SN74AHCT16245DLG4
SN74AHCT16245DLG4
    ROCHESTER(罗切斯特)
    BSSOP48
    BUS TRANSCEIVER
SN74AHCT16245DLG4 数据手册
Sample & Buy Product Folder Support & Community Tools & Software Technical Documents SN74AHCT16245 SCLS335K – MARCH 1996 – REVISED OCTOBER 2014 SN74AHCT16245 16-Bit Bus Transceivers With 3-State Outputs 1 Features 3 Description • The SN74AHCT16245 device is a 16-bit (dual-octal) noninverting 3-state transceiver designed for synchronous two-way communication between data buses. 1 • • • • Members of Texas Instruments’ Widebus™ Family Inputs are TTL-Voltage Compatible Distributed VCC and GND Pins Minimize High-Speed Switching Noise Flow-Through Architecture Optimizes PCB Layout Latch-Up Performance Exceeds 250 mA Per JESD 17 2 Applications • • • • • Device Information(1) PART NUMBER SN74AHCT16245 PACKAGE BODY SIZE (NOM) TVSOP (48) 9.70 mm × 4.40 mm SSOP (48) 15.80 mm × 7.50 mm TSSOP (48) 12.50 mm × 6.10 mm (1) For all available packages, see the orderable addendum at the end of the data sheet. Telecom and Wireless Infrastructures Electronic Points of Sale Printers and Other Peripherals Motor Drives Health and Fitness 4 Simplified Schematic 1OE 1DIR G3 3 EN1 [BA] 3 EN2 [AB] 2OE 2DIR G6 6 EN4 [BA] 6 EN5 [AB] 1A1 1B1 1 2 1A2 1B2 1A3 1B3 1A4 1B4 1A5 1B5 1A6 1B6 1A7 1B7 1A8 2A1 1B8 2B1 4 5 2A2 2B2 2A3 2B3 2A4 2B4 2A5 2B5 2A6 2B6 2A7 2B7 2A8 2B8 † This symbol is in accordance with ANSI/IEEE Std 91-1984 and IEC Publication 617-12. 1 An IMPORTANT NOTICE at the end of this data sheet addresses availability, warranty, changes, use in safety-critical applications, intellectual property matters and other important disclaimers. PRODUCTION DATA. SN74AHCT16245 SCLS335K – MARCH 1996 – REVISED OCTOBER 2014 www.ti.com Table of Contents 1 2 3 4 5 6 7 8 Features .................................................................. Applications ........................................................... Description ............................................................. Simplified Schematic............................................. Revision History..................................................... Pin Configuration and Functions ......................... Specifications......................................................... 1 1 1 1 2 3 5 7.1 7.2 7.3 7.4 7.5 7.6 7.7 7.8 7.9 5 5 5 6 6 7 7 7 7 Absolute Maximum Ratings ...................................... Handling Ratings....................................................... Recommended Operating Conditions....................... Thermal Information .................................................. Electrical Characteristics........................................... Switching Characteristics .......................................... Noise Characteristics ................................................ Operating Characteristics.......................................... Typical Characteristics .............................................. Parameter Measurement Information .................. 8 9 Detailed Description .............................................. 9 9.1 9.2 9.3 9.4 Overview ................................................................... 9 Functional Block Diagrams ....................................... 9 Feature Description................................................. 10 Device Functional Modes........................................ 10 10 Application and Implementation........................ 11 10.1 Application Information.......................................... 11 10.2 Typical Application ............................................... 11 11 Power Supply Recommendations ..................... 12 12 Layout................................................................... 12 12.1 Layout Guidelines ................................................. 12 12.2 Layout Example .................................................... 12 13 Device and Documentation Support ................. 13 13.1 Trademarks ........................................................... 