SN74AS374DWR
SN74AS374DWR
    ROCHESTER(罗切斯特)
    SOIC20_300MIL
    BUS DRIVER
SN74AS374DWR 数据手册
SN54ALS374A, SN54AS374, SN74ALS374A, SN74AS374 OCTAL D-TYPE EDGE-TRIGGERED FLIP-FLOPS WITH 3-STATE OUTPUTS SDAS167C – APRIL 1982 – REVISED NOVEMBER 1999 D D D SN54ALS374A, SN54AS374 . . . J PACKAGE SN74ALS374A, SN74AS374 . . . DW OR N PACKAGE (TOP VIEW) D-Type Flip-Flops in a Single Package With 3-State Bus Driving True Outputs Full Parallel Access for Loading Buffered Control Inputs Package Options Include Plastic Small-Outline (DW) Packages, Ceramic Chip Carriers (FK), and Standard Plastic (N) and Ceramic (J) DIPs OE 1Q 1D 2D 2Q 3Q 3D 4D 4Q GND description These octal D-type edge-triggered flip-flops feature 3-state outputs designed specifically for driving highly capacitive or relatively low-impedance loads. They are particularly suitable for implementing buffer registers, I/O ports, bidirectional bus drivers, and working registers. 1 20 2 19 3 18 4 17 5 16 6 15 7 14 8 13 9 12 10 11 VCC 8Q 8D 7D 7Q 6Q 6D 5D 5Q CLK 1D 1Q SN54ALS374A, SN54AS374 . . . FK PACKAGE (TOP VIEW) On the positive transition of the clock (CLK) input, the Q outputs are set to the logic levels set up at the data (D) inputs. 2D 2Q 3Q 3D 4D 4 2 1 20 19 18 5 17 6 16 7 15 8 14 9 10 11 12 13 8D 7D 7Q 6Q 6D 4Q GND CLK 5Q 5D A buffered output-enable (OE) input places the eight outputs in either a normal logic state (high or low logic levels) or the high-impedance state. In the high-impedance state, the outputs neither load nor drive the bus lines significantly. The high-impedance state and the increased drive provide the capability to drive bus lines without interface or pullup components. 3 OE VCC 8Q D OE does not affect internal operations of the flip-flops. Old data can be retained or new data can be entered while the outputs are in the high-impedance state. The SN54ALS374A and SN54AS374 are characterized for operation over the full military temperature range of –55°C to 125°C. The SN74ALS374A and SN74AS374 are characterized for operation from 0°C to 70°C. FUNCTION TABLE (each flip-flop) INPUTS OE CLK D OUTPUT Q L ↑ H H L ↑ L L L H or L X Q0 H X X Z Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet. Copyright  1999, Texas Instruments Incorporated PRODUCTION DATA information is current as of publication date. Products conform to specifications per the terms of Texas Instruments standard warranty. Production processing does not necessarily include testing of all parameters. On products compliant to MIL-PRF-38535, all parameters are tested unless otherwise noted. On all other products, production processing does not necessarily include testing of all parameters. POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 1 SN54ALS374A, SN54AS374, SN74ALS374A, SN74AS374 OCTAL D-TYPE EDGE-TRIGGERED FLIP-FLOPS WITH 3-STATE OUTPUTS SDAS167C – APRIL 1982 – REVISED NOVEMBER 1999 logic symbol† OE CLK 1 logic diagram (positive logic) OE EN 11 CLK C1 1 11 C1 1D 2D 3D 4D 5D 6D 7D 8D 3 2 1D 4 5 7 6 8 9 13 12 14 15 17 16 18 19 1Q 1D 3 2 1Q 1D 2Q 3Q 4Q To Seven Other Channels 5Q 6Q 7Q 8Q † This symbol is in accordance with ANSI/IEEE Std 91-1984 and IEC Publication 617-12. absolute maximum ratings over operating free-air temperature range (unless otherwise noted)‡ Supply voltage range, VCC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –0.5 V to 7 V Input voltage range, VI . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –0.5 V to 7 V Voltage applied to a disabled 3-state output . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –0.5 V to 5.5 V Package thermal impedance, θJA (see Note 1): DW package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 58°C/W N package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 69°C/W Storage temperature range, Tstg . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –65°C to 150°C ‡ Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. NOTE 1: The package thermal impedance is calculated in accordance with JESD 51. recommended operating conditions SN54ALS374A 2 SN74ALS374A MIN NOM MAX MIN NOM MAX 4.5 5 5.5 4.5 5 5.5 UNIT VCC VIH Supply voltage VIL IOH Low-level input voltage 0.7 0.8 V High-level output current –1 –2.6 mA IOL TA Low-level output current 24 mA 70 °C High-level input voltage 2 2 12 Operating free-air temperature –55 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 125 0 V V SN54ALS374A, SN54AS374, SN74ALS374A, SN74AS374 OCTAL D-TYPE EDGE-TRIGGERED FLIP-FLOPS WITH 3-STATE OUTPUTS SDAS167C – APRIL 1982 – REVISED NOVEMBER 1999 electrical characteristics over recommended operating free-air temperature range (unless otherwise noted) PARAMETER VIK VCC = 4.5 V, VCC = 4.5 V to 5.5 V, II = –18 mA IOH = –0.4 mA 5V VCC = 4 4.5 IOH = –1 mA IOH = –2.6 mA VOL VCC = 4 4.5 5V IOL = 12 mA IOL = 24 mA IOZH IOZL VCC = 5.5 V, VCC = 5.5 V, VO = 2.7 V VO = 0.4 V II IIH VCC = 5.5 V, VCC = 5.5 V, VI = 7 V VI = 2.7 V IIL IO‡ VCC = 5.5 V, VCC = 5.5 V, VI = 0.4 V VO = 2.25 V VOH ICC SN54ALS374A TYP† MAX TEST CONDITIONS VCC = 5.5 V MIN SN74ALS374A TYP† MAX MIN –1.5 VCC–2 2.4 UNIT –1.5 V VCC–2 V 3.3 2.4 0.25 –20 0.4 3.2 0.25 0.4 0.35 0.5 V 20 20 µA –20 –20 µA 0.1 0.1 mA 20 20 µA –0.2 –0.2 mA –112 mA –112 –30 Outputs high 11 20 11 19 Outputs low 19 28 19 28 mA Outputs disabled 20 31 20 31 † All typical values are at VCC = 5 V, TA = 25°C. ‡ The output conditions have been chosen to produce a current that closely approximates one half of the true short-circuit output current, IOS. timing requirements over recommended operating free-air temperature range (unless otherwise noted) SN54ALS374A MIN fclock tw Clock frequency Pulse duration CLK high or low tsu th Setup time Data before CLK↑ Hold time Data after CLK↑ MAX SN74ALS374A MIN 30 MAX 35 UNIT MHz 16.5 14 ns 10 10 ns 4 0 ns switching characteristics over recommended operating conditions (unless otherwise noted (see Figure 3) PARAMETER fmax tPLH tPHL tPZH tPZL tPHZ tPLZ FROM (INPUT) TO (OUTPUT) SN54ALS374A MIN MAX 30 CLK Q OE Q OE Q POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 SN74ALS374A MIN MAX 35 UNIT MHz 3 14 3 12 5 17 5 16 3 18 3 17 5 21 5 18 1 11 1 10 2 19 2 18 ns ns ns 3 SN54ALS374A, SN54AS374, SN74ALS374A, SN74AS374 OCTAL D-TYPE EDGE-TRIGGERED FLIP-FLOPS WITH 3-STATE OUTPUTS SDAS167C – APRIL 1982 – REVISED NOVEMBER 1999 recommended operating conditions SN54AS374 SN74AS374 MIN NOM MAX MIN NOM MAX 4.5 5 5.5 4.5 5 5.5 UNIT VCC VIH Supply voltage VIL IOH Low-level input voltage 0.7 0.8 V High-level output current –12 –15 mA IOL TA Low-level output current 32 48 mA 70 °C High-level input voltage 2 Operating free-air temperature 2 –55 125 V V 0 electrical characteristics over recommended operating free-air temperature range (unless otherwise noted) PARAMETER VIK TEST CONDITIONS VCC = 4.5 V, VCC = 4.5 V to 5.5 V, II = –18 mA IOH = –2 mA VCC = 4 4.5 5V IOH = –12 mA IOH = –15 mA VOL VCC = 4 4.5 5V IOL = 32 mA IOL = 48 mA IOZH IOZL VCC = 5.5 V, VCC = 5.5 V, VO = 2.7 V VO = 0.4 V II IIH VCC = 5.5 V, VCC = 5.5 V, VI = 7 V VI = 2.7 V VOH IIL OE, CLK Data IO‡ ICC VCC = 5 5.5 5V V, VI = 