ADS7841P
ADS7841P
    ROCHESTER(罗切斯特)
    DIP16
    SAR ADC, 12-BIT, SERIAL ACCESS
ADS7841P 数据手册
ADS7841 ADS 784 ADS 784 1 1 SBAS084B – JULY 2001 12-Bit, 4-Channel Serial Output Sampling ANALOG-TO-DIGITAL CONVERTER FEATURES DESCRIPTION ● SINGLE SUPPLY: 2.7V to 5V The ADS7841 is a 4-channel, 12-bit sampling Analog-toDigital Converter (ADC) with a synchronous serial interface. The resolution is programmable to either 8 bits or 12 bits. Typical power dissipation is 2mW at a 200kHz throughput rate and a +5V supply. The reference voltage (VREF) can be varied between 100mV and VCC, providing a corresponding input voltage range of 0V to VREF. The device includes a shutdown mode which reduces power dissipation to under 15µW. The ADS7841 is tested down to 2.7V operation. ● 4-CHANNEL SINGLE-ENDED OR 2-CHANNEL DIFFERENTIAL INPUT ● UP TO 200kHz CONVERSION RATE ● ±1LSB MAX INL AND DNL ● NO MISSING CODES ● 72dB SINAD ● SERIAL INTERFACE ● DIP-16 OR SSOP-16 PACKAGE ● ALTERNATE SOURCE FOR MAX1247 ● ADS7841ES: +125°C Version Low power, high speed, and on-board multiplexer make the ADS7841 ideal for battery-operated systems such as personal digital assistants, portable multi-channel data loggers, and measurement equipment. The serial interface also provides low-cost isolation for remote data acquisition. The ADS7841 is available in a DIP-16 or a SSOP-16 package and is specified over the –40°C to +125°C(1) temperature range. APPLICATIONS ● ● ● ● ● DATA ACQUISITION TEST AND MEASUREMENT INDUSTRIAL PROCESS CONTROL PERSONAL DIGITAL ASSISTANTS BATTERY-POWERED SYSTEMS NOTE: (1) ES grade only. SAR DCLK CS CH0 CH1 CH2 Comparator Four Channel Multiplexer Serial Interface and Control CDAC CH3 SHDN DIN DOUT MODE COM BUSY VREF Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet. Copyright © 2000, Texas Instruments Incorporated PRODUCTION DATA information is current as of publication date. Products conform to specifications per the terms of Texas Instruments standard warranty. Production processing does not necessarily include testing of all parameters. www.ti.com ELECTROSTATIC DISCHARGE SENSITIVITY ABSOLUTE MAXIMUM RATINGS(1) +VCC to GND ........................................................................ –0.3V to +6V Analog Inputs to GND ............................................ –0.3V to +VCC + 0.3V Digital Inputs to GND ........................................................... –0.3V to +6V Power Dissipation .......................................................................... 250mW Maximum Junction Temperature ................................................... +150°C Operating Temperature Range .................................. –40°C to +125°C(2) Storage Temperature Range ......................................... –65°C to +150°C Lead Temperature (soldering, 10s) ............................................... +300°C NOTES: (1) Stresses above those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. Exposure to absolute maximum conditions for extended periods may affect device reliability. (2) ADS7841ES 0nly. All other grades are: –40°C to +85°C. PACKAGE/ORDERING INFORMATION PRODUCT MINIMUM RELATIVE ACCURACY (LSB) MAXIMUM GAIN ERROR (LSB) SPECIFICATION TEMPERATURE RANGE ±2 " ±2 ±1 " ±1 ±2 ±4 " " ±3 " " ±4 –40°C to +85°C " –40°C to +85°C –40°C to +85°C " –40°C to +85°C –40°C to +125°C ADS7841E " ADS7841P ADS7841EB " ADS7841PB ADS7841ES This integrated circuit can be damaged by ESD. Texas Instruments recommends that all integrated circuits be handled with appropriate precautions. Failure to observe proper handling and installation procedures can cause damage. ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet its published specifications. PACKAGE PACKAGE DESIGNATOR PACKAGE DRAWING NUMBER SSOP-16 " DIP-16 SSOP-16 " DIP-16 SSOP-16 DBQ " N DBQ " N DBQ 322 " 180 322 " 180 322 ORDERING NUMBER(1) TRANSPORT MEDIA ADS7841E Rails ADS7841E/2K5 Tape and Reel ADS7841P Rails ADS7841EB Rails ADS7841EB/2K5 Tape and Reel ADS7841PB Rails ADS7841ES/2K5 Tape and Reel NOTES: (1) Models with a slash (/) are available only in Tape and Reel in the quantities indicated (e.g., /2K5 indicates 2500 devices per reel). Ordering 2500 pieces of “ADS7841E/2K5” will get a single 2500-piece Tape and Reel. PIN CONFIGURATIONS Top View