIGH, or when R/C is LOW. 20 DZ O LOW when CS LOW, R/C HIGH. Hi-Z state when CS is HIGH, or when R/C is LOW. 21 DZ O LOW when CS LOW, R/C HIGH. Hi-Z state when CS is HIGH, or when R/C is LOW. 22 DZ O LOW when CS LOW, R/C HIGH. Hi-Z state when CS is HIGH, or when R/C is LOW. 23 BYTE I Selects 8 most significant bits (LOW) or 8 least significant bits (HIGH). 24 R/C I With CS LOW and BUSY HIGH, a Falling Edge on R/C Initiates a New Conversion. With CS LOW, a rising edge on R/C enables the parallel output. Analog Ground. Digital Ground. 25 CS I Internally OR’d with R/C. If R/C LOW, a falling edge on CS initiates a new conversion. 26 BUSY O At the start of a conversion, BUSY goes LOW and stays LOW until the conversion is completed and the digital outputs have been updated. 27 VANA Analog Supply Input. Nominally +5V. Decouple to ground with 0.1µF ceramic and 10µF tantalum capacitors. 28 VDIG Digital Supply Input. Nominally +5V. Connect directly to pin 27. Must be ≤ VANA. TABLE I. Pin Assignments. 4 ADS7804 www.ti.com SBAS019A BASIC OPERATION CS R/C BUSY 1 X X None. Databus is in Hi-Z state. ↓ 0 1 Initiates conversion ‘n’. Databus remains in Hi-Z state. 0 ↓ 1 Initiates conversion ‘n’. Databus enters Hi-Z state. 0 1 ↑ Conversion ‘n’ completed. Valid data from conversion ‘n’ on the databus. ↓ 1 1 Enables databus with valid data from conversion ‘n’. ↓ 1 0 Enables databus with valid data from conversion ‘n-1’(1). Conversion n in process. 0 ↑ 0 Enables databus with valid data from conversion ‘n-1’(1). Conversion ‘n’ in process. 0 0 ↑ New conversion initiated without acquisition of a new signal. Data will be invalid. CS and/or R/C must be HIGH when BUSY goes HIGH. X X 0 New convert commands ignored. Conversion ‘n’ in process. Figure 1 shows a basic circuit to operate the ADS7804 with a full parallel data output. Taking R/C (pin 24) LOW for a minimum of 40ns (6µs max) will initiate a conversion. BUSY (pin 26) will go LOW and stay LOW until the conversion is completed and the output registers are updated. Data will be output in Binary Two’s Complement with the MSB on pin 6. BUSY going HIGH can be used to latch the data. All convert commands will be ignored while BUSY is LOW. The ADS7804 will begin tracking the input signal at the end of the conversion. Allowing 10µs between convert commands assures accurate acquisition of a new signal. The offset and gain are adjusted internally to allow external trimming with a single supply. The external resistors compensate for this adjustment and can be left out if the offset and gain will be corrected in software (refer to the Calibration section). OPERATION NOTE: (1) See Figures 2 and 3 for constraints on data valid from conversion “n-1”. STARTING A CONVERSION The combination of CS (pin 25) and R/C (pin 24) LOW for a minimum of 40ns immediately puts the sample/hold of the ADS7804 in the hold state and starts conversion ‘n’. BUSY (pin 26) will go LOW and stay LOW until conversion ‘n’ is completed and the internal output register has been updated. All new convert commands during BUSY LOW will be ignored. CS and/or R/C must go HIGH before BUSY goes HIGH or a new conversion will be initiated without sufficient time to acquire a new signal. The ADS7804 will begin tracking the input signal at the end of the conversion. Allowing 10µs between convert commands assures accurate acquisition of a new signal. Refer to Table II for a summary of CS, R/C, and BUSY states and Figures 3 through 5 for timing diagrams. Table II. Control Line Functions for Read and Convert. CS and R/C are internally OR’d and level triggered. There is not a requirement which input goes LOW first when initiating a conversion. If, however, it is critical that CS or R/C initiates conversion ‘n’, be sure the less critical input is LOW at least 10ns prior to the initiating input. To reduce the number of control pins, CS can be tied LOW using R/C to control the read and convert modes. This will have no effect when using the internal data clock in the serial output mode. However, the parallel output will become active whenever R/C goes HIGH. Refer to the Reading Data section. 