SN74ALVCH16373KR
SN74ALVCH16373KR
    ROCHESTER(罗切斯特)
    56-VFBGA
    BUS DRIVER
SN74ALVCH16373KR 数据手册
SN74ALVCH16373 16-BIT TRANSPARENT D-TYPE LATCH WITH 3-STATE OUTPUTS www.ti.com FEATURES • • • • • • • Member of the Texas Instruments Widebus™ Family Operates From 1.65 V to 3.6 V Max tpd of 3.6 ns at 3.3 V ±24-mA Output Drive at 3.3 V Bus Hold on Data Inputs Eliminates the Need for External Pullup/Pulldown Resistors Latch-Up Performance Exceeds 250 mA Per JESD 17 ESD Protection Exceeds JESD 22 – 2000-V Human-Body Model (A114-A) – 200-V Machine Model (A115-A) XXXX DESCRIPTION/ORDERING INFORMATION This 16-bit transparent D-type latch is designed for 1.65-V to 3.6-V VCC operation. The SN74ALVCH16373 is particularly suitable for implementing buffer registers, I/O ports, bidirectional bus drivers, and working registers. This device can be used as two 8-bit latches or one 16-bit latch. When the latch-enable (LE) input is high, the Q outputs follow the data (D) inputs. When LE is taken low, the Q outputs are latched at the levels set up at the D inputs. SCES020I – JULY 1995 – REVISED NOVEMBER 2005 DGG OR DL PACKAGE (TOP VIEW) 1OE 1Q1 1Q2 GND 1Q3 1Q4 VCC 1Q5 1Q6 GND 1Q7 1Q8 2Q1 2Q2 GND 2Q3 2Q4 VCC 2Q5 2Q6 GND 2Q7 2Q8 2OE 1 48 2 47 3 46 4 45 5 44 6 43 7 42 8 41 9 40 10 39 11 38 12 37 13 36 14 35 15 34 16 33 17 32 18 31 19 30 20 29 21 28 22 27 23 26 24 25 1LE 1D1 1D2 GND 1D3 1D4 VCC 1D5 1D6 GND 1D7 1D8 2D1 2D2 GND 2D3 2D4 VCC 2D5 2D6 GND 2D7 2D8 2LE A buffered output-enable (OE) input can be used to place the eight outputs in either a normal logic state (high or low logic levels) or the high-impedance state. In the high-impedance state, the outputs neither load nor drive the buslines significantly. The high-impedance state and the increased drive provide the capability to drive bus lines without need for interface or pullup components. OE does not affect internal operations of the latch. Old data can be retained or new data can be entered while the outputs are in the high-impedance state. To ensure the high-impedance state during power up or power down, OE should be tied to VCC through a pullup resistor; the minimum value of the resistor is determined by the current-sinking capability of the driver. Active bus-hold circuitry holds unused or undriven inputs at a valid logic state. Use of pullup or pulldown resistors with the bus-hold circuitry is not recommended. Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet. Widebus is a trademark of Texas Instruments. PRODUCTION DATA information is current as of publication date. Products conform to specifications per the terms of the Texas Instruments standard warranty. Production processing does not necessarily include testing of all parameters. Copyright © 1995–2005, Texas Instruments Incorporated SN74ALVCH16373 16-BIT TRANSPARENT D-TYPE LATCH WITH 3-STATE OUTPUTS www.ti.com SCES020I – JULY 1995 – REVISED NOVEMBER 2005 ORDERING