0 0.4 4V VCC = 5.5 V, VO = 2.25 V Outputs high VCC = 5.5 V SN54AS374 TYP† MAX MIN SN74AS374 TYP† MAX MIN –1.2 VCC–2 2.4 –1.2 UNIT V VCC–2 V 3.2 2.4 0.29 3.3 0.5 0.34 –30 0.5 V µA 50 50 –50 –50 µA 0.1 0.1 mA µA 20 20 –0.5 –0.5 –3 –2 –112 –30 –112 77 120 77 120 Outputs low 84 128 84 128 Outputs disabled 84 128 84 128 mA mA mA † All typical values are at VCC = 5 V, TA = 25°C. ‡ The output conditions have been chosen to produce a current that closely approximates one half of the true short-circuit output current, IOS. timing requirements over recommended operating free-air temperature range (unless otherwise noted) SN54AS374 MIN fclock Clock frequency tw Pulse duration tsu th SN74AS374 MIN 100* CLK high MAX 125 UNIT MHz 5.5* 4 CLK low 3* 3 Setup time Data before CLK↑ 3* 2 ns Hold time Data after CLK↑ 3* 2 ns * On products compliant to MIL-PRF-38535, this parameter is not production tested. 4 MAX POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 ns SN54ALS374A, SN54AS374, SN74ALS374A, SN74AS374 OCTAL D-TYPE EDGE-TRIGGERED FLIP-FLOPS WITH 3-STATE OUTPUTS SDAS167C – APRIL 1982 – REVISED NOVEMBER 1999 switching characteristics over recommended operating conditions (unless otherwise noted) (see Figure 3) PARAMETER fmax tPLH tPHL tPZH tPZL tPHZ FROM (INPUT) TO (OUTPUT) SN54AS374 MIN MAX 100* CLK Q OE Q OE Q tPLZ * On products compliant to MIL-PRF-38535, this parameter is not production tested. POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 SN74AS374 MIN MAX 125 UNIT MHz 3 11 3 8 4 11.5 4 9 2 7 2 6 3 11 3 10 2 10 2 6 2 7 2 6 ns ns ns 5 SN54ALS374A, SN54AS374, SN74ALS374A, SN74AS374 OCTAL D-TYPE EDGE-TRIGGERED FLIP-FLOPS WITH 3-STATE OUTPUTS SDAS167C – APRIL 1982 – REVISED NOVEMBER 1999 APPLICATION INFORMATION Four SN54ALS374A, SN74ALS374A, or ’AS374 EN C 8 8 ’ALS139 A Output-Enable Select B G X/Y 1 2 0 EN 1 C 2 EN 8 8 3 A Input Clock Select B EN G C 8 Clock 8 EN C 8 8 Input Figure 1. Expandable 4-Word by 8-Bit General File Register 6 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 8 8 Output SN54ALS374A, SN54AS374, SN74ALS374A, SN74AS374 OCTAL D-TYPE EDGE-TRIGGERED FLIP-FLOPS WITH 3-STATE OUTPUTS SDAS167C – APRIL 1982 – REVISED NOVEMBER 1999 APPLICATION INFORMATION SN54ALS374A, SN74ALS374A, or ’AS374 Output Enable 1 EN Clock 1 C1 1D Bidirectional Data Bus 1 Bidirectional Data Bus 2 SN54ALS374A, SN74ALS374A, or ’AS374 EN Output Enable 2 Clock 2 C1 1D Clock 1 H Bus-Exchange Clock Clock 2 H Clock Circuit for Bus Exchange Figure 2. Bidirectional Bus Driver POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 7 SN54ALS374A, SN54AS374, SN74ALS374A, SN74AS374 OCTAL D-TYPE EDGE-TRIGGERED FLIP-FLOPS WITH 3-STATE OUTPUTS SDAS167C – APRIL 1982 – REVISED NOVEMBER 1999 PARAMETER MEASUREMENT INFORMATION SERIES 54ALS/74ALS AND 54AS/74AS DEVICES 7V VCC S1 500 Ω From Output Under Test From Output Under Test Test Point CL = 50 pF (see Note A) CL = 50 pF (see Note A) 500 Ω 3.5 V Timing Input 500 Ω 3.5 V High-Level Pulse 1.3 V Test Point LOAD CIRCUIT FOR 3-STATE OUTPUTS LOAD CIRCUIT FOR OPEN-COLLECTOR OUTPUTS LOAD CIRCUIT FOR BI-STATE TOTEM-POLE OUTPUTS 500 Ω From Output Under Test CL = 50 pF (see Note A) Test Point 1.3 V 1.3 V 0.3 V 0.3 V tw th tsu 3.5 V Data Input 1.3 V 3.5 V Low-Level Pulse 1.3 V 0.3 V 1.3 V 1.3 V 0.3 V VOLTAGE WAVEFORMS PULSE DURATIONS VOLTAGE WAVEFORMS SETUP AND HOLD TIMES 3.5 V Output Control 1.3 V 1.3 V 3.5 V 0.3 V tPZL 1.3 V Input tPLZ 1.3 V 0.3 V ≈3.5 V Waveform 1 S1 Closed (see Note B) 1.3 V tPZH Waveform 2 S1 Open (see Note B) tPLH VOL + 0.3 V VOL