200Ω 33.2kΩ + 1 28 2 27 2.2µF 3 26 4 25 5 24 B11 (MSB) 6 23 B10 7 + 0.1µF + +5V 10µF BUSY 2.2µF + R/C 22 LOW ADS7804 B9 8 21 LOW B8 9 20 LOW B7 10 19 LOW B6 11 18 B0 (LSB) B5 12 17 B1 B4 13 16 B2 14 15 B3 Convert Pulse 40ns min 6µs max FIGURE 1. Basic Operation. ADS7804 SBAS019A www.ti.com 5 READING DATA PARALLEL OUTPUT (During a Conversion) The ADS7804 outputs full or byte-reading parallel data in Binary Two’s Complement data output format. The parallel output will be active when R/C (pin 24) is HIGH and CS (pin 25) is LOW. Any other combination of CS and R/C will tristate the parallel output. Valid conversion data can be read in a full parallel, 12-bit word or two 8-bit bytes on pins 6-13 and pins 15-22. BYTE (pin 23) can be toggled to read both bytes within one conversion cycle. Refer to Table III for ideal output codes and Figure 2 for bit locations relative to the state of BYTE. DIGITAL OUTPUT BINARY TWO’S COMPLEMENT DESCRIPTION ANALOG INPUT Full Scale Range ±10V Least Significant Bit (LSB) 4.88mV +Full Scale (10V – 1LSB) Midscale One LSB below Midscale –Full Scale BINARY CODE 9.99512V After conversion ‘n’ has been initiated, valid data from conversion ‘n-1’ can be read and will be valid up to 16µs after the start of conversion ‘n’. Do not attempt to read data from 16µs after the start of conversion ‘n’ until BUSY (pin 26) goes HIGH; this may result in reading invalid data. Refer to Table IV and Figures 3 and 5 for timing specifications. Note! For the best possible performance, data should not be read during a conversion. The switching noise of the asynchronous data transfer can cause digital feedthrough degrading the converter’s performance. The number of control lines can be reduced by tieing CS LOW while using R/C to initiate conversions and activate the output mode of the converter. See Figure 3. HEX CODE 0111 1111 1111 SYMBOL DESCRIPTION t1 Convert Pulse Width MIN TYP MAX UNITS 6000 ns 7FF t2 Data Valid Delay after R/C LOW 8 µs BUSY Delay from R/C LOW BUSY LOW 65 8 ns µs 40 0V 0000 0000 0000 000 t3 t4 –4.88mV 1111 1111 1111 FFF t5 BUSY Delay after End of Conversion 220 ns –10V 1000 0000 0000 800 t6 Aperture Delay 40 ns 7.6 Table III. Ideal Input Voltages and Output Codes. PARALLEL OUTPUT (After a Conversion) After conversion ‘n’ is completed and the output registers have been updated, BUSY (pin 26) will go HIGH. Valid data from conversion ‘n’ will be available on D11-D0 (pin 6-13 and 15-18 when BYTE is LOW). BUSY going HIGH can be used to latch the data. Refer to Table IV and Figures 3 and 5 for timing specifications. 8 µs 2 µs 83 ns t7 Conversion Time t8 Acquisition Time t9 Bus Relinquish Time 10 35 t10 BUSY Delay after Data Valid 50 200 ns t11 Previous Data Valid after R/C LOW 7.4 µs t7 + t6 Throughput Time t12 R/C to CS Setup Time 10 t13 Time Between Conversions 10 t14 Bus Access Time and BYTE Delay 10 9 10 µs ns µs 83 ns TABLE IV. Conversion Timing. BYTE LOW BYTE HIGH +5V Bit 11 (MSB) 6 Bit 10 7 23 Bit 3 6 22 LOW Bit 2 7 ADS7804 23 22 Bit 4 ADS7804 Bit 9 8 21 LOW Bit 1 8 21 Bit 5 Bit 8 9 20 LOW Bit 0 (LSB) 9 20 Bit 6 Bit 7 10 19 LOW LOW 10 19 Bit 7 Bit 6 11 18 Bit 0 (LSB) LOW 11 18 Bit 8 Bit 5 12 17 Bit 1 LOW 12 17 Bit 9 Bit 4 13 16 Bit 2 LOW 13 16 Bit 10 14 15 Bit 3 14 15 Bit 11 FIGURE 2. Bit Locations Relative to State of BYTE (pin 23). 