INFORMATION PACKAGE (1) TA FBGA – GRD FBGA – ZRD (Pb-free) ORDERABLE PART NUMBER SN74ALVCH16373GRDR Tape and reel SSOP – DL VH373 SN74ALVCH16373ZRDR Tube TOP-SIDE MARKING SN74ALVCH16373DL SN74ALVCH16373DLR Tape and reel ALVCH16373 74ALVCH16373DLG4 –40°C to 85°C 74ALVCH16373DLRG4 SN74ALVCH16373DGGR TSSOP – DGG Tape and reel 74ALVCH16373DGGE4 ALVCH16373 74ALVCH16373DGGRG4 VFBGA – GQL VFBGA – ZQL (Pb-free) (1) SN74ALVCH16373KR Tape and reel VH373 74ALVCH16373ZQLR Package drawings, standard packing quantities, thermal data, symbolization, and PCB design guidelines are available at www.ti.com/sc/package. GQL OR ZQL PACKAGE (TOP VIEW) TERMINAL ASSIGNMENTS (1) (56-Ball GQL/ZQL Package) 1 2 3 4 5 6 A B C D E F G H J K 1 2 3 4 5 6 A 1OE NC NC NC NC 1LE B 1Q2 1Q1 GND GND 1D1 1D2 C 1Q4 1Q3 VCC VCC 1D3 1D4 D 1Q6 1Q5 GND GND 1D5 1D6 E 1Q8 1Q7 1D7 1D8 F 2Q1 2Q2 2D2 2D1 G 2Q3 2Q4 GND GND 2D4 2D3 H 2Q5 2Q6 VCC VCC 2D6 2D5 J 2Q7 2Q8 GND GND 2D8 2D7 K 2OE NC NC NC NC 2LE abc (1) abc NC – No internal connection GRD OR ZRD PACKAGE (TOP VIEW) 1 2 3 4 5 6 TERMINAL ASSIGNMENTS (1) (54-Ball GRD/ZRD Package) 1 2 3 4 5 6 A 1Q1 NC 1OE 1LE NC 1D1 B 1Q3 1Q2 NC NC 1D2 1D3 C 1Q5 1Q4 VCC VCC 1D4 1D5 D 1Q7 1Q6 GND GND 1D6 1D7 D E 2Q1 1Q8 GND GND 1D8 2D1 E F 2Q3 2Q2 GND GND 2D2 2D3 G 2Q5 2Q4 VCC VCC 2D4 2D5 H 2Q7 2Q6 NC NC 2D6 2D7 J 2Q8 NC 2OE 2LE NC 2D8 A B C F G H J (1) NC – No internal connection xxxxx 2 SN74ALVCH16373 16-BIT TRANSPARENT D-TYPE LATCH WITH 3-STATE OUTPUTS www.ti.com SCES020I – JULY 1995 – REVISED NOVEMBER 2005 FUNCTION TABLE (EACH 8-BIT SECTION) INPUTS OE LE D OUTPUT Q L H H H L H L L L L X Q0 H X X Z LOGIC DIAGRAM (POSITIVE LOGIC) 1OE 1LE 1D1 1 2OE 48 2LE C1 47 1D 2 1Q1 24 25 C1 2D1 36 To Seven Other Channels 13 1D 2Q1 To Seven Other Channels Pin numbers shown are for the DGG and DL packages. Absolute Maximum Ratings (1) over operating free-air temperature range (unless otherwise noted) VCC Supply voltage range range (2) (3) VI Input voltage VO Output voltage range (2) (3) IIK Input clamp current VI < 0 IOK Output clamp current VO < 0 IO Continuous output current MIN MAX –0.5 4.6 V –0.5 VCC + 0.5 V –0.5 VCC + 0.5 Continuous current through each VCC or GND θJA Tstg (1) (2) (3) (4) Package thermal impedance (4) Storage temperature range V -50 mA -50 mA ±50 mA ±100 mA DGG package 70 DL package 63 GQL/ZQL package 42 GRD/ZRD package 36 –65 UNIT 150 °C/W °C Stresses beyond those listed under "absolute maximum ratings" may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under "recommended operating conditions" is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. The input negative-voltage and output voltage ratings may be exceeded if the input and output current ratings are observed. This value is limited to 4.6 V maximum. The package thermal impedance is calculated in accordance with JESD 51-7. 