DIP SSOP +VCC 1 16 DCLK +VCC 1 16 DCLK CH0 2 15 CS CH0 2 15 CS CH1 3 14 DIN CH1 3 14 DIN CH2 4 13 BUSY CH2 4 13 BUSY 12 DOUT CH3 5 COM ADS7841 ADS7841 12 DOUT CH3 5 6 11 MODE COM 6 11 MODE SHDN 7 10 GND SHDN 7 10 GND VREF 8 9 +VCC VREF 8 9 +VCC PIN DESCRIPTIONS 2 PIN NAME DESCRIPTION 1 2 3 4 5 6 +VCC CH0 CH1 CH2 CH3 COM 7 8 9 10 11 SHDN VREF +VCC GND MODE 12 13 14 15 16 DOUT BUSY DIN CS DCLK Power Supply, 2.7V to 5V Analog Input Channel 0 Analog Input Channel 1 Analog Input Channel 2 Analog Input Channel 3 Ground Reference for Analog Inputs. Sets zero code voltage in single-ended mode. Connect this pin to ground or ground reference point. Shutdown. When LOW, the device enters a very low power shutdown mode. Voltage Reference Input Power Supply, 2.7V to 5V Ground Conversion Mode. When LOW, the device always performs a 12-bit conversion. When HIGH, the resolution is set by the MODE bit in the CONTROL byte. Serial Data Output. Data is shifted on the falling edge of DCLK. This output is high impedance when CS is HIGH. Busy Output. This output is high impedance when CS is HIGH. Serial Data Input. If CS is LOW, data is latched on rising edge of DCLK. Chip Select Input. Controls conversion timing and enables the serial input/output register. External Clock Input. This clock runs the SAR conversion process and synchronizes serial data I/O. ADS7841 SBAS084B ELECTRICAL CHARACTERISTICS: +5V At TA = TMIN to TMAX, +VCC = +5V, VREF = +5V, fSAMPLE = 200kHz, and fCLK = 16 • fSAMPLE = 3.2MHz, unless otherwise noted. ADS7841E, P PARAMETER ANALOG INPUT Full-Scale Input Span Absolute Input Range CONDITIONS MIN Positive Input - Negative Input 0 Positive Input –0.2 Negative Input –0.2 Capacitance Leakage Current VREF +VCC +0.2 +1.25 ✻ ✻ ✻ TYP ±2 ✻ ✻ ✻ ✻ 68 72 0.1 DCLK Static 70 76 +VCC 5 40 2.5 0.001 3.0 –0.3 3.5 100 3 ✻ ✻ ✻ ✻ ✻ ✻ ✻ 68 72 ✻ ✻ ✻ ✻ ✻ ✻ ✻ ✻ ✻ ✻ Clk Cycles Clk Cycles kHz ns ns ps –72 dB dB dB dB ✻ V GΩ µA µA µA ✻ ✻ ✻ ✻ ✻ V V V V ✻ ✻ ✻ ✻ ✻ ✻ ✻ ✻ ✻ V µA µA µA mW +125 °C ✻ ✻ ✻ ✻ Bits Bits LSB(1) LSB LSB LSB LSB LSB µVrms dB ✻ ✻ 3 4.5 +85 –78 71 79 120 ✻ ✻ 5.25 900 ✻ ✻ ±4 ✻ ✻ –76 ✻ ✻ 0.4 –40 ✻ ✻ 5.5 +0.8 550 300 2 ±0.8 ✻ ✻ ✻ ✻ ✻ ✻ ✻ ✻ Straight Binary PWR SUPPLY REQUIREMENTS +VCC Specified Performance 4.75 Quiescent Current fSAMPLE = 12.5kHz Power-Down Mode(3), CS = +VCC Power Dissipation TEMPERATURE RANGE Specified Performance –80 72 81 ✻ ✻ CMOS | IIH | ≤ +5µA | IIL | ≤ +5µA IOH = –250µA IOL = 250µA ±1 ±1 ✻ ✻ ±3 ✻ ✻ –72 V V V pF nA 200 ✻ ✻ ✻ –78 71 79 120 ✻ ✻ ✻ ✻ 200 10kHz 10kHz 10kHz 50kHz UNITS ✻ ✻ 500 30 100 MAX ✻ ✻ 12 3 TYP 11 ±0.5 ±3 1.0 ±4 1.0 0.1 30 70 at at at at ✻ ✻ ✻ ✻ 0.15 5Vp-p 5Vp-p 5Vp-p 5Vp-p ✻ ✻ ✻ 12 ±0.8 = = = = MIN 200 12 VIN VIN VIN VIN ADS7841ES MAX ✻ 12 fSAMPLE = 12.5kHz DCLK Static DIGITAL INPUT/OUTPUT Logic Family Logic Levels VIH VIL VOH VOL Data Format MIN 200 SAMPLING DYNAMICS Conversion Time Acquisition Time Throughput Rate Multiplexer Settling Time Aperture Delay Aperture Jitter REFERENCE INPUT Range Resistance Input Current MAX 25 SYSTEM PERFORMANCE Resolution No Missing Codes Integral Linearity Error Differential Linearity Error Offset Error Offset Error Match Gain Error Gain Error Match Noise Power-Supply Rejection DYNAMIC CHARACTERISTICS Total Harmonic Distortion(2) Signal-to-(Noise + Distortion) Spurious-Free Dynamic Range Channel-to-Channel Isolation ADS7841EB, PB TYP ✻ ✻ ✻ Same specifications as ADS7841E, P. NOTE: (1) LSB means Least Significant Bit. With VREF equal to +5.0V, one LSB is 1.22mV. (2) First five harmonics of the test frequency. (3) Auto power-down mode (PD1 = PD0 = 0) active or SHDN = GND. ADS7841 SBAS084B 3 ELECTRICAL CHARACTERISTICS: +2.7V At TA = –40°C to +85°C, +VCC = +2.7V, VREF = +2.5V, fSAMPLE = 125kHz, and fCLK = 16 • fSAMPLE = 2MHz, unless otherwise noted. ADS7841E, P PARAMETER ANALOG INPUT Full-Scale Input Span Absolute Input Range CONDITIONS MIN Positive Input - Negative Input Positive Input Negative Input 0 –0.2 –0.2 TYP Capacitance Leakage Current POWER SUPPLY REQUIREMENTS +VCC Quiescent Current ✻ ✻ ✻ TYP 0.15 0.1 30 70 ±2 ±0.5 ±3 1.0 ±4 1.0 ✻ ✻ ✻ ✻ 10kHz 10kHz 10kHz 50kHz –77 71 78 100 68 72 0.1 ✻ ✻ ✻ ✻ –72 70 76 +VCC DCLK Static 5 13 2.5 0.001 +VCC • 0.7 –0.3 +VCC • 0.8 ✻ ✻ ✻ ✻ 40 3 5.5 +0.8 ✻ ✻ ✻ 280 220 –40 dB dB dB dB ✻ V GΩ µA µA µA ✻ ✻ ✻ V V V V ✻ 3.6 650 ✻ ✻ ✻ 3 1.8 Power Dissipation Clk Cycles Clk Cycles kHz ns ns ps –76 ✻ ✻ 0.4 2.7 Bits Bits LSB(1) LSB LSB LSB LSB LSB µVrms dB ✻ Straight Binary Specified Performance –79 72 80 ✻ ✻ CMOS | IIH | ≤ +5µA | IIL | ≤ +5µA IOH = –250µA IOL = 250µA ±1 ±1 ✻ ✻ ±3 ✻ ✻ 125 at at at at V V V pF µA ✻ 500 30 100 2.5Vp-p 2.5Vp-p 2.5Vp-p 2.5Vp-p ✻ ✻ ✻ ✻ 12 = = = = UNITS ✻ ✻ 3 VIN VIN VIN VIN MAX 12 ±0.8 fSAMPLE = 12.5kHz Power-Down Mode(3), CS = +VCC TEMPERATURE RANGE Specified Performance VREF +VCC +0.2 +0.2 12 fSAMPLE = 12.5kHz DCLK Static DIGITAL INPUT/OUTPUT Logic Family Logic Levels VIH VIL VOH VOL Data Format MIN 12 SAMPLING DYNAMICS Conversion Time Acquisition Time Throughput Rate Multiplexer Settling Time Aperture Delay Aperture Jitter REFERENCE INPUT Range Resistance Input Current MAX 25 ±1 SYSTEM PERFORMANCE Resolution No Missing Codes Integral Linearity Error Differential Linearity Error Offset Error Offset Error Match Gain Error Gain Error Match Noise Power-Supply Rejection DYNAMIC CHARACTERISTICS Total Harmonic Distortion(2) Signal-to-(Noise + Distortion) Spurious-Free Dynamic Range Channel-to-Channel Isolation ADS7841EB, PB +85 ✻ ✻ ✻ ✻ ✻ V µA µA µA mW ✻ °C ✻ Same specifications as ADS7841E, P. NOTE: (1) LSB means Least Significant Bit. With VREF equal to +2.5V, one LSB is 610mV. (2) First five harmonics of the test frequency. (3) Auto power-down mode (PD1 = PD0 = 0) active or SHDN = GND. 4 ADS7841 SBAS084B TYPICAL CHARACTERISTICS: +5V At TA = +25°C, +VCC = +5V, VREF = +5V, fSAMPLE = 200kHz, and fCLK = 16 • fSAMPLE = 3.2MHz, unless otherwise noted. FREQUENCY SPECTRUM (4096 Point FFT; fIN = 10.3kHz, –0.2dB) 0 0 –20 –20 –40 –40 Amplitude (dB) Amplitude (dB) FREQUENCY SPECTRUM (4096 Point FFT; fIN = 1,123Hz, –0.2dB) –60 –80 –60 –80 –100 –100 –120 –120 0 25 50 75 100 0 25 50 75 100 Frequency (kHz) Frequency (kHz) SIGNAL-TO-NOISE RATIO AND SIGNAL-TO(NOISE+DISTORTION) vs INPUT FREQUENCY SPURIOUS-FREE DYNAMIC RANGE AND TOTAL HARMONIC DISTORTION vs INPUT FREQUENCY 74 –85 85 SNR SFDR –80 80 SINAD 71 THD 75 –75 70 –70 70 69 68 10 1 100 10 Input Frequency (kHz) Input Frequency (kHz) EFFECTIVE NUMBER OF BITS vs INPUT FREQUENCY CHANGE IN SIGNAL-TO-(NOISE+DISTORTION) vs TEMPERATURE 12.0 0.6 0.4 11.8 Delta from +25°C (dB) Effective Number of Bits –65 100 65 1 11.6 11.4 11.2 0.2 0.0 –0.2 –0.4 fIN = 10kHz, –0.2dB –0.6 11.0 1 10 Input Frequency (kHz) ADS7841 SBAS084B 100 –40 –20 0 20 40 60 80 100 Temperature (°C) 5 THD (dB) 72 SFDR (dB) SNR and SINAD (dB) 73 TYPICAL CHARACTERISTICS: +2.7V At TA = +25°C, +VCC = +2.7V, VREF = +2.5V, fSAMPLE = 125kHz, and fCLK = 16 • fSAMPLE = 2MHz, unless otherwise noted. FREQUENCY SPECTRUM (4096 Point FFT; fIN = 10.6kHz, –0.2dB) 0 0 –20 –20 –40 –40 Amplitude (dB) –60 –80 –100 –80 –100 –120 –120 0 15.6 31.3 46.9 62.5 0 15.6 31.3 46.9 62.5 Frequency (kHz) Frequency (kHz) SIGNAL-TO-NOISE RATIO AND SIGNAL-TO(NOISE+DISTORTION) vs INPUT FREQUENCY SPURIOUS-FREE DYNAMIC RANGE AND TOTAL HARMONIC DISTORTION vs INPUT FREQUENCY 78 90 SNR –90 85 74 –85 SFDR 80 –80 70 SFDR (dB) SNR and SINAD (dB) –60 66 SINAD 62 75 –75 70 –70 THD 65 –65 60 –60 55 –55 58 54 50 1 10 Input Frequency (kHz) 100 –50 1 10 100 Input Frequency (kHz) EFFECTIVE NUMBER OF BITS vs INPUT FREQUENCY CHANGE IN SIGNAL-TO-(NOISE+DISTORTION) vs TEMPERATURE 12.0 0.4 11.5 0.2 Delta from +25°C (dB) Effective Number of Bits fIN = 10kHz, –0.2dB 11.0 10.5 10.0 –0.2 –0.4 –0.6 9.5 –0.8 9.0 1 10 Input Frequency (kHz) 6 0.0 100 –40 –20 0 20 40 60 80 100 Temperature (˚C) ADS7841 SBAS084B THD (dB) Amplitude (dB) FREQUENCY SPECTRUM (4096 Point FFT; fIN = 1,129Hz, –0.2dB) TYPICAL CHARACTERISTICS: +2.7V (Cont.) At TA = +25°C, +VCC = +2.7V, VREF = +2.5V, fSAMPLE = 125kHz, and fCLK = 16 • fSAMPLE = 2MHz, unless otherwise noted. POWER DOWN SUPPLY CURRENT vs TEMPERATURE 400 140 350 120 Supply Current (nA) Supply Current (µA) SUPPLY CURRENT vs TEMPERATURE 300 250 200 150 100 80 60 40 100 20 –40 –20 0 20 40 60 80 100 –40 –20 0 40 60 80 100 DIFFERENTIAL LINEARITY ERROR vs CODE 1.00 1.00 0.75 0.75 0.50 0.50 DLE (LSB) ILE (LSB) INTEGRAL LINEARITY ERROR vs CODE 0.25 0.00 –0.25 0.25 0.00 –0.25 –0.50 –0.50 –0.75 –0.75 –1.00 000H –1.00 000H FFFH 800H FFFH 800H Output Code Output Code CHANGE IN GAIN vs TEMPERATURE CHANGE IN OFFSET vs