SN74LV373AZQNR
SN74LV373AZQNR
    ROCHESTER(罗切斯特)
    VFBGA20
    BUS DRIVER
SN74LV373AZQNR 数据手册
SN74LV373A SCLS407N – APRIL 1998 – REVISED DECEMBER 2023 SN74LV373A Octal Transparent D-Type Latches With 3-State Outputs 1 Features 3 Description • • • The SN74LV373A device is an octal transparent Dtype latch designed for 2 V to 5.5 V VCC operation. • • • • VCC operation of 2 V to 5.5 V Maximum tpd of 8.5 ns at 5 V Typical VOLP (Output Ground Bounce) < 0.8 V at VCC = 3.3 V, TA = 25°C Typical VOHV (Output VOH Undershoot) > 2.3 V at VCC = 3.3 V, TA = 25°C Support Mixed-Mode Voltage Operation on All Ports Ioff Supports Partial-Power-Down Mode Operation Latch-Up Performance Exceeds 250 mA Per JESD 17 Package Information PART NUMBER SN74LV373A 2 Applications • • • • • • PACKAGE BODY SIZE (NOM) VQFN (20) 4.50 x 3.50 mm SSOP (20) 7.50 x 5.30 mm TSSOP (20) 6.50 x 4.40 mm TVSOP (20) 5.00 x 4.40 mm SOIC (20) 12.80 x 7.50 mm SO (20) 12.60 mm × 5.30 mm Printers Network Switches Tests and Measurements Wireless Infrastructure Motor Controls Server Motherboards Simplified Schematic An IMPORTANT NOTICE at the end of this data sheet addresses availability, warranty, changes, use in safety-critical applications, intellectual property matters and other important disclaimers. UNLESS OTHERWISE NOTED, this document contains PRODUCTION DATA. SN74LV373A www.ti.com SCLS407N – APRIL 1998 – REVISED DECEMBER 2023 Table of Contents 1 Features............................................................................1 2 Applications..................................................................... 1 3 Description.......................................................................1 4 Pin Configuration and Functions...................................3 5 Specifications.................................................................. 4 5.1 Absolute Maximum Ratings........................................ 4 5.2 ESD Ratings............................................................... 4 5.3 Recommended Operating Conditions.........................5 5.4 Thermal Information....................................................5 5.5 Electrical Characteristics.............................................6 5.6 Timing Requirements, VCC = 2.5 V ± 0.2 V.................6 5.7 Timing Requirements, VCC = 3.3 V ± 0.3 V.................6 5.8 Timing Requirements, VCC = 5 V ± 0.5 V....................6 5.9 Switching Characteristics, VCC = 2.5 V ± 0.2 V...........7 5.10 Switching Characteristics, VCC = 3.3 V ± 0.3 V.........7 5.11 Switching Characteristics, VCC = 5 V ± 0.5 V............ 7 5.12 Noise Characteristics................................................ 8 5.13 Operating Characteristics......................................... 8 2 5.14 Typical Characteristics.............................................. 8 6 Parameter Measurement Information............................ 9 7 Detailed Description......................................................10 7.1 Overview................................................................... 10 7.2 Functional Block Diagram......................................... 10 7.3 Feature Description...................................................10 7.4 Device Functional Modes..........................................10 8 Application and Implementation.................................. 11 8.1 Application Information..............................................11 8.2 Typical Application.................................................... 11 8.3 Layout....................................................................... 