13 13.2 Electrostatic Discharge Caution ............................ 13 13.3 Glossary ................................................................ 13 14 Mechanical, Packaging, and Orderable Information ........................................................... 13 5 Revision History Changes from Revision J (October 2000) to Revision K Page • Updated document to new TI data sheet format. ................................................................................................................... 1 • Deleted Ordering Information table. ....................................................................................................................................... 1 • Deleted SN54AHCT16245 device from data sheet................................................................................................................ 1 • Added Applications. ................................................................................................................................................................ 1 • Added Pin Functions table...................................................................................................................................................... 3 • Added Handling Ratings table. ............................................................................................................................................... 5 • Changed MAX operating temperature to 125°C in Recommended Operating Conditions table. ......................................... 5 • Added Thermal Information table. .......................................................................................................................................... 6 • Added –40°C to 125°C range for SN74AHCT16245 in Electrical Characteristics table. ....................................................... 6 • Added TA = –40°C to 125°C for SN74AHCT16245 in the Switching Characteristics table.................................................... 7 • Added Typical Characteristics. ............................................................................................................................................... 7 • Added Detailed Description section........................................................................................................................................ 9 • Added Application and Implementation section.................................................................................................................... 11 • Added Power Supply Recommendations and Layout sections............................................................................................ 12 2 Submit Documentation Feedback Copyright © 1996–2014, Texas Instruments Incorporated Product Folder Links: SN74AHCT16245 SN74AHCT16245 www.ti.com SCLS335K – MARCH 1996 – REVISED OCTOBER 2014 6 Pin Configuration and Functions SN74AHCT16245 . . . DGG, DGV, OR DL PACKAGE (TOP VIEW) 1DIR 1B1 1B2 GND 1B3 1B4 VCC 1B5 1B6 GND 1B7 1B8 2B1 2B2 GND 2B3 2B4 VCC 2B5 2B6 GND 2B7 2B8 2DIR 1 48 2 47 3 46 4 45 5 44 6 43 7 42 8 41 9 40 10 39 11 38 12 37 13 36 14 35 15 34 16 33 17 32 18 31 19 30 20 29 21 28 22 27 23 26 24 25 1OE 1A1 1A2 GND 1A3 1A4 VCC 1A5 1A6 GND 1A7 1A8 2A1 2A2 GND 2A3 2A4 VCC 2A5 2A6 GND 2A7 2A8 2OE Pin Functions PIN I/O DESCRIPTION 1DIR I Direction pin 1 1B1 I/O 1B1 input or output 3 1B2 I/O 1B2 input or output 4 GND — Ground pin 5 1B3 I/O 1B3 input or output 6 1B4 I/O 1B4 input or output 7 VCC — Power pin 8 1B5 I/O 1B5 input or output 9 1B6 I/O 1B6 input or output 10 GND — Ground pin 11 1B7 I/O 1B7 input or output 12 1B8 I/O 1B8 input or output 13 2B1 I/O 2B1 input or output 14 2B2 I/O 2B2 input or output 15 GND — Ground pin 16 2B3 I/O 2B3 input or output 17 2B4 I/O 2B4 input or output 18 VCC — Power pin NO. NAME 1 2 Submit Documentation Feedback Copyright © 1996–2014, Texas Instruments Incorporated Product Folder Links: SN74AHCT16245 3 SN74AHCT16245 SCLS335K – MARCH 1996 – REVISED OCTOBER 2014 www.ti.com Pin