CFM25S SERIES
25 WATT OPEN FRAME
AC-DC MODULES
Features
Universal Input Range 90~264Vac
High Efficiency up to 87%
2”x 1.1” Open Frame Compact Size
Class II
No Load Input Power < 0.1W
Approval IEC/EN/UL 62368-1 Ed 3.0
Approval IEC/EN 60335-1
Approval EN 55032 Class B
and CISPR/FCC Class B
Operating Altitude 5000m
Continuous Short Circuit Protection
Over Voltage Protection
Peak Load (2 Times of Rated Current (note7))
Over Voltage Category OVC II & OVC III
VOLTAGE
RIPPLE&
LINE
LOAD
ACCURACY
NOISE
REGULATION
REGULATION
(Typ.)
NOTE1
NOTE2
NOTE3
NOTE4
NOTE5
4.0 A
±2%
50mV
±1%
±1%
81%
12 V
2.1 A
±1%
120mV
±1%
±1%
84%
CFM25S150
15 V
1.67 A
±1%
150mV
±1%
±1%
85%
CFM25S240
24 V
1.05 A
±1%
240mV
±1%
±1%
86%
CFM25S360
36 V
0.7 A
±1%
360mV
±1%
±1%
87%
CFM25S480
48 V
0.52 A
±1%
480mV
±1%
±1%
87%
MODEL
OUTPUT
OUTPUT
NUMBER
VOLTAGE
CURRENT
CFM25S050
5V
CFM25S120
%EFF.
Note:
1. Voltage accuracy is set at 100% full load.
2. Add a 0.1uF ceramic capacitor and a 10uF E.L. capacitor to output for ripple & noise measurement @20MHz BW.
3. Line regulation is measured from 90Vac to 264Vac with 100% full load.
4. Load regulation is measured from 10% to 100% full load.
5. Typical efficiency at 230 Vac and 100% full load at 25℃.
6. T Version wafer with JST B3B-XH/B4B-XH and mate with JST housing XH series or equivalent.
7. PL (peak load function) lasting time 95% Reduction
Criterion A
Voltage Interruptions
IEC 61000-4-11:2020, >95% Reduction
Criterion B
Application Note Link
CFM25S Series App Notes
CHARACTERISTIC CURVE
Power Derating Curve
CFM250S120(-T),CFM25S150(-T)
CFM25S240(-T),CFM250S360(-T)
CFM25S480(-T), CFM25SXXX-E
CFM250S050(-T)
100%
Rated Load (%)
Rated Load (%)
100%
75%
50%
25%
20LFM(Natural Convection)
75%
50%
25%
0%
0%
-30
-20
-10
40
50
-30
60
-20
-10
40
50
60
70
Ambient Temperature (℃)
Performance Data
CFM25S050 (Eff Vs Io)
CFM25S120 (Eff Vs Io)
90%
Efficiency (%)
Efficiency (%)
85%
80%
115V
85%
115V
80%
230V
75%
10%
20%
30%
40%
50%
60%
70%
80%
230V
75%
10%
90% 100%
20%
30%
Current Load (%)
50%
60%
70%
80%
CFM25S150 (Eff Vs Io)
CFM25S240 (Eff Vs Io)
Efficiency (%)
90%
85%
80%
115V
85%
80%
115V
230V
75%
10%
90% 100%
Current Load (%)
90%
Efficiency (%)
40%
20%
30%
40%
50%
60%
70%
80%
230V
90% 100%
Current Load (%)
www.cincon.com
75%
10%
20%
30%
40%
50%
60%
70%
80%
90% 100%
Current Load (%)
4
REVISION: V18
CFM25S
CFM25S360 (Eff Vs Io)
CFM25S480 (Eff Vs Io)
90%
Efficiency (%)
90%
Efficiency (%)
Series
85%
80%
115V
85%
80%
115V
230V
75%
10%
20%
30%
40%
50%
60%
70%
80%
230V
90% 100%
75%
10%
20%
30%
40%
Current Load (%)
50%
60%
70%
80%
90% 100%
Current Load (%)
MECHANICAL SPECIFICATION
CFM25SXXX-E
BOTTOM VIEW
3
4
0.145[3.69]
0.145[3.69]
1.800[45.72]
2.091[53.10]
5
All Dimensions are in inches[mm]
Tolerance:Inches:X.XXX±0.02
Millimeters:X.XX±0.5
0.400[10.16]
1
1.800[45.72]
www.cincon.com
1.193[30.30]
2
Φ0.039[1.00]
Φ0.071[1.80]
PIN CONNECTION
Pin
Function
1
ACL
2
ACN
3
+Vout
4
-Vout
0.136[3.46]
0.800[20.32]
Φ0.039[1.00]
0.205[5.20]
0.610[15.50]
0.098[2.50]max
0.150[3.80]
0.173[4.40]
0.257 [6.52]
3
2
0.980[24.90]max
1.100[27.94]
4
0.976[24.80]
0.100[2.54]
0.768[19.50]max
0.210[5.34]
2.000[50.80]
0.100[2.54]
1
0.800[20.32]
0.090[2.28]
0.400[10.16]
CFM25SXXX
REVISION: V18
CFM25S
CFM25SXXX PL
Series
CFM25SXXX-E PL
2.000[50.80]
1.193[30.30]
Φ0.039[1.00]
0.800[20.32]
0.768[19.50]max
PIN CONNECTION
2
3
BOTTOM VIEW
1
4
5
Φ0.039[1.00]
6
0.100[2.54]
0.136[3.46]
Φ0.039[1.00]
Φ0.071[1.80]
1.800[45.72]
0.337[8.56]
0.145[3.69]
Pin
1
2
3
4
5
6
Function
ACL
ACN
+Vout
-Vout
BC+(Optional)
BC-(Optional)
0.400[10.16]
3
2
0.136[3.46]
1.100[27.94]
4
0.976[24.80]
1
0.098[2.50]max
0.800[20.32]
0.090[2.28]
0.173[4.40]
6
0.150[3.80]
0.323[8.20]
0.100[2.54]
5
0.980[24.90]max
0.100[2.54]
0.100[2.54]
0.205[5.20]
0.400[10.16]
0.292[7.41]
1.800[45.72]
2.091[53.10]
0.125[3.18]
CFM25SXXX-T
2.776 [70.50]
2.500 [63.50]
3
CN2
1
4
1.100 [27.94]
8[Φ3.50
4-Φ0.13
CN1
1
0.138 [3.50]
0.850 [21.59]
0.138 [3.50]
All Dimensions In Inches[mm]
Tolerance Inches:x.xxx= ± 0.02
Millimeters: x.xx = ± 0.5
0.906 [23.00]max
0.098 [2.50]max
0.125 [3.18]
0.768 [19.50]max
AC Input Connector(CN1):JST B3B-XH-A(LF)(SN)(2N) or equivalent
Pin
1
2
3
Function Mating Housing
Terminal
ACL
JST
JST XHP-3
or equivalent SXH-001T-P0.6N
or equivalent
ACN
DC Output Connector(CN2):JST B4B-XH-A(LF)(SN) or equivalent
Pin
1
2
3
4
-Vout
-Vout
JST XHP-4
or equivalent
+Vout
+Vout
Terminal
JST
SXH-001T-P0.6N
or equivalent
sales@cincon.com.tw
www.cincon.com
6
REVISION: V18
很抱歉,暂时无法提供与“CFM25S150-T”相匹配的价格&库存,您可以联系我们找货