TEMPERATURE 0.15 0.6 0.10 0.4 Delta from +25˚C (LSB) Delta from +25˚C (LSB) 20 Temperature (˚C) Temperature (˚C) 0.05 0.00 –0.05 –0.10 0.2 0.0 –0.2 –0.4 –0.15 –0.6 –40 –20 0 20 40 Temperature (˚C) ADS7841 SBAS084B 60 80 100 –40 –20 0 20 40 60 80 100 Temperature (˚C) 7 TYPICAL CHARACTERISTICS: +2.7V (Cont.) At TA = +25°C, +VCC = +2.7V, VREF = +2.5V, fSAMPLE = 125kHz, and fCLK = 16 • fSAMPLE = 2MHz, unless otherwise noted. REFERENCE CURRENT vs TEMPERATURE 18 12 16 Reference Current (µA) Reference Current (µA) REFERENCE CURRENT vs SAMPLE RATE 14 10 8 6 4 14 12 10 8 2 6 0 0 25 50 75 100 –40 125 –20 0 20 40 60 80 100 Temperature (˚C) Sample Rate (kHz) SUPPLY CURRENT vs +VCC MAXIMUM SAMPLE RATE vs +VCC 1M 320 300 Sample Rate (Hz) Supply Current (µA) fSAMPLE = 12.5kHz 280 VREF = +VCC 260 240 220 100k 10k VREF = +VCC 200 1k 180 2 2.5 3 3.5 +VCC (V) 8 4 4.5 5 2 2.5 3 3.5 4 4.5 5 +VCC (V) ADS7841 SBAS084B THEORY OF OPERATION The input current on the analog inputs depends on the conversion rate of the device. During the sample period, the source must charge the internal sampling capacitor (typically 25pF). After the capacitor has been fully charged, there is no further input current. The rate of charge transfer from the analog source to the converter is a function of conversion rate. The ADS7841 is a classic Successive Approximation Register (SAR) ADC. The architecture is based on capacitive redistribution that inherently includes a sample-and-hold function. The converter is fabricated on a 0.6µs CMOS process. The basic operation of the ADS7841 is shown in Figure 1. The device requires an external reference and an external clock. It operates from a single supply of 2.7V to 5.25V. The external reference can be any voltage between 100mV and +VCC. The value of the reference voltage directly sets the input range of the converter. The average reference input current depends on the conversion rate of the ADS7841. A2 A1 A0 CH0 0 0 1 +IN 1 0 1 0 1 0 1 1 0 CH1 CH2 CH3 COM –IN +IN –IN +IN –IN +IN –IN TABLE I. Single-Ended Channel Selection (SGL/DIF HIGH). The analog input to the converter is differential and is provided via a four-channel multiplexer. The input can be provided in reference to a voltage on the COM pin (which is generally ground) or differentially by using two of the four input channels (CH0 - CH3). The particular configuration is selectable via the digital interface. A2 A1 A0 CH0 CH1 0 0 1 +IN –IN CH2 CH3 1 0 1 –IN +IN 0 1 0 +IN –IN 1 1 0 –IN +IN COM TABLE II. Differential Channel Control (SGL/DIF LOW). ANALOG INPUT Figure 2 shows a block diagram of the input multiplexer on the ADS7841. The differential input of the converter is derived from one of the four inputs in reference to the COM pin or two of the four inputs. Table I and Table II show the relationship between the A2, A1, A0, and SGL/DIF control bits and the configuration of the analog multiplexer. The control bits are provided serially via the DIN pin, see the Digital Interface section of this data sheet for more details. A2-A0 (Shown 001B) CH0 CH1 CH2 +IN CH3 Converter –IN When the converter enters the hold mode, the voltage difference between the +IN and –IN inputs (as shown in Figure 2) is captured on the internal capacitor array. The voltage on the –IN input is limited between –0.2V and 1.25V, allowing the input to reject small signals that are common to both the +IN and –IN input. The +IN input has a range of –0.2V to +VCC + 0.2V. COM SGL/DIF (Shown HIGH) FIGURE 2. Simplified Diagram of the Analog Input. +2.7V to +5V ADS7841 1µF + to 10µF 0.1µF Single-ended or differential analog inputs 1 +VCC DCLK 16 2 CH0 CS 15 3 CH1 DIN 14 4 CH2 BUSY 13 5 CH3 DOUT 12 6 COM MODE 11 7 SHDN GND 10 8 VREF +VCC Serial/Conversion Clock Chip Select Serial Data In Serial Data Out 9 0.1µF FIGURE 1. Basic Operation of the ADS7841. ADS7841 SBAS084B 9 REFERENCE INPUT The voltage into the VREF input is not buffered and directly drives the Capacitor Digital-to-Analog Converter (CDAC) portion of the ADS7841. Typically, the input current is 13µA with a 2.5V reference. This value will vary by microamps depending on the result of the conversion. The reference current diminishes directly with both conversion rate and reference voltage. As the current from the reference