Functions (continued) PIN 4 I/O DESCRIPTION 2B5 I/O 2B5 input or output 2B6 I/O 2B6 input or output 21 GND — Ground pin 22 2B7 I/O 2B7 input or output 23 2B8 I/O 2B8 input or output 24 2DIR — Direction pin 2 25 2OE I 26 2A8 I/O 2A8 input or output 27 2A7 I/O 2A7 input or output 28 GND — Ground pin 29 2A6 I/O 2A6 input or output 30 2A5 I/O 2A5 input or output 31 VCC — Power pin 32 2A4 I/O 2A4 input or output 33 2A3 I/O 2A3 input or output 34 GND — Ground pin 35 2A2 I/O 2A2 input or output 36 2A1 I/O 2A1 input or output 37 1A8 I/O 1A8 input or output 38 1A7 I/O 1A7 input or output 39 GND — Ground pin 40 1A6 I/O 1A6 input or output 41 1A5 I/O 1A5 input or output 42 VCC — Power pin 43 1A4 I/O 1A4 input or output 44 1A3 I/O 1A3 input or output 45 GND — Ground pin 46 1A2 I/O 1A2 input or output 47 1A1 I/O 1A1 input or output 48 1OE I NO. NAME 19 20 Output Enable 2 Output Enable 1 Submit Documentation Feedback Copyright © 1996–2014, Texas Instruments Incorporated Product Folder Links: SN74AHCT16245 SN74AHCT16245 www.ti.com SCLS335K – MARCH 1996 – REVISED OCTOBER 2014 7 Specifications 7.1 Absolute Maximum Ratings over operating free-air temperature range (unless otherwise noted) (1) VCC MIN MAX Supply voltage range –0.5 7 UNIT V (2) –0.5 7 V –0.5 VCC + 0.5 VI Control Inputs Input voltage range VO I/O Output voltage range (2) IIK Control Inputs Input clamp current VI < 0 –20 mA IOK I/O Output clamp current VO < 0 or VO > VCC ±20 mA Continuous output current VO = 0 to VCC ±25 mA ±75 mA IO Continuous current through VCC or GND (1) (2) V Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, which do not imply functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. The input and output voltage ratings may be exceeded if the input and output current ratings are observed. 7.2 Handling Ratings Tstg Storage temperature range V(ESD) (1) (2) Electrostatic discharge MIN MAX UNIT °C –65 150 Human body model (HBM), per ANSI/ESDA/JEDEC JS-001, all pins (1) 0 1500 Charged device model (CDM), per JEDEC specification JESD22-C101, all pins (2) 0 2000 V JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. 7.3 Recommended Operating Conditions over operating free-air temperature range (unless otherwise noted) (1) SN74AHCT16245 MIN MAX 4.5 5.5 UNIT VCC Supply voltage VIH High-level input voltage VIL Low-level input voltage VI Input voltage VIO Input/Output voltage, A or B pins IOH High-level output current –8 IOL Low-level output current 8 mA Δt/Δv Input transition rise or fall rate 20 ns/V TA Operating free-air temperature 125 °C (1) 2 V V 0.8 V 0 5.5 V 0 VCC V –40 mA All unused inputs of the device must be held at VCC or GND to ensure proper device operation. Refer to the TI Application Report, Implications of Slow or Floating CMOS Inputs (SCBA004). Submit Documentation Feedback Copyright © 1996–2014, Texas Instruments Incorporated Product Folder Links: SN74AHCT16245 5 SN74AHCT16245 SCLS335K – MARCH 1996 – REVISED OCTOBER 2014 www.ti.com 7.4 Thermal Information SN74AHCT16245 THERMAL METRIC (1) DGG DGV DL UNIT 48 PINS RθJA Junction-to-ambient thermal resistance 68.1 79.3 61.0 RθJC(top) Junction-to-case (top) thermal resistance 22.6 31.3 30.8 RθJB Junction-to-board thermal resistance 35.0 42.3 32.8 ψJT Junction-to-top characterization parameter 1.3 2.4 8.4 ψJB Junction-to-board characterization parameter 34.7 41.8 32.5 RθJC(bot) Junction-to-case (bottom) thermal resistance n/a n/a n/a (1) °C/W For more information about traditional and new thermal metrics, see the IC Package Thermal Metrics application report (SPRA953). 