6 ADS7804 www.ti.com SBAS019A t1 R/C t13 t2 t4 BUSY t3 t6 t5 Convert Acquire MODE Acquire t7 DATA BUS Previous Data Valid t8 Previous Data Valid Hi-Z t9 Convert Not Valid Data Valid Hi-Z Data Valid t10 t11 FIGURE 3. Conversion Timing with Outputs Enabled after Conversion (CS Tied LOW.) t12 t12 t12 t12 R/C t1 CS t3 t4 BUSY t6 MODE Convert Acquire Acquire t7 Hi-Z State DATA BUS Data Valid Hi-Z State t9 t14 FIGURE 4. Using CS to Control Conversion and Read Timing. t12 t12 R/C CS BYTE Pins 6 - 13 Hi-Z High Byte t14 Pins 15 - 22 Hi-Z Low Byte Low Byte t14 High Byte Hi-Z t9 Hi-Z FIGURE 5. Using CS and BYTE to Control Data Bus. ADS7804 SBAS019A www.ti.com 7 INPUT RANGES HARDWARE CALIBRATION The ADS7804 offers a standard ±10V input range. Figure 6 shows the necessary circuit connections for the ADS7804 with and without hardware trim. Offset and full scale error(1) specifications are tested and guaranteed with the fixed resistors shown in Figure 6b. Adjustments for offset and gain are described in the Calibration section of this data sheet. To calibrate the offset and gain of the ADS7804, install the proper resistors and potentiometers as shown in Figure 6a. The calibration range is ±15mV for the offset and ±60mV for the gain. The offset and gain are adjusted internally to allow external trimming with a single supply. The external resistors compensate for this adjustment and can be left out if the offset and gain will be corrected in software (refer to the Calibration section). The nominal input impedance of 23kW results from the combination of the internal resistor network shown on the front page of the product data sheet and the external resistors. The input resistor divider network provides inherent overvoltage protection guaranteed to at least ±25V. The 1% resistors used for the external circuitry do not compromise the accuracy or drift of the converter. They have little influence relative to the internal resistors, and tighter tolerances are not required. SOFTWARE CALIBRATION To calibrate the offset and gain of the ADS7804 in software, no external resistors are required. See the No Calibration section for details on the effects of the external resistors. Refer to Table V for range of offset and gain errors with and without external resistors. NO CALIBRATION See Figure 6b for circuit connections. The external resistors shown in Figure 6b may not be necessary in some applications. These resistors provide compensation for an internal adjustment of the offset and gain which allows calibration with a single supply. The nominal transfer function of the ADS7804 will be bound by the shaded region seen in Figure 7 with a typical offset of –30mV and a typical gain error of –1.5%. Refer to Table V for range of offset and gain errors with and without external resistors. NOTE: (1) Full scale error includes offset and gain errors measured at both +FS and –FS. CALIBRATION The ADS7804 can be trimmed in hardware or software. The offset should be trimmed before the gain since the offset directly affects the gain. To achieve optimum performance, several iterations may be required. WITH EXTERNAL RESISTORS WITHOUT EXTERNAL RESISTORS UNITS BPZ –10 < BPZ < 10 –2 < BPZ < 2 –45 < BPZ < 5 –8 < BPZ < 1 mV LSBs Gain Error –0.5 < error < 0.5 –0.25 < error < 0.25(1) –0.6 < error < –0.55 –0.45 < error < –0.3(1) % of FSR NOTE: (1) High Grade. TABLE VII. Bipolar Offset and Gain Errors With and Without External Resistors. ±10V With Hardware a) ±10V Without Hardware b) Trim Trim 200Ω 1 ±10V 2 33.2kΩ +5V 2.2µF 50kΩ Offset 50kΩ + 3 200Ω 1 ±10V VIN 2 AGND1 33.2kΩ 2.2µF + REF 3 VIN AGND1 REF 576kΩ 4 Gain 2.2µF 4 CAP + 2.2µF 5 5 AGND2 CAP + AGND2 NOTE: Use 1% metal film resistors. FIGURE 6. Circuit Diagram With and Without External Resistors. 