12 9 Device and Documentation Support............................13 9.1 Receiving Notification of Documentation Updates....13 9.2 Community Resources..............................................13 9.3 Trademarks............................................................... 13 10 Revision History.......................................................... 13 11 Mechanical, Packaging, and Orderable Information.................................................................... 13 Submit Document Feedback Copyright © 2023 Texas Instruments Incorporated Product Folder Links: SN74LV373A SN74LV373A www.ti.com SCLS407N – APRIL 1998 – REVISED DECEMBER 2023 4 Pin Configuration and Functions Figure 4-1. DB, DGV, DW, NS, or PW 20-Pin SSOP, TVSOP, SOIC, SO, or TSSOP Top View Figure 4-2. RGY Package 20-Pin VQFN Top View Table 4-1. Pin Functions PIN TYPE DESCRIPTION SSOP, TVSOP, SOIC, SO, or TSSOP VQFN 1 OE OE I Output Enable 2 1Q 1Q O 1Q Output 3 1D 1D I 1D Input NO. 4 2D 2D I 2D Input 5 2Q 2Q O 2Q Output 6 3Q 3Q O 3Q Output 7 3D 3D I 3D Input 8 4D 4D I 4D Input 9 4Q 4Q O 4Q Output 10 GND GND — Ground Pin 11 LE LE I Latch Enable 12 5Q 5Q O 5Q Output 13 5D 5D I 5D Input 14 6D 6D I 6D Input 15 6Q 6Q O 6Q Output 16 7Q 7Q O 7Q Output 17 7D 7D I 7D Input 18 8D 8D I 8D Input 19 8Q 8Q O 8Q Output 20 VCC VCC — Power Pin — — Thermal Pad — Thermal Pad, normally tied to GND Submit Document Feedback Copyright © 2023 Texas Instruments Incorporated Product Folder Links: SN74LV373A 3 SN74LV373A www.ti.com SCLS407N – APRIL 1998 – REVISED DECEMBER 2023 5 Specifications 5.1 Absolute Maximum Ratings over operating free-air temperature range (unless otherwise noted)(1) VCC MIN MAX Supply voltage –0.5 7 V voltage(2) –0.5 7 V –0.5 7 V –0.5 VCC + 0.5 VI Input VO Voltage range applied to any output in the high-impedance or power-off state(2) voltage(2) (3) UNIT VO Output IIK Input clamp current VI < 0 –20 mA IOK Output clamp current VO < 0 –50 mA IO Continuous output current VO = 0 to VCC ±35 mA ±70 mA 150 °C Continuous channel current through VCC or GND Tstg (1) (2) (3) Storage temperature –65 V Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under Section 5.3 is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. The input and output negative-voltage ratings may be exceeded if the input and output current ratings are observed. This value is limited to 5.5-V maximum. 5.2 ESD Ratings VALUE Human body model (HBM), per ANSI/ESDA/JEDEC JS-001, all V(ESD) (1) (2) 4 Electrostatic discharge pins(1) UNIT ±3000 Charged device model (CDM), per JEDEC specification JESD22-C101, all pins(2) ±2000 Machine Model (MM) ±200 V JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. Submit Document Feedback Copyright © 2023 Texas Instruments Incorporated Product Folder Links: SN74LV373A SN74LV373A www.ti.com SCLS407N – APRIL 1998 – REVISED DECEMBER 2023 5.3 Recommended Operating Conditions over operating free-air temperature range (unless otherwise noted)(1) VCC MIN MAX 2 5.5 Supply voltage VCC = 2 V VIH High-level input voltage Low-level input voltage VI Input voltage VCC = 2.3 V ± 2.7 V VCC × 0.7 VCC = 3 V ± 3.6 V VCC × 0.7 VCC = 4.5 V ± 5.5 V VCC × 0.7 Output voltage VCC = 2.3 V ± 2.7 V VCC × 0.3 VCC = 3 V ± 3.6 V VCC × 0.3 High-level output current 5.5 High or low state 0 VCC 3-state 0 5.5 VCC = 2.3 V ± 2.7 V –2 VCC = 3 V ± 3.6 V –8 Δt/Δv Input transition rise or fall (1) µA mA 50 VCC = 2.3 V ± 2.7 V 2 VCC = 3 V ± 3.6 V 8 VCC = 4.5 V ± 5.5 V 16 VCC = 2.3 V ± 2.7 V 200 VCC = 3 V ± 3.6 V 100 VCC = 4.5 V ± 5.5 V TA V –16 VCC = 2 V Low-level output current V –50 VCC = 4.5 V ± 5.5 V IOL V VCC × 0.3 0 VCC = 2 V IOH V 0.5 VCC = 4.5 V ± 5.5 V VO V 1.5 VCC = 2 V VIL UNIT µA mA ns/V 20 Operating free-air temperature –40 125 °C All unused inputs of the device must be held at VCC or GND to ensure proper device operation. Refer to the TI application report, Implications of Slow or Floating CMOS Inputs (SCBA004). 