is drawn on each bit decision, clocking the converter more quickly during a given conversion period will not reduce overall current drain from the reference. The external reference sets the analog input range. The ADS7841 will operate with a reference in the range of 100mV to +VCC. Keep in mind that the analog input is the difference between the +IN input and the –IN input, see Figure 2. For example, in the single-ended mode, a 1.25V reference, and with the COM pin grounded, the selected input channel (CH0 - CH3) will properly digitize a signal in the range of 0V to 1.25V. If the COM pin is connected to 0.5V, the input range on the selected channel is 0.5V to 1.75V. There are several critical items concerning the reference input and its wide voltage range. As the reference voltage is reduced, the analog voltage weight of each digital output code is also reduced. This is often referred to as the LSB (least significant bit) size and is equal to the reference voltage divided by 4096. Any offset or gain error inherent in the ADC will appear to increase, in terms of LSB size, as the reference voltage is reduced. For example, if the offset of a given converter is 2LSBs with a 2.5V reference, then it will typically be 10LSBs with a 0.5V reference. In each case, the actual offset of the device is the same, 1.22mV. DIGITAL INTERFACE Figure 3 shows the typical operation of the ADS7841’s digital interface. This diagram assumes that the source of the digital signals is a microcontroller or digital signal processor with a basic serial interface (note that the digital inputs are over-voltage tolerant up to 5.5V, regardless of +VCC). Each communication between the processor and the converter consists of eight clock cycles. One complete conversion can be accomplished with three serial communications, for a total of 24 clock cycles on the DCLK input. Likewise, the noise or uncertainty of the digitized output will increase with lower LSB size. With a reference voltage of 100mV, the LSB size is 24µV. This level is below the internal noise of the device. As a result, the digital output code will not be stable and vary around a mean value by a number of LSBs. The distribution of output codes will be gaussian and the noise can be reduced by simply averaging consecutive conversion results or applying a digital filter. The first eight clock cycles are used to provide the control byte via the DIN pin. When the converter has enough information about the following conversion to set the input multiplexer appropriately, it enters the acquisition (sample) mode. After three more clock cycles, the control byte is complete and the converter enters the conversion mode. At this point, the input sample-and-hold goes into the hold mode. The next twelve clock cycles accomplish the actual Analog-to-Digital conversion. A thirteenth clock cycle is needed for the last bit of the conversion result. Three more clock cycles are needed to complete the last byte (DOUT will be LOW). These will be ignored by the converter. With a lower reference voltage, care should be taken to provide a clean layout including adequate bypassing, a clean (low-noise, low-ripple) power supply, a low-noise reference, and a low-noise input signal. Because the LSB size is lower, the converter will also be more sensitive to nearby digital signals and electromagnetic interference. CS tACQ DCLK DIN 1 S 8 A2 A1 8 1 1 8 A0 MODE SGL/ DIF PD1 PD0 (START) Idle Acquire Conversion Idle BUSY DOUT 11 (MSB) 10 9 8 7 6 5 4 3 2 1 0 Zero Filled... (LSB) FIGURE 3. Conversion Timing, 24-Clocks per Conversion, 8-Bit Bus Interface. No DCLK delay required with dedicated serial port. 10 ADS7841 SBAS084B Control Byte MODE pin is HIGH, then the MODE bit determines the number of bits for each conversion, either 12 bits (LOW) or 8 bits (HIGH). Also shown in Figure 3 is the placement and order of the control bits within the control byte. Tables III and IV give detailed information about these bits. The first bit, the ‘S’ bit, must always be HIGH and indicates the start of the control byte. The ADS7841 will ignore inputs on the DIN pin until the start bit is detected. The next three bits (A2 - A0) select the active input channel or channels of the input multiplexer (see Tables I and II