V27
CHB100 SERIES
66 - 100 WATT WIDE INPUT
DC-DC CONVERTERS
SINGLE OUTPUT
FEATURES
* 66 - 100W Isolated Output
* Efficiency to 89%
* 500KHz Switching Frequency
* 2:1 Input Range
* Regulated Outputs
* Continuous Short Circuit Protection
* Five-Sided Metal Case
* Half-Brick Size Meet Industrial Standard
* UL60950-1 Approval
* Without Tantalum Capacitor Inside
(Except 3.3&5Vout)
MODEL
NUMBER
INPUT
OUTPUT OUTPUT CURRENT
VOLTAGE VOLTAGE
MIN.
MAX.
INPUT CURRENT
% CAPACITOR
EFF. LOAD MAX.
NO LOAD FULL LOAD
CHB100-24S33
18-36 VDC
3.3 VDC
0 mA
20 A
50 mA
3313 mA
83
20000uF
CHB100-24S05
18-36 VDC
5 VDC
0 mA
20 A
50 mA
4960 mA
84
20000uF
CHB100-24S12
18-36 VDC
12 VDC
0 mA
8.3 A
50 mA
4770 mA
87
8300uF
CHB100-24S15
18-36 VDC
15 VDC
0 mA
6.7 A
50 mA
4758 mA
88
6700uF
CHB100-24S24
18-36 VDC
24 VDC
0 mA
4.17 A
50 mA
4793 mA
87
4170uF
CHB100-48S33
36-75 VDC
3.3 VDC
0 mA
20 A
50 mA
1676 mA
82
20000uF
CHB100-48S05
36-75 VDC
5 VDC
0 mA
20 A
50 mA
2422 mA
86
20000uF
CHB100-48S12
36-75 VDC
12 VDC
0 mA
8.3 A
50 mA
2331 mA
89
8300uF
CHB100-48S15
36-75 VDC
15 VDC
0 mA
6.7 A
50 mA
2352 mA
89
6700uF
CHB100-48S24
36-75 VDC
24 VDC
0 mA
4.17 A
50 mA
2369 mA
88
4170uF
NOTE: 1. Nominal Input Voltage 24 or 48VDC
1
V27
SPECIFICATIONS
All Specifications Typical At Nominal Line, Full Load, and 25℃ Unless Otherwise Noted
INPUT SPECIFICATIONS:
GENRAL SPECIFICATIONS:
Input Voltage Range....……………........................ 24V .................. 18-36V
48V ................. 36-75V
Input Surge Voltage (100ms max.) ……...… 24V …... 50Vdc max.
48V .…... 100Vdc max.
Efficiency .................….............................................…....... See Table
Isolation Voltage …........ Input/Output, Input/Case, Output/Case .....….. 1500VDC min.
Isolation Resistance .............................……………….............. 107 ohm min.
Isolation Capacitance ……………….…..……………………..… 1000pF typ.
Switching Frequency .....................................……................. 500KHz typ.
Under Voltage Lockout:
24Vin …………….. Power Up ….... 17V, Power Down …..… 16V
48Vin ..……..….….. Power Up ….… 34V, Power Down …….. 32.5V
Positive Logic Remote On/Off (note3&4)
Input Filter …………………………………………………………... Pi Type
OUTPUT SPECIFICATIONS:
Operating Case Temperature ………………….....…............ -40℃ to +100℃
Storage Temperature …………….............…................. -40℃ to +105℃
Thermal Shutdown Case Temperature ..………….…………..……. 100℃ typ.
Humidity .................................................... 95% RH max. Non Condensing
Voltage Accuracy ..........................................……….......... ±1.0% max.
Transient Response:25% Step Load Change ………………
很抱歉,暂时无法提供与“CHB100-24S05”相匹配的价格&库存,您可以联系我们找货