3 SN74ALVCH16373 16-BIT TRANSPARENT D-TYPE LATCH WITH 3-STATE OUTPUTS www.ti.com SCES020I – JULY 1995 – REVISED NOVEMBER 2005 Recommended Operating Conditions (1) VCC Supply voltage VIH High-level input voltage VCC = 1.65 V to 1.95 V MIN MAX 1.65 3.6 Low-level input voltage VI Input voltage VO Output voltage IOH High-level output current IOL Low-level output current ∆t/∆v Input transition rise or fall rate TA Operating free-air temperature (1) 4 V 0.65 × VCC VCC = 2.3 V to 2.7 V 1.7 VCC = 2.7 V to 3.6 V 2 V 0.35 × VCC VCC = 1.65 V to 1.95 V VIL UNIT VCC = 2.3 V to 2.7 V 0.7 VCC = 2.7 V to 3.6 V 0.8 V 0 VCC V 0 VCC V VCC = 1.65 V –4 VCC = 2.3 V –12 VCC = 2.7 V –12 VCC = 3 V –24 VCC = 1.65 V 4 VCC = 2.3 V 12 VCC = 2.7 V 12 VCC = 3 V 24 –40 mA mA 10 ns/V 85 °C All unused control inputs of the device must be held at VCC or GND to ensure proper device operation. Refer to the TI application report, Implications of Slow or Floating CMOS Inputs, literature number SCBA004. SN74ALVCH16373 16-BIT TRANSPARENT D-TYPE LATCH WITH 3-STATE OUTPUTS www.ti.com SCES020I – JULY 1995 – REVISED NOVEMBER 2005 Electrical Characteristics over recommended operating free-air temperature range (unless otherwise noted) PARAMETER TEST CONDITIONS IOH = –100 µA 1.65 V to 3.6 V 1.65 V IOH = –6 mA 2.3 V 2 2.3 V 1.7 2.7 V 2.2 IOH = –12 mA II(hold) V 3V 2.4 3V 2 IOL = 100 µA 1.65 V to 3.6 V 0.2 IOL = 4 mA 1.65 V 0.45 IOL = 6 mA 2.3 V 0.4 2.3 V 0.7 2.7 V 0.4 3V 0.55 IOL = 24 mA UNIT 1.2 IOH = –24 mA IOL = 12 mA II MAX VCC – 0.2 IOH = –4 mA VOH VOL MIN TYP (1) VCC V ±5 VI = VCC or GND 3.6 V VI = 0.58 V 1.65 V 25 VI = 1.07 V 1.65 V –25 VI = 0.7 V 2.3 V 45 VI = 1.7 V 2.3 V –45 VI = 0.8 V 3V 75 VI = 2 V 3V –75 µA µA VI = 0 to 3.6 V (2) 3.6 V ±500 IOZ VO = VCC or GND 3.6 V ±10 µA ICC VI = VCC or GND IO = 0 3.6 V 40 µA ∆ICC One input at VCC – 0.6 V, Other inputs at VCC or GND 3 V to 3.6 V 750 µA Ci Co (1) (2) Control inputs Data inputs Outputs VI = VCC or GND 3.3 V VO = VCC or GND 3.3 V 3 pF 6 7 pF All typical values are at VCC = 3.3 V, TA = 25°C. This is the bus-hold maximum dynamic current. It is the minimum overdrive current required to switch the input from one state to another. Timing Requirements over recommended operating free-air temperature range (unless otherwise noted) (see Figure 1) VCC = 1.8 V MIN Pulse duration, LE high or low (1) tsu Setup time, data before LE↓ (1) th Hold time, data after LE↓ (1) tw (1) MAX VCC = 2.5 V ± 0.2 V MIN 3.3 MAX VCC = 2.7 V MIN MAX VCC = 3.3 V ± 0.3 V MIN UNIT MAX 3.3 3.3 ns 1 1 1.1 ns 1.5 1.7 1.4 ns This information was not available at the time of publication. 