5.4 Thermal Information SN74LV373A THERMAL METRIC(1) DB (SSOP) DGV (TVSOP) DW (SOIC) NS (SO) PW (TSSOP) RGY (VQFN) UNIT 20 PINS RθJA Junction-to-ambient thermal resistance 94.5 116.2 79.2 76.7 128.2 34.8 °C/W RθJC(top) Junction-to-case (top) thermal resistance 56.4 31.2 43.7 43.2 70.5 42.9 °C/W RθJB Junction-to-board thermal resistance 49.7 57.7 47.0 44.2 79.3 12.4 °C/W ψJT Junction-to-top characterization parameter 18.5 0.9 18.6 16.8 23.4 0.8 °C/W ψJB Junction-to-board characterization parameter 49.3 57.0 46.5 43.8 78.9 12.5 °C/W RθJC(bot) Junction-to-case (bottom) thermal resistance — — — — — 7.6 °C/W (1) For more information about traditional and new thermal metrics, see the Semiconductor and IC Package Thermal Metrics application report. Submit Document Feedback Copyright © 2023 Texas Instruments Incorporated Product Folder Links: SN74LV373A 5 SN74LV373A www.ti.com SCLS407N – APRIL 1998 – REVISED DECEMBER 2023 5.5 Electrical Characteristics over recommended operating free-air temperature range (unless otherwise noted) PARAMETER TEST CONDITIONS TA = 25°C VCC MIN –40°C to +85°C TYP MAX MIN –40°C to +125°C MAX MIN MAX UNIT IOH = –50 µA 2 V to 5.5 V IOH = −2 mA 2.3 V 2 2 2 IOH = −8 mA 3V 2.48 2.48 2.48 IOH = −16 mA 4.5 V 3.8 3.8 3.8 IOL = 50 µA 2 V to 5.5 V 0.1 0.1 0.1 IOL = 2 mA 2.3 V 0.4 0.4 0.4 IOL = 8 mA 3V 0.44 0.44 0.44 IOL = 16 mA 4.5 V 0.55 0.55 0.55 II VI = 5.5 V or GND 0 V to 5.5 V ±1 ±1 ±1 µA IOZ VI = VCC or GND 5.5 V ±5 ±5 ±5 µA ICC VI = VCC or GND, 5.5 V 20 20 20 µA Ioff VI or VO = 0 to VCC 0 5 5 5 µA Ci VI = VCC or GND VOH VOL IO = 0 VCC – 0.1 3.3 V VCC – 0.1 VCC – 0.1 V 2.9 V pF 5.6 Timing Requirements, VCC = 2.5 V ± 0.2 V over recommended operating free-air temperature range (unless otherwise noted) (see Figure 6-1) TA = 25°C MIN MAX –40°C to +85°C MIN –40°C to +125°C MAX MIN MAX UNIT tw Pulse duration, LE high 6 6.5 6.5 ns tsu Setup time, data before LE↓ High or low 4.5 5 5.5 ns th Hold time, data after LE↓ High or low 1.5 1.5 2 ns 5.7 Timing Requirements, VCC = 3.3 V ± 0.3 V over recommended operating free-air temperature range (unless otherwise noted) (see Figure 6-1) TA = 25°C MIN MAX –40°C to +85°C MIN –40°C to +125°C MAX MIN MAX UNIT tw Pulse duration, LE high 5 5 5 ns tsu Setup time, data before LE↓ High or low 4 4 4.5 ns th Hold time, data after LE↓ High or low 1 1 1.5 ns 5.8 Timing Requirements, VCC = 5 V ± 0.5 V over recommended operating free-air temperature range (unless otherwise noted) (see Figure 6-1) TA = 25°C MIN 6 MAX –40°C to +85°C MIN MAX –40°C to +125°C MIN MAX UNIT tw Pulse duration, LE high 5 5 5 ns tsu Setup time, data before LE↓ High or low 4 4 4.5 ns th Hold time, data after LE↓ High or low 1 1 1.5 ns Submit Document Feedback Copyright © 2023 Texas Instruments Incorporated Product Folder Links: SN74LV373A SN74LV373A www.ti.com SCLS407N – APRIL 1998 – REVISED DECEMBER 2023 5.9 Switching Characteristics, VCC = 2.5 V ± 0.2 V over recommended operating free-air temperature range (unless otherwise noted) (see Figure 6-1) PARAMETER tpd FROM (INPUT) TO (OUTPUT) D MAX MIN MAX Q 8.3(1) 15.2(1) 1 17 1 18.5 9.1(1) 15.7(1) 1 19 1 20.5 8.9(1) 15.8(1) 1 19 1 20 6.2(1) 12.6(1) LE Q Q tdis OE Q D Q LE Q ten OE Q tdis OE Q MIN CL = 15 pF CL = 50 pF TYP –40°C to +125°C MIN OE 1 15 1 16.5 10.4 18 1 21 1 22.5 11.1 18.6 1 22 1 23.5 10.9 18.8 1 22 1 23.5 8.3 17.4 1 19 1 20.5 tsk(o) (1) –40°C to +85°C TA = 25°C MAX ten tpd LOAD CAPACITANCE 2 2 UNIT ns ns 2 On products compliant to MIL-PRF-38535, this parameter is not production tested. 