8 ADS7804 www.ti.com SBAS019A Digital Output 7FF –10V –9.99983V –9.9998V –50mV 9.9997V –15mV 9.999815V +10V Analog Input Ideal Transfer Function With External Resistors Range of Transfer Function Without External Resistors 800 FIGURE 7. Full Scale Transfer Function. REFERENCE The ADS7804 can operate with its internal 2.5V reference or an external reference. By applying an external reference to pin 5, the internal reference can be bypassed. The reference voltage at REF is buffered internally with the output on CAP (pin 4). The internal reference has an 8 ppm/°C drift (typical) and accounts for approximately 20% of the full scale error (FSE = ±0.5% for low grade, ±0.25% for high grade). REF REF (pin 3) is an input for an external reference or the output for the internal 2.5V reference. A 2.2µF capacitor should be connected as close to the REF pin as possible. The capacitor and the output resistance of REF create a low pass filter to bandlimit noise on the reference. Using a smaller value capacitor will introduce more noise to the reference degrading the SNR and SINAD. The REF pin should not be used to drive external AC or DC loads. The range for the external reference is 2.3V to 2.7V and determines the actual LSB size. Increasing the reference voltage will increase the full scale range and the LSB size of the converter which can improve the SNR. CAP CAP (pin 4) is the output of the internal reference buffer. A 2.2µF capacitor should be placed as close to the CAP pin as possible to provide optimum switching currents for the CDAC throughout the conversion cycle and compensation for the output of the internal buffer. Using a capacitor any smaller than 1µF can cause the output buffer to oscillate and may not have sufficient charge for the CDAC. Capacitor values larger than 2.2µF will have little affect on improving performance. The output of the buffer is capable of driving up to 2mA of current to a DC load. DC loads requiring more than 2mA of current from the CAP pin will begin to degrade the linearity of the ADS7804. Using an external buffer will allow the internal reference to be used for larger DC loads and AC loads. Do not attempt to directly drive an AC load with the output voltage on CAP. This will cause performance degradation of the converter. ADS7804 SBAS019A www.ti.com 9 LAYOUT SIGNAL CONDITIONING POWER For optimum performance, tie the analog and digital power pins to the same +5V power supply and tie the analog and digital grounds together. As noted in the electrical specifications, the ADS7804 uses 90% of its power for the analog circuitry. The ADS7804 should be considered as an analog component. The +5V power for the A/D should be separate from the +5V used for the system’s digital logic. Connecting VDIG (pin 28) directly to a digital supply can reduce converter performance due to switching noise from the digital logic. For best performance, the +5V supply can be produced from whatever analog supply is used for the rest of the analog signal conditioning. If +12V or +15V supplies are present, a simple +5V regulator can be used. Although it is not suggested, if the digital supply must be used to power the converter, be sure to properly filter the supply. Either using a filtered digital supply or a regulated analog supply, both VDIG and VANA should be tied to the same +5V source. GROUNDING Three ground pins are present on the ADS7804. DGND is the digital supply ground. AGND2 is the analog supply ground. AGND1 is the ground which all analog signals internal to the A/D are referenced. AGND1 is more susceptible to current induced voltage drops and must have the path of least resistance back to the power supply. All the ground pins of the A/D should be tied to the analog ground plane, separated from the system’s digital logic ground, to achieve optimum performance. Both analog and digital ground planes should be tied to the “system” ground as near to the power supplies as possible. This helps to prevent dynamic digital ground currents from modulating the analog ground through a common impedance to power ground. 