5 SN74ALVCH16373 16-BIT TRANSPARENT D-TYPE LATCH WITH 3-STATE OUTPUTS www.ti.com SCES020I – JULY 1995 – REVISED NOVEMBER 2005 Switching Characteristics over recommended operating free-air temperature range (unless otherwise noted) (see Figure 1) FROM (INPUT) PARAMETER D tpd LE ten OE tdis (1) VCC = 1.8 V TO (OUTPUT) OE TYP VCC = 2.5 V ± 0.2 V VCC = 2.7 V MIN MAX (1) 1 (1) 1 Q (1) Q (1) Q MIN VCC = 3.3 V ± 0.3 V UNIT MAX MIN MAX 4.5 4.3 1.1 3.6 4.9 4.6 1 3.9 1 6 5.7 1 4.7 ns 1.2 5.1 4.5 1.4 4.1 ns ns This information was not available at the time of publication. Operating Characteristics TA = 25°C PARAMETER Cpd (1) 6 Power dissipation capacitance Outputs enabled Outputs disabled TEST CONDITIONS CL = 50 pF, This information was not available at the time of publication. f = 10 MHz VCC = 1.8 V VCC = 2.5 V VCC = 3.3 V TYP TYP TYP (1) 19 22 (1) 4 5 UNIT pF SN74ALVCH16373 16-BIT TRANSPARENT D-TYPE LATCH WITH 3-STATE OUTPUTS www.ti.com SCES020I – JULY 1995 – REVISED NOVEMBER 2005 PARAMETER MEASUREMENT INFORMATION VLOAD S1 RL From Output Under Test Open GND CL (see Note A) RL TEST S1 tpd tPLZ/tPZL tPHZ/tPZH Open VLOAD GND LOAD CIRCUIT INPUT VCC 1.8 V 2.5 V ± 0.2 V 2.7 V 3.3 V ± 0.3 V VI tr/tf VCC VCC 2.7 V 2.7 V ≤2 ns ≤2 ns ≤2.5 ns ≤2.5 ns VM VLOAD CL RL V∆ VCC/2 VCC/2 1.5 V 1.5 V 2 × VCC 2 × VCC 6V 6V 30 pF 30 pF 50 pF 50 pF 1 kΩ 500 Ω 500 Ω 500 Ω 0.15 V 0.15 V 0.3 V 0.3 V tw VI Timing Input VM VM VM 0V VOLTAGE WAVEFORMS SETUP AND HOLD TIMES VM VM 0V tPLH Output Control (low-level enabling) tPLZ VLOAD/2 VM tPZH VOH VM VOL VOLTAGE WAVEFORMS PROPAGATION DELAY TIMES VM 0V Output Waveform 1 S1 at VLOAD (see Note B) tPHL VM VI VM tPZL VI Input VOLTAGE WAVEFORMS PULSE DURATION th VI Data Input VM 0V 0V tsu Output VI VM Input Output Waveform 2 S1 at GND (see Note B) VOL + V∆ VOL tPHZ VOH VM VOH − V∆ 0V VOLTAGE WAVEFORMS ENABLE AND DISABLE TIMES NOTES: A. CL includes probe and jig capacitance. B. Waveform 1 is for an output with internal conditions such that the output is low, except when disabled by the output control. Waveform 2 is for an output with internal conditions such that the output is high, except when disabled by the output control. C. All input pulses are supplied by generators having the following characteristics: PRR ≤ 10 MHz, ZO = 50 Ω. D. The outputs are measured one at a time, with one transition per measurement. E. tPLZ and tPHZ are the same as tdis. F. tPZL and tPZH are the same as ten. G. tPLH and tPHL are the same as tpd. H. All parameters and waveforms are not applicable to all devices. Figure 1. Load Circuit and Voltage Waveforms 7 PACKAGE OPTION ADDENDUM www.ti.com 15-Jan-2021 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan (2) Lead finish/ Ball material MSL Peak Temp Op Temp (°C) (3) Device Marking (4/5) (6) 74ALVCH16373DGGRG4 ACTIVE TSSOP DGG 48 2000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 ALVCH16373 SN74ALVCH16373DGGR ACTIVE TSSOP DGG 48 2000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 ALVCH16373 SN74ALVCH16373DL ACTIVE SSOP DL 48 25 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 ALVCH16373 SN74ALVCH16373DLR ACTIVE SSOP DL 48 1000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 ALVCH16373 (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
SN74ALVCH16373KR 价格&库存
很抱歉,暂时无法提供与“SN74ALVCH16373KR”相匹配的价格&库存,您可以联系我们找货