5.10 Switching Characteristics, VCC = 3.3 V ± 0.3 V over recommended operating free-air temperature range (unless otherwise noted) (see Figure 6-1) PARAMETER tpd FROM (INPUT) TO (OUTPUT) D LE LOAD CAPACITANCE –40°C to +85°C TA = 25°C MIN MAX MIN MAX MIN MAX Q 5.8(1) 11.4(1) 1 13.5 1 14.5 Q 6.4(1) 11(1) 1 13 1 14 6.3(1) 11.4(1) 1 13.5 1 14.5 12 1 12.5 CL = 15 pF TYP –40°C to +125°C ten OE Q tdis OE Q 4.7(1) 10(1) 1 D Q 7.3 14.9 1 17 1 18 LE Q 7.8 14.5 1 16.5 1 17.5 ten OE Q 7.7 14.9 1 17 1 18 tdis OE Q 6 13.2 1 15 1 15.5 tpd CL = 50 pF tsk(o) (1) 1.5 1.5 UNIT ns ns 1.5 On products compliant to MIL-PRF-38535, this parameter is not production tested. 5.11 Switching Characteristics, VCC = 5 V ± 0.5 V over recommended operating free-air temperature range (unless otherwise noted) (see Figure 6-1) PARAMETER tpd FROM (INPUT) TO (OUTPUT) D LOAD CAPACITANCE –40°C to +85°C TA = 25°C MIN –40°C to +125°C TYP MAX MIN MAX MIN MAX Q 4.1(1) 7.2(1) 1 8.5 1 9.5 4.5(1) 7.2(1) 1 8.5 1 9.5 4.5(1) 8.1(1) 1 9.5 1 10.5 LE Q ten OE Q tdis OE Q 3.3(1) 7.2(1) 1 8.5 1 9 D Q 5.1 9.2 1 10.5 1 11.5 5.5 9.2 1 10.5 1 11.5 5.5 10.1 1 11.5 1 12.5 4 9.2 1 10.5 1 11 tpd LE Q ten OE Q tdis OE Q CL = 15 pF CL = 50 pF tsk(o) (1) 1 1 UNIT ns ns 1 On products compliant to MIL-PRF-38535, this parameter is not production tested. Submit Document Feedback Copyright © 2023 Texas Instruments Incorporated Product Folder Links: SN74LV373A 7 SN74LV373A www.ti.com SCLS407N – APRIL 1998 – REVISED DECEMBER 2023 5.12 Noise Characteristics VCC = 5 V, CL = 50 pF, TA = 25°C(1) SN74LV373A PARAMETER MIN TYP MAX UNIT VOL(P) Quiet output, maximum dynamic VOL 0.6 0.8 V VOL(V) Quiet output, minimum dynamic VOL –0.6 –0.8 V VOH(V) Quiet output, minimum dynamic VOH 2.9 VIH(D) High-level dynamic input voltage VIL(D) Low-level dynamic input voltage (1) V 2.31 V 0.99 V VCC TYP UNIT 3.3 V 17.4 5V 19.5 Characteristics are for surface-mount packages only. 5.13 Operating Characteristics TA = 25°C PARAMETER Cpd Power dissipation capacitance TEST CONDITIONS Outputs enabled CL = 50 pF f = 10 MHz pF 5.14 Typical Characteristics Figure 5-1. TPD vs Temperature at 5 V 8 Figure 5-2. TPD vs VCC at 25°C Submit Document Feedback Copyright © 2023 Texas Instruments Incorporated Product Folder Links: SN74LV373A SN74LV373A www.ti.com SCLS407N – APRIL 1998 – REVISED DECEMBER 2023 6 Parameter Measurement Information 6.1 Figure 6-1. Load Circuit and Voltage Waveforms Submit Document Feedback Copyright © 2023 Texas Instruments Incorporated Product Folder Links: SN74LV373A 9 SN74LV373A www.ti.com SCLS407N – APRIL 1998 – REVISED DECEMBER 2023 7 Detailed Description 7.1 Overview The SN74LV373A device is an octal transparent D-type latch designed for 2 V to 5.5 V VCC operation. When the latch-enable (LE) input is high, the Q outputs follow the data (D) inputs. When LE is taken low, the Q outputs are latched at the logic levels set up at the D inputs. At power-up, the state of the Q outputs are not predictable until the first valid clock. A buffered output-enable ( OE) input can be used to place the eight outputs in either a normal logic state (high or low) or the high-impedance state. In the high-impedance state, the outputs neither load nor drive the bus lines significantly. The high-impedance state and increased drive provide the capability to drive bus lines without need for interface or pull-up components. OE does not affect the internal operations of the latches. Old data can be retained or new data can be entered while the outputs are in the high-impedance state. To ensure the high-impedance state during power up or power down, OE should be tied to VCC through a pull-up resistor; the minimum value of the resistor is determined by the current-sinking capability of the driver. 