and Figure 2). Bit 7 (MSB) Bit 6 Bit 5 Bit 4 S A2 A1 A0 Bit 3 Bit 2 MODE SGL/DIF Bit 1 Bit 0 (LSB) PD1 PD0 The SGL/DIF bit controls the multiplexer input mode: either single-ended (HIGH) or differential (LOW). In single-ended mode, the selected input channel is referenced to the COM pin. In differential mode, the two selected inputs provide a differential input. See Tables I and II and Figure 2 for more information. The last two bits (PD1 - PD0) select the powerdown mode, as shown in Table V. If both inputs are HIGH, the device is always powered up. If both inputs are LOW, the device enters a power-down mode between conversions. When a new conversion is initiated, the device will resume normal operation instantly—no delay is needed to allow the device to power up and the very first conversion will be valid. TABLE III. Order of the Control Bits in the Control Byte. DESCRIPTION 16-Clocks per Conversion S Start Bit. Control byte starts with first HIGH bit on DIN. A new control byte can start every 15th clock cycle in 12-bit conversion mode or every 11th clock cycle in 8-bit conversion mode. A2 - A0 Channel Select Bits. Along with the SGL/DIF bit, these bits control the setting of the multiplexer input, see Tables I and II. 3 MODE 12-Bit/8-Bit Conversion Select Bit. If the MODE pin is HIGH, this bit controls the number of bits for the next conversion: 12-bits (LOW) or 8-bits (HIGH). If the MODE pin is LOW, this bit has no function and the conversion is always 12 bits. 2 SGL/DIF Single-Ended/Differential Select Bit. Along with bits A2 - A0, this bit controls the setting of the multiplexer input, see Tables I and II. The control bits for conversion n+1 can be overlapped with conversion ‘n’ to allow for a conversion every 16 clock cycles, as shown in Figure 4. This figure also shows possible serial communication occurring with other serial peripherals between each byte transfer between the processor and the converter. This is possible provided that each conversion completes within 1.6ms of starting. Otherwise, the signal that has been captured on the input sample-and-hold may droop enough to affect the conversion result. In addition, the ADS7841 is fully powered while other serial communications are taking place. PD1 - PD0 Power-Down Mode Select Bits. See Table V for details. BIT NAME 7 6-4 1-0 PD1 PD0 0 0 Power-down between conversions. When each conversion is finished, the converter enters a low power mode. At the start of the next conversion, the device instantly powers up to full power. There is no need for additional delays to assure full operation and the very first conversion is valid. Description 0 1 Reserved for Future Use 1 0 Reserved for Future Use 1 1 No power-down between conversions, device always powered. TABLE IV. Descriptions of the Control Bits within the Control Byte. The MODE bit and the MODE pin work together to determine the number of bits for a given conversion. If the MODE pin is LOW, the converter always performs a 12-bit conversion regardless of the state of the MODE bit. If the TABLE V. Power-Down Selection. CS DCLK 1 DIN 8 1 8 S 1 8 1 S CONTROL BITS CONTROL BITS BUSY DOUT 11 10 9 8 7 6 5 4 3 2 1 0 11 10 9 FIGURE 4. Conversion Timing, 16-Clocks per Conversion, 8-bit Bus Interface. No DCLK delay required with dedicated serial port. ADS7841 SBAS084B 11 Digital Timing microcontrollers and digital signal processors as they are generally not capable of providing 15 clock cycles per serial transfer. However, this method could be used with Field Programmable Gate Arrays (FPGAs) or Application Specific Integrated Circuits (ASICs). Note that this effectively increases the maximum conversion rate of the converter beyond the values given in the specification tables, which assume 16 clock cycles per conversion. Figure 5 and Tables VI and VII provide detailed timing for the digital interface of the ADS7841. 