7.5 Electrical Characteristics over recommended operating free-air temperature range (unless otherwise noted) PARAMETER TEST CONDITIONS IOH = –50 µA VOH IOH = –8 mA IOL = 50 µA VOL IOL = 8 mA II OE or DIR VI = VCC or GND IOZ (1) A or B Inputs VO = VCC or GND ICC ΔICC (2) Ci OE or DIR Cio A or B Inputs (1) (2) 6 TA = 25°C VCC 4.5 V MIN TYP 4.4 4.5 MAX 3.94 4.5 V 0 V to 5.5 V –40°C to 125°C SN74AHCT16245 SN74AHCT16245 MIN MAX MIN 4.4 4.4 3.8 3.8 UNIT MAX V 0.1 0.1 0.1 0.36 0.44 0.44 ±0.1 ±1 ±1 µA ±0.25 ±2.5 ±2.5 µA V VI = VCC or GND, IO = 0 5.5 V 4 40 40 µA One input at 3.4 V, Other inputs at VCC or GND 5.5 V 1.35 1.5 1.5 mA 10 10 10 pF VI = VCC or GND 5V 2.5 5V 4 pF For I/O ports, the parameter IOZ includes the input leakage current. This is the increase in supply current for each input at one of the specified TTL voltage levels, rather than 0 V or VCC. Submit Documentation Feedback Copyright © 1996–2014, Texas Instruments Incorporated Product Folder Links: SN74AHCT16245 SN74AHCT16245 www.ti.com SCLS335K – MARCH 1996 – REVISED OCTOBER 2014 7.6 Switching Characteristics over recommended operating free-air temperature range, VCC = 5 V ± 0.5 V (unless otherwise noted) (see Figure 2) PARAMETER tPLH tPHL FROM (INPUT) TO (OUTPUT) LOAD CAPACITANCE A or B B or A CL = 15 pF tPZH OE A or B CL = 15 pF OE A or B CL = 15 pF A or B B or A CL = 50 pF OE A or B CL = 50 pF OE A or B CL = 50 pF tPZL tPHZ tPLZ tPLH tPHL tPZH tPZL tPHZ tPLZ tsk(o) (1) (2) TA = 25°C TA = –40°C to 125°C SN74AHCT16245 SN74AHCT16245 UNIT TYP MAX MIN MAX MIN MAX 4.5 (1) 8.5 (1) 1 9.5 1 11 4.5 (1) 8.5 (1) 1 9.5 1 11 8.9 (1) (1) 1 14 1 15 8.9 (1) 13 (1) 1 14 1 15 9.2 (1) 14 (1) 1 15 1 15.7 9.2 (1) 14 (1) 1 15 1 15.7 13 7 9.5 1 10.5 1 12 5.3 9.5 1 10.5 1 12 8.3 14 1 15 1 16 8.3 14 1 15 1 16 8 14 1 15 1 15.7 8 14 1 15 1 15.7 1 (2) CL = 50 pF 1 ns ns ns ns ns ns 1 ns On products compliant to MIL-PRF-38535, this parameter is not production tested. On products compliant to MIL-PRF-38535, this parameter does not apply. 7.7 Noise Characteristics VCC = 5 V, CL = 50 pF, TA = 25°C (1) SN74AHCT16245 PARAMETER MIN TYP UNIT MAX VOL(P) Quiet output, maximum dynamic VOL 0.6 0.8 V VOL(V) Quiet output, minimum dynamic VOL –0.6 –0.8 V VOH(V) Quiet output, minimum dynamic VOH 4.8 VIH(D) High-level dynamic input voltage VIL(D) Low-level dynamic input voltage (1) V 2 V 0.8 V Characteristics are for surface-mount packages only. 7.8 Operating Characteristics VCC = 5 V, TA = 25°C PARAMETER Cpd TEST CONDITIONS Power dissipation capacitance No load, f = 1 MHz TYP UNIT 17 pF 7.9 Typical Characteristics 6 5 TPD (ns) 4 3 2 1 TPD in ns 0 -100 -50 0 50 Temperature (qC) 100 150 D001 Figure 1. TPD vs Temperature Submit Documentation Feedback Copyright © 1996–2014, Texas Instruments Incorporated Product Folder Links: SN74AHCT16245 7 SN74AHCT16245 SCLS335K – MARCH 1996 – REVISED OCTOBER 2014 www.ti.com 8 Parameter Measurement Information From Output Under Test Test Point From Output Under Test RL = 1 kΩ S1 VCC Open TEST GND CL (see Note A) CL (see Note A) S1 tPLH/tPHL tPLZ/tPZL tPHZ/tPZH Open Drain Open VCC GND VCC LOAD CIRCUIT FOR 3-STATE AND OPEN-DRAIN OUTPUTS LOAD CIRCUIT FOR TOTEM-POLE OUTPUTS 3V 1.5 V Timing Input 0V tw 3V 1.5 V Input 1.5 V th tsu 3V 1.5 V Data Input 1.5 V 0V 0V VOLTAGE WAVEFORMS SETUP AND HOLD TIMES VOLTAGE WAVEFORMS PULSE DURATION 3V 1.5 V Input 1.5 V 0V tPLH In-Phase Output tPHL 50% VCC tPHL Out-of-Phase Output VOH 50% VCC VOL Output Waveform 1 S1 at VCC (see Note B) VOH 50% VCC VOL 1.5 V 1.5 V 0V tPLZ tPZL ≈VCC 50% VCC Output Waveform 2 S1 at GND (see Note B) VOLTAGE WAVEFORMS PROPAGATION DELAY TIMES INVERTING AND NONINVERTING OUTPUTS VOL + 0.3 V VOL tPHZ tPZH tPLH 50% VCC 3V Output Control 50% VCC VOH – 0.3 V VOH ≈0 V VOLTAGE WAVEFORMS ENABLE AND DISABLE TIMES LOW- AND HIGH-LEVEL ENABLING NOTES: A. CL includes probe and jig capacitance. B. Waveform 1 is for an output with internal conditions such that the output is low except when disabled by the output control. Waveform 2 is for an output with internal conditions such that the output is high except when disabled by the output control. C. All input pulses are supplied by generators having the following characteristics: PRR ≤ 1 MHz, ZO = 50 Ω, tr ≤ 3 ns, tf ≤ 3 ns. D. The outputs are measured one at a time with one input transition per measurement. Figure 2. Load Circuit and Voltage Waveforms 8 Submit Documentation Feedback Copyright © 1996–2014, Texas