7.2 Functional Block Diagram 7.3 Feature Description • • • Wide operating voltage range – Operates from 2 V to 5.5 V Allows down-voltage translation – Inputs accept voltages to 5.5 V Slow edges reduce output ringing 7.4 Device Functional Modes Table 7-1 shows the functional modes of SN74LV373A. Table 7-1. Function Table (Each Latch) INPUTS 10 OUTPUT OE LE D Q L H H H L H L L L L X Q0 H X X Z Submit Document Feedback Copyright © 2023 Texas Instruments Incorporated Product Folder Links: SN74LV373A SN74LV373A www.ti.com SCLS407N – APRIL 1998 – REVISED DECEMBER 2023 8 Application and Implementation Note Information in the following applications sections is not part of the TI component specification, and TI does not warrant its accuracy or completeness. TI’s customers are responsible for determining suitability of components for their purposes, as well as validating and testing their design implementation to confirm system functionality. 8.1 Application Information The SN74LV540A device is a low-drive CMOS device that can be used for a multitude of bus interface type applications where putput ringing is a concern. The low drive and slow edge rates will minimize overshoot and undershoot on the outputs. The inputs are tolerant to 5.5 V at any valid VCC. This feature makes it Ideal for translating down to the VCC level. Figure 8-2 shows the reduction in ringing compared to higher drive parts such as AC. 8.2 Typical Application Figure 8-1. Typical Application Schematic 8.2.1 Design Requirements This device uses CMOS technology and has balanced output drive. Care should be taken to avoid bus contention because it can drive currents that would exceed maximum limits. The high drive will also create fast edges into light loads, so routing and load conditions should be considered to prevent ringing. 8.2.2 Detailed Design Procedure 1. Recommended Input Conditions • For rise time and fall time specifications, see Δt/ΔV in the Section 5.3 table. • For specified High and low levels, see VIH and VIL in the Section 5.3 table. • Inputs are overvoltage tolerant allowing them to go as high as 5.5 V at any valid VCC. 2. Recommend Output Conditions • Load currents should not exceed 35 mA per output and 70 mA total for the part. • Outputs should not be pulled above VCC. Submit Document Feedback Copyright © 2023 Texas Instruments Incorporated Product Folder Links: SN74LV373A 11 SN74LV373A www.ti.com SCLS407N – APRIL 1998 – REVISED DECEMBER 2023 8.2.3 Application Curves Figure 8-2. Switching Characteristics Comparison Power Supply Recommendations The power supply can be any voltage between the MIN and MAX supply voltage rating located in the Section 5.3 table. Each VCC pin should have a good bypass capacitor to prevent power disturbance. For devices with a single supply, 0.1 μF is recommended. If there are multiple VCC pins, 0.01 μF or 0.022 μF is recommended for each power pin. It is acceptable to parallel multiple bypass caps to reject different frequencies of noise. A 0.1 μF and 1 μF are commonly used in parallel. The bypass capacitor should be installed as close to the power pin as possible for best results. 