In-Phase Output tPHZ 1.3 V VOH VOH – 0.3 V ≈0 V 1.3 V tPHL Out-of-Phase Output (see Note C) VOLTAGE WAVEFORMS ENABLE AND DISABLE TIMES, 3-STATE OUTPUTS tPHL VOH 1.3 V VOL tPLH VOH 1.3 V 1.3 V VOL VOLTAGE WAVEFORMS PROPAGATION DELAY TIMES NOTES: A. CL includes probe and jig capacitance. B. Waveform 1 is for an output with internal conditions such that the output is low except when disabled by the output control. Waveform 2 is for an output with internal conditions such that the output is high except when disabled by the output control. C. When measuring propagation delay items of 3-state outputs, switch S1 is open. D. All input pulses have the following characteristics: PRR ≤ 1 MHz, tr = tf = 2 ns, duty cycle = 50%. E. The outputs are measured one at a time with one transition per measurement. Figure 3. Load Circuits and Voltage Waveforms 8 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 PACKAGE OPTION ADDENDUM www.ti.com 2-Dec-2023 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan (2) Lead finish/ Ball material MSL Peak Temp Op Temp (°C) Device Marking (3) Samples (4/5) (6) 5962-9756201QRA ACTIVE CDIP J 20 20 Non-RoHS & Green SNPB N / A for Pkg Type -55 to 125 5962-9756201QR A SNJ54AS374J 83020022A ACTIVE LCCC FK 20 55 Non-RoHS & Green SNPB N / A for Pkg Type -55 to 125 83020022A SNJ54ALS 374AFK 8302002RA ACTIVE CDIP J 20 20 Non-RoHS & Green SNPB N / A for Pkg Type -55 to 125 8302002RA SNJ54ALS374AJ Samples 8302002SA ACTIVE CFP W 20 25 Non-RoHS & Green SNPB N / A for Pkg Type -55 to 125 8302002SA SNJ54ALS374AW Samples JM38510/37204B2A ACTIVE LCCC FK 20 55 Non-RoHS & Green SNPB N / A for Pkg Type JM38510/ 37204B2A Samples JM38510/37204BRA ACTIVE CDIP J 20 20 Non-RoHS & Green SNPB N / A for Pkg Type JM38510/ 37204BRA Samples M38510/37204B2A ACTIVE LCCC FK 20 55 Non-RoHS & Green SNPB N / A for Pkg Type -55 to 125 JM38510/ 37204B2A Samples M38510/37204BRA ACTIVE CDIP J 20 20 Non-RoHS & Green SNPB N / A for Pkg Type -55 to 125 JM38510/ 37204BRA Samples SN54ALS374AJ ACTIVE CDIP J 20 20 Non-RoHS & Green SNPB N / A for Pkg Type SN54ALS374AJ Samples SN54AS374J ACTIVE CDIP J 20 20 Non-RoHS & Green SNPB N / A for Pkg Type -55 to 125 SN54AS374J Samples SN74ALS374ADW LIFEBUY SOIC DW 20 25 RoHS & Green NIPDAU Level-1-260C-UNLIM 0 to 70 ALS374A SN74ALS374ADWR ACTIVE SOIC DW 20 2000 RoHS & Green NIPDAU Level-1-260C-UNLIM 0 to 70 ALS374A Samples SN74ALS374AN ACTIVE PDIP N 20 20 RoHS & Non-Green NIPDAU N / A for Pkg Type 0 to 70 SN74ALS374AN Samples SN74ALS374ANSR ACTIVE SO NS 20 2000 RoHS & Green NIPDAU Level-1-260C-UNLIM 0 to 70 ALS374A Samples SN74AS374N ACTIVE PDIP N 20 20 RoHS & Non-Green NIPDAU N / A for Pkg Type 0 to 70 SN74AS374N Samples SNJ54ALS374AFK ACTIVE LCCC FK 20 55 Non-RoHS & Green SNPB N / A for Pkg Type -55 to 125 Addendum-Page 1 83020022A SNJ54ALS 374AFK Samples Samples Samples PACKAGE OPTION ADDENDUM www.ti.com Orderable Device 2-Dec-2023 Status (1) Package Type Package Pins Package Drawing Qty Eco Plan (2) Lead finish/ Ball material MSL Peak Temp Op Temp (°C) (3) Device Marking Samples (4/5) (6) SNJ54ALS374AJ ACTIVE CDIP J 20 20 Non-RoHS & Green SNPB N / A for Pkg Type -55 to 125 8302002RA SNJ54ALS374AJ Samples SNJ54ALS374AW ACTIVE CFP W 20 25 Non-RoHS & Green SNPB N / A for Pkg Type -55 to 125 8302002SA SNJ54ALS374AW Samples SNJ54AS374J ACTIVE CDIP J 20 20 Non-RoHS & Green SNPB N / A for Pkg Type -55 to 125 5962-9756201QR A SNJ54AS374J (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
SN74AS374DWR 价格&库存
很抱歉,暂时无法提供与“SN74AS374DWR”相匹配的价格&库存,您可以联系我们找货