15-Clocks per Conversion Figure 6 provides the fastest way to clock the ADS7841. This method will not work with the serial interface of most SYMBOL DESCRIPTION MIN UNITS SYMBOL DESCRIPTION MIN tACQ Acquisition Time 1.5 TYP MAX µs tACQ Acquisition Time 900 TYP MAX UNITS tDS DIN Valid Prior to DCLK Rising 100 ns tDS DIN Valid Prior to DCLK Rising 50 ns tDH DIN Hold After DCLK HIGH 10 ns tDH DIN Hold After DCLK HIGH 10 ns ns tDO DCLK Falling to DOUT Valid 200 ns tDO DCLK Falling to DOUT Valid 100 ns tDV CS Falling to DOUT Enabled 200 ns tDV CS Falling to DOUT Enabled 70 ns tTR CS Rising to DOUT Disabled 200 ns tTR CS Rising to DOUT Disabled 70 tCSS CS Falling to First DCLK Rising ns tCSS CS Falling to First DCLK Rising tCSH CS Rising to DCLK Ignored 0 ns tCSH CS Rising to DCLK Ignored 0 ns tCH DCLK HIGH 200 ns tCH DCLK HIGH 150 ns tCL DCLK LOW 200 ns tCL DCLK LOW 150 tBD DCLK Falling to BUSY Rising 200 ns tBD DCLK Falling to BUSY Rising tBDV CS Falling to BUSY Enabled 200 ns tBDV CS Falling to BUSY Enabled 70 ns tBTR CS Rising to BUSY Disabled 200 ns tBTR CS Rising to BUSY Disabled 70 ns 100 TABLE VI. Timing Specifications (+VCC = +2.7V to 3.6V, TA = –40°C to +85°C, CLOAD = 50pF). ns 50 ns ns 100 ns TABLE VII. Timing Specifications (+VCC = +4.75V to +5.25V, TA = –40°C to +85°C, CLOAD = 50pF). CS tCSS tCL tCH tBD tBD tCSH tD0 DCLK tDS tDH DIN PD0 tBDV tBTR BUSY tDV tTR DOUT 11 10 FIGURE 5. Detailed Timing Diagram. CS DCLK 15 1 DIN S SGL/ A2 A1 A0 MODE DIF PD1 PD0 1 S 15 SGL/ A2 A1 A0 MODE DIF PD1 PD0 1 S A2 5 4 A1 A0 BUSY DOUT 11 10 9 8 7 6 5 4 3 2 1 0 11 10 9 8 7 6 3 2 FIGURE 6. Maximum Conversion Rate, 15-Clocks per Conversion. 12 ADS7841 SBAS084B Data Format The ADS7841 output data is in straight binary format, as shown in Figure 7. This figure shows the ideal output code for the given input voltage and does not include the effects of offset, gain, or noise. FS = Full-Scale Voltage = VREF 1LSB = VREF/4096 1LSB 11...111 Output Code 11...110 11...101 gible. If the conversion rate is decreased by simply slowing the frequency of the DCLK input, the two modes remain approximately equal. However, if the DCLK frequency is kept at the maximum rate during a conversion, but conversion are simply done less often, then the difference between the two modes is dramatic. Figure 8 shows the difference between reducing the DCLK frequency (“scaling” DCLK to match the conversion rate) or maintaining DCLK at the highest frequency and reducing the number of conversion per second. In the later case, the converter spends an increasing percentage of its time in power-down mode (assuming the auto power-down mode is active). If DCLK is active and CS is LOW while the ADS7841 is in auto power-down mode, the device will continue to dissipate some power in the digital logic. The power can be reduced to a minimum by keeping CS HIGH. The differences in supply current for these two cases are shown in Figure 9. 00...010 00...001 00...000 FS – 1LSB 0V Input Voltage(1) (V) Note 1: Voltage at converter input, after multiplexer: +IN – (–IN). See Figure 2. Operating the ADS7841 in auto power-down mode will result in the lowest power dissipation, and there is no conversion time “penalty” on power-up. The very first conversion will be valid. SHDN can be used to force an immediate power-down. FIGURE 7. Ideal Input Voltages and Output Codes. 1000 8-Bit Conversion Supply Current (µA) The ADS7841 provides an 8-bit conversion mode that can be used when faster throughput is needed and the digital result is not as critical. By switching to the 8-bit mode, a conversion is complete four clock cycles earlier. This could be used in conjunction with serial interfaces that provide a 12-bit transfer or two conversions could be accomplished with three 8-bit transfers. Not only does this shorten each conversion by four bits (25% faster throughput), but each conversion can actually occur at a faster clock rate. This is because the internal settling time of the ADS7841 is not as critical, settling to better than 8 bits is all that is needed. The clock rate can be as much as 50% faster. The faster clock rate and fewer clock cycles combine to provide a 2x increase in conversion rate. fCLK = 16 • fSAMPLE 100 fCLK = 2MHz 10 TA = 25°C +VCC = +2.7V VREF = +2.5V PD1 = PD0 = 0 1 1k 10k 100k 1M fSAMPLE (Hz) FIGURE 8. Supply Current vs Directly Scaling the Frequency of DCLK with Sample Rate or Keeping DCLK at the Maximum Possible Frequency. POWER DISSIPATION When operating at full-speed and 16-clocks per conversion (see Figure 4), the ADS7841 spends most of its time acquiring or converting. There is little time for auto power-down, assuming