Instruments Incorporated Product Folder Links: SN74AHCT16245 SN74AHCT16245 www.ti.com SCLS335K – MARCH 1996 – REVISED OCTOBER 2014 9 Detailed Description 9.1 Overview The SN74AHCT16245 device is a 16-bit (dual-octal) noninverting 3-state transceiver designed for synchronous two-way communication between data buses. The control-function implementation minimizes external timing requirements. This device can be used as two 8-bit transceivers or one 16-bit transceiver. It allows data transmission from the A bus to the B bus or from the B bus to the A bus, depending on the logic level at the direction-control (DIR) input. The output-enable (OE) input can be used to disable the device so that the buses are effectively isolated. To ensure the high-impedance state during power up or power down, OE should be tied to VCC through a pullup resistor; the minimum value of the resistor is determined by the current-sinking capability of the driver. 9.2 Functional Block Diagrams 1OE 1DIR G3 3 EN1 [BA] 3 EN2 [AB] 2OE 2DIR G6 6 EN4 [BA] 6 EN5 [AB] 1A1 1B1 1 2 1A2 1B2 1A3 1B3 1A4 1B4 1A5 1B5 1A6 1B6 1A7 1B7 1A8 1B8 2A1 2B1 4 5 A. 2A2 2B2 2A3 2B3 2A4 2B4 2A5 2B5 2A6 2B6 2A7 2B7 2A8 2B8 † This symbol is in accordance with ANSI/IEEE Std 91-1984 and IEC Publication 617-12. Figure 3. Logic Symbol Submit Documentation Feedback Copyright © 1996–2014, Texas Instruments Incorporated Product Folder Links: SN74AHCT16245 9 SN74AHCT16245 SCLS335K – MARCH 1996 – REVISED OCTOBER 2014 www.ti.com Functional Block Diagrams (continued) 1DIR 2DIR 1OE 1A1 2OE 2A1 1B1 2B1 To Seven Other Channels To Seven Other Channels Figure 4. Logic Diagram (Positive Logic) 9.3 Feature Description • • TTL inputs – Lowered switching threshold allows up translation 3.3 V to 5 V Slow edges reduce output ringing 9.4 Device Functional Modes Table 1. Function Table (Each 8-bit Transceiver) INPUTS OE 10 DIR OPERATION L L B data to A bus L H A data to B bus H X Isolation Submit Documentation Feedback Copyright © 1996–2014, Texas Instruments Incorporated Product Folder Links: SN74AHCT16245 SN74AHCT16245 www.ti.com SCLS335K – MARCH 1996 – REVISED OCTOBER 2014 10 Application and Implementation 10.1 Application Information The SN74AHCT16245 is a low-drive CMOS device that can be used for a multitude of bus interface type applications where output ringing is a concern. The low drive and slow edge rates will minimize overshoot and undershoot on the outputs. The input switching levels have been lowered to accommodate TTL inputs of 0.8-V VIL and 2-V VIH. This feature makes the device ideal for translating up from 3.3 V to 5 V. Figure 6 shows this type of translation. 10.2 Typical Application Regulated 5 V to 3.3 V Regulated 3.3 V Regulated 5 V OE VCC OE DIR A1 DIR B1 µC or other system boards A8 VCC µC or other system boards B8 µC LEDs or Relays or other system boards GND A1 B1 A8 B8 GND µC LEDs or Relays or other system boards Figure 5. Typical Application Diagram 10.2.1 Design Requirements This device uses CMOS technology and has balanced output drive. Care should be taken to avoid bus contention because it can drive currents that would exceed maximum limits. The high drive will also create fast edges into light loads; therefore, routing and load conditions should be considered to prevent ringing. 10.2.2 Detailed Design Procedure 1. Recommended Input Conditions: – For rise time and fall time specifications, see Δt/ΔV in the Recommended Operating Conditions table. – For specified high and low levels, see VIH and VIL in the Recommended Operating Conditions table. – Inputs are overvoltage tolerant allowing them to go as high as 5.5 V at any valid VCC. 2. Recommend Output Conditions: – Load currents should not exceed 25 mA per output and 75 mA total for the part. – Outputs should not be pulled above VCC. Submit Documentation Feedback Copyright © 1996–2014, Texas Instruments Incorporated Product Folder Links: SN74AHCT16245 11 SN74AHCT16245 SCLS335K – MARCH 1996 – REVISED OCTOBER 2014 www.ti.com Typical