8.3 Layout 8.3.1 Layout Guidelines When using multiple bit logic devices, inputs should not float. In many cases, functions or parts of functions of digital logic devices are unused. Some examples are when only two inputs of a triple-input AND gate are used, or when only 3 of the 4-buffer gates are used. Such input pins should not be left unconnected because the undefined voltages at the outside connections result in undefined operational states. Specified in Figure 8-3 are rules that must be observed under all circumstances. All unused inputs of digital logic devices must be connected to a high or low bias to prevent them from floating. The logic level that should be applied to any particular unused input depends on the function of the device. Generally they will be tied to GND or VCC, whichever makes more sense or is more convenient. It is acceptable to float outputs unless the part is a transceiver. If the transceiver has an output enable pin, it will disable the outputs section of the part when asserted. This will not disable the input section of the I/Os so they also cannot float when disabled. 8.3.2 Layout Example Figure 8-3. Layout Diagram 12 Submit Document Feedback Copyright © 2023 Texas Instruments Incorporated Product Folder Links: SN74LV373A SN74LV373A www.ti.com SCLS407N – APRIL 1998 – REVISED DECEMBER 2023 9 Device and Documentation Support 9.1 Receiving Notification of Documentation Updates To receive notification of documentation updates, navigate to the device product folder on ti.com. In the upper right corner, click on Alert me to register and receive a weekly digest of any product information that has changed. For change details, review the revision history included in any revised document. 9.2 Community Resources 9.3 Trademarks All trademarks are the property of their respective owners. 10 Revision History NOTE: Page numbers for previous revisions may differ from page numbers in the current version. Changes from Revision M (December 2022) to Revision N (December 2023) Page • Updated thermal values for PW package from RθJA = 102.4 to 128.2, RθJC(top) = 36.5 to 70.5, RθJB = 53.6 to 79.3, ΨJT = 2.4 to 23.4, ΨJB = 52.9 to 78.9, all values in °C/W....................................................................5 Changes from Revision L (August 2016) to Revision M (December 2022) Page • Updated the format for tables, figures, and cross-references throughout the document................................... 1 11 Mechanical, Packaging, and Orderable Information The following pages include mechanical, packaging, and orderable information. This information is the most current data available for the designated devices. This data is subject to change without notice and revision of this document. For browser-based versions of this data sheet, refer to the left-hand navigation. Submit Document Feedback Copyright © 2023 Texas Instruments Incorporated Product Folder Links: SN74LV373A 13 PACKAGE OPTION ADDENDUM www.ti.com 23-Dec-2023 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan (2) Lead finish/ Ball material MSL Peak Temp Op Temp (°C) Device Marking (3) Samples (4/5) (6) SN74LV373ADBR ACTIVE SSOP DB 20 2000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 125 LV373A Samples SN74LV373ADGVR ACTIVE TVSOP DGV 20 2000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 125 LV373A Samples SN74LV373ADW LIFEBUY SOIC DW 20 25 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 125 LV373A SN74LV373ADWR ACTIVE SOIC DW 20 2000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 125 LV373A Samples SN74LV373ANSR ACTIVE SO NS 20 2000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 125 74LV373A Samples SN74LV373APWR ACTIVE TSSOP PW 20 2000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 125 LV373A Samples SN74LV373APWRG4 ACTIVE TSSOP PW 20 2000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 125 LV373A Samples SN74LV373ARGYR ACTIVE VQFN RGY 20 3000 RoHS & Green NIPDAU Level-2-260C-1 YEAR -40 to 125 LV373A Samples (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
SN74LV373AZQNR 价格&库存
很抱歉,暂时无法提供与“SN74LV373AZQNR”相匹配的价格&库存,您可以联系我们找货