that this mode is active. Thus, the difference between full power mode and auto power-down is negli- ADS7841 SBAS084B 14 TA = 25°C +VCC = +2.7V VREF = +2.5V fCLK = 16 • fSAMPLE PD1 = PD0 = 0 12 Supply Current (µA) There are three power modes for the ADS7841: full power (PD1 - PD0 = 11B), auto power-down (PD1 - PD0 = 00B), and shutdown (SHDN LOW). The affects of these modes varies depending on how the ADS7841 is being operated. For example, at full conversion rate and 16 clocks per conversion, there is very little difference between full power mode and auto power-down. Likewise, if the device has entered auto power-down, a shutdown (SHDN LOW) will not lower power dissipation. 10 8 6 CS LOW (GND) 4 2 CS HIGH (+VCC) 0 0.09 0.00 1k 10k 100k 1M fSAMPLE (Hz) FIGURE 9. Supply Current vs State of CS. 13 LAYOUT For optimum performance, care should be taken with the physical layout of the ADS7841 circuitry. This is particularly true if the reference voltage is low and/or the conversion rate is high. The basic SAR architecture is sensitive to glitches or sudden changes on the power supply, reference, ground connections, and digital inputs that occur just prior to latching the output of the analog comparator. Thus, during any single conversion for an n-bit SAR converter, there are n “windows” in which large external transient voltages can easily affect the conversion result. Such glitches might originate from switching power supplies, nearby digital logic, and high power devices. The degree of error in the digital output depends on the reference voltage, layout, and the exact timing of the external event. The error can change if the external event changes in time with respect to the DCLK input. With this in mind, power to the ADS7841 should be clean and well bypassed. A 0.1µF ceramic bypass capacitor should be placed as close to the device as possible. In addition, a 1µF to 10µF capacitor and a 5Ω or 10Ω series resistor may be used to low-pass filter a noisy supply. 14 The reference should be similarly bypassed with a 0.1µF capacitor. Again, a series resistor and large capacitor can be used to low-pass filter the reference voltage. If the reference voltage originates from an op amp, make sure that it can drive the bypass capacitor without oscillation (the series resistor can help in this case). The ADS7841 draws very little current from the reference on average, but it does place larger demands on the reference circuitry over short periods of time (on each rising edge of DCLK during a conversion). The ADS7841 architecture offers no inherent rejection of noise or voltage variation in regards to the reference input. This is of particular concern when the reference input is tied to the power supply. Any noise and ripple from the supply will appear directly in the digital results. While high frequency noise can be filtered out as discussed in the previous paragraph, voltage variation due to line frequency (50Hz or 60Hz) can be difficult to remove. The GND pin should be connected to a clean ground point. In many cases, this will be the “analog” ground. Avoid connections which are too near the grounding point of a microcontroller or digital signal processor. If needed, run a ground trace directly from the converter to the power supply entry point. The ideal layout will include an analog ground plane dedicated to the converter and associated analog circuitry. ADS7841 SBAS084B PACKAGE OPTION ADDENDUM www.ti.com 14-Oct-2022 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan (2) Lead finish/ Ball material MSL Peak Temp Op Temp (°C) Device Marking (3) Samples (4/5) (6) ADS7841E ACTIVE SSOP DBQ 16 75 RoHS & Green Call TI Level-2-260C-1 YEAR -40 to 85 ADS7841E/2K5 ACTIVE SSOP DBQ 16 2500 RoHS & Green Call TI Level-2-260C-1 YEAR ADS 7841E ADS7841EB ACTIVE SSOP DBQ 16 75 RoHS & Green Call TI Level-2-260C-1 YEAR ADS 7841E B ADS7841EB/2K5 ACTIVE SSOP DBQ 16 2500 RoHS & Green Call TI Level-2-260C-1 YEAR ADS 7841E B ADS7841EG4 ACTIVE SSOP DBQ 16 75 RoHS & Green Call TI Level-2-260C-1 YEAR ADS7841ES ACTIVE SSOP DBQ 16 75 RoHS & Green Call TI Level-2-260C-1 YEAR -40 to 85 ADS 7841E B ADS 7841E B ADS 7841E S (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
ADS7841P 价格&库存
很抱歉,暂时无法提供与“ADS7841P”相匹配的价格&库存,您可以联系我们找货