Application (continued) 10.2.3 Application Curves Voltage (1 V/ div) Output Voltage Input Voltage Time (5 ns/div), VCC = 5 V Figure 6. Up Translation 11 Power Supply Recommendations The power supply can be any voltage between the MIN and MAX supply voltage rating located in the Recommended Operating Conditions table. Each VCC pin should have a good bypass capacitor to prevent power disturbance. For devices with a single supply, 0.1 μF is recommended and if there are multiple VCC pins than 0.01 μF or 0.022 μF is recommended for each power pin. It is acceptable to parallel multiple bypass caps to reject different frequencies of noise. A 0.1 μF and 1 μF are commonly used in parallel. The bypass capacitor should be installed as close to the power pin as possible for best results. 12 Layout 12.1 Layout Guidelines When using multiple bit logic devices, inputs should not float. In many cases, functions or parts of functions of digital logic devices are unused. Some examples are when only two inputs of a triple-input AND gate are used, or when only 3 of the 4-buffer gates are used. Such input pins should not be left unconnected because the undefined voltages at the outside connections result in undefined operational states. Specified in Figure 7 are rules that must be observed under all circumstances. All unused inputs of digital logic devices must be connected to a high or low bias to prevent them from floating. The logic level that should be applied to any particular unused input depends on the function of the device. Generally they will be tied to GND or VCC, whichever makes more sense or is more convenient. It is acceptable to float outputs unless the part is a transceiver. 12.2 Layout Example Vcc Unused Input Input Output Unused Input Output Input Figure 7. Layout Diagram 12 Submit Documentation Feedback Copyright © 1996–2014, Texas Instruments Incorporated Product Folder Links: SN74AHCT16245 SN74AHCT16245 www.ti.com SCLS335K – MARCH 1996 – REVISED OCTOBER 2014 13 Device and Documentation Support 13.1 Trademarks Widebus is a trademark of Texas Instruments. All other trademarks are the property of their respective owners. 13.2 Electrostatic Discharge Caution These devices have limited built-in ESD protection. The leads should be shorted together or the device placed in conductive foam during storage or handling to prevent electrostatic damage to the MOS gates. 13.3 Glossary SLYZ022 — TI Glossary. This glossary lists and explains terms, acronyms, and definitions. 14 Mechanical, Packaging, and Orderable Information The following pages include mechanical, packaging, and orderable information. This information is the most current data available for the designated devices. This data is subject to change without notice and revision of this document. For browser-based versions of this data sheet, refer to the left-hand navigation. Submit Documentation Feedback Copyright © 1996–2014, Texas Instruments Incorporated Product Folder Links: SN74AHCT16245 13 PACKAGE OPTION ADDENDUM www.ti.com 8-Sep-2023 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan (2) Lead finish/ Ball material MSL Peak Temp Op Temp (°C) Device Marking (3) Samples (4/5) (6) 74AHCT16245DGGRG4 ACTIVE TSSOP DGG 48 2000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 125 AHCT16245 Samples 74AHCT16245DLRG4 ACTIVE SSOP DL 48 1000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 125 AHCT16245 Samples SN74AHCT16245DGGR ACTIVE TSSOP DGG 48 2000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 125 AHCT16245 Samples SN74AHCT16245DGVR ACTIVE TVSOP DGV 48 2000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 125 HF245 Samples SN74AHCT16245DL LIFEBUY SSOP DL 48 25 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 125 AHCT16245 SN74AHCT16245DLR ACTIVE SSOP DL 48 1000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 125 AHCT16245 (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
SN74AHCT16245DLG4 价格&库存
很抱歉,暂时无法提供与“SN74AHCT16245DLG4”相匹配的价格&库存,您可以联系我们找货