10 The FET switches used for the sample hold on many CMOS A/D converters release a significant amount of charge injection which can cause the driving op amp to oscillate. The FET switch on the ADS7804, compared to the FET switches on other CMOS A/D converters, releases 5%-10% of the charge. There is also a resistive front end which attenuates any charge which is released. The end result is a minimal requirement for the anti-alias filter on the front end. Any op amp sufficient for the signal in an application will be sufficient to drive the ADS7804. The resistive front end of the ADS7804 also provides a guaranteed ±25V overvoltage protection. In most cases, this eliminates the need for external input protection circuitry. INTERMEDIATE LATCHES The ADS7804 does have tri-state outputs for the parallel port, but intermediate latches should be used if the bus will be active during conversions. If the bus is not active during conversion, the tri-state outputs can be used to isolate the A/D from other peripherals on the same bus. Tri-state outputs can also be used when the A/D is the only peripheral on the data bus. Intermediate latches are beneficial on any monolithic A/D converter. The ADS7804 has an internal LSB size of 610µV. Transients from fast switching signals on the parallel port, even when the A/D is tri-stated, can be coupled through the substrate to the analog circuitry causing degradation of converter performance. The effects of this phenomenon will be more obvious when using the pin-compatible ADS7805 or any of the other 16-bit converters in the ADS Family. This is due to the smaller internal LSB size of 38µV. ADS7804 www.ti.com SBAS019A PACKAGE DRAWINGS NT (R-PDIP-T**) PLASTIC DUAL-IN-LINE PACKAGE 24 PINS SHOWN PINS ** A 24 28 A MAX 1.260 (32,04) 1.425 (36,20) A MIN 1.230 (31,24) 1.385 (35,18) B MAX 0.310 (7,87) 0.315 (8,00) B MIN 0.290 (7,37) 0.295 (7,49) DIM 24 13 0.280 (7,11) 0.250 (6,35) 1 12 0.070 (1,78) MAX B 0.020 (0,51) MIN 0.200 (5,08) MAX Seating Plane 0.125 (3,18) MIN 0.100 (2,54) 0.021 (0,53) 0.015 (0,38) 0°– 15° 0.010 (0,25) M 0.010 (0,25) NOM 4040050 / B 04/95 NOTES: A. All linear dimensions are in inches (millimeters). B. This drawing is subject to change without notice. ADS7804 SBAS019A www.ti.com 11 PACKAGE DRAWINGS (Cont.) DW (R-PDSO-G**) PLASTIC SMALL-OUTLINE PACKAGE 16 PINS SHOWN 0.050 (1,27) 0.020 (0,51) 0.014 (0,35) 16 0.010 (0,25) M 9 0.419 (10,65) 0.400 (10,15) 0.010 (0,25) NOM 0.299 (7,59) 0.291 (7,39) Gage Plane 0.010 (0,25) 1 8 0° – 8° A 0.050 (1,27) 0.016 (0,40) Seating Plane 0.104 (2,65) MAX 0.012 (0,30) 0.004 (0,10) PINS ** 0.004 (0,10) 16 18 20 24 28 A MAX 0.410 (10,41) 0.462 (11,73) 0.510 (12,95) 0.610 (15,49) 0.710 (18,03) A MIN 0.400 (10,16) 0.453 (11,51) 0.500 (12,70) 0.600 (15,24) 0.700 (17,78) DIM 4040000 / E 08/01 NOTES: A. B. C. D. 12 All linear dimensions are in inches (millimeters). This drawing is subject to change without notice. Body dimensions do not include mold flash or protrusion not to exceed 0.006 (0,15). Falls within JEDEC MS-013 ADS7804 www.ti.com SBAS019A PACKAGE OPTION ADDENDUM www.ti.com 1-Dec-2023 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan (2) Lead finish/ Ball material MSL Peak Temp Op Temp (°C) Device Marking (3) (4/5) (6) ADS7804U LIFEBUY SOIC DW 28 20 RoHS & Green NIPDAU Level-3-260C-168 HR -40 to 85 ADS7804U B ADS7804U/1K LIFEBUY SOIC DW 28 1000 RoHS & Green Call TI Level-3-260C-168 HR -40 to 85 ADS7804U B ADS7804UB LIFEBUY SOIC DW 28 20 RoHS & Green Call TI Level-3-260C-168 HR -40 to 85 ADS7804U B ADS7804UG4 LIFEBUY SOIC DW 28 20 RoHS & Green NIPDAU Level-3-260C-168 HR -40 to 85 ADS7804U B (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
ADS7804UE4 价格&库存
很抱歉,暂时无法提供与“ADS7804UE4”相匹配的价格&库存,您可以联系我们找货
