EC6AW-48S05
EC6AW-48S05
    CINCON
    DIP9 模块
    隔离模块 直流转换器 1 输出 5V 1.6A 18V - 75V 输入
EC6AW-48S05 数据手册
EC6AW SERIES 8 WATT 4:1 INPUT ISOLATED DC-DC CONVERTER Features  Efficiency Up to 86%  100KHz Switching Frequency  Regulated Outputs  Remote On/Off  Fully Protected (OTP/OCP/OVP/UVLO)  1500Vdc I/O Isolation  Operating Ambient Temperature -40 to +85℃  DIP: 1.25”x0.80”x0.40”, SMD: 1.25”x0.80”x0.43” Meet Industrial Standard  EN 50155 Compliant with External Circuits  Shock & Vibration EN 50155 (EN 61373) Compliant  Fire & Smoke EN 45545-2 Compliant  3000m Operating Altitude  Safety Meets IEC/EN/UL 62368-1  Without Tantalum Capacitors Inside MODEL INPUT OUTPUT OUTPUT CURRENT INPUT CURRENT CAPACITOR % EFF. NUMBER VOLTAGE VOLTAGE MIN. MAX. NO LOAD FULL LOAD LOAD MAX. EC6AW-24S33 9-36 VDC 3.3 VDC 0 mA 2000 mA 10 mA 344 mA 80 2000uF EC6AW-24S05 9-36 VDC 5 VDC 0 mA 1600 mA 10 mA 406 mA 82 1600uF EC6AW-24S12 9-36 VDC 12 VDC 0 mA 666 mA 10 mA 392 mA 85 666uF EC6AW-24S15 9-36 VDC 15 VDC 0 mA 530 mA 10 mA 390 mA 85 530uF EC6AW-24D05 9-36 VDC ±5 VDC 0 mA ±800mA 10 mA 406 mA 82 800uF EC6AW-24D12 9-36 VDC ±12 VDC 0 mA ±333mA 10 mA 392 mA 85 333uF EC6AW-24D15 9-36 VDC ±15 VDC 0 mA ±265mA 10 mA 390 mA 85 265uF EC6AW-48S33 18-75 VDC 3.3 VDC 0 mA 2000 mA 5 mA 172 mA 80 2000uF EC6AW-48S05 18-75 VDC 5 VDC 0 mA 1600 mA 5 mA 201 mA 83 1600uF EC6AW-48S12 18-75 VDC 12 VDC 0 mA 666 mA 5 mA 194 mA 86 666uF EC6AW-48S15 18-75 VDC 15 VDC 0 mA 530 mA 5 mA 193 mA 86 530uF EC6AW-48D05 18-75 VDC ±5 VDC 0 mA ±800mA 5 mA 201 mA 83 800uF EC6AW-48D12 18-75 VDC ±12 VDC 0 mA ±333mA 5 mA 194 mA 86 333uF EC6AW-48D15 18-75 VDC ±15 VDC 0 mA ±265mA 5 mA 193 mA 86 265uF NOTE: 1. Nominal Input Voltage 24 or 48 VDC www.cincon.com 1 REVISION: V17 EC6AW Series PART NUMBER Series EC6AW- Nominal Input Voltage II Number of Outputs Nominal Output Voltage Remote On/Off Logic Packages O XX L -Y 33:3.3VDC 05:5VDC EC6AW 24:24 VDC 48:48 VDC 12:12VDC S:Single D:Dual 15:15VDC None:Positive N:Negative None: DIP S: SMD 05:±5VDC 12:±12VDC 15:±15VDC Part Number Example: EC6AW-24S12N: 1.25”x0.8”, 8W, 4:1 9-36Vdc Input, Single 12Vdc Output, Negative Logic www.cincon.com 2 REVISION: V17 EC6AW Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, full load at 25℃ unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Input Voltage Continuous Input Surge Voltage 100ms max. Device Min. Typ. Max. 24Vin 9 24 36 48Vin 18 48 75 24Vin 50 48Vin 100 Operating Ambient Temperature With derating, above 71℃ All Operating Case Temperature At the center part of case plate All Storage Temperature -40 Units Vdc Vdc 85 ℃ 100 ℃ 125 ℃ Units All -55 Device Min. Typ. Max. 24Vin 9 24 36 48Vin 18 48 75 INPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Operating Input Voltage Vdc Input Under Voltage Lockout Turn-On Voltage Threshold 100% Load Turn-Off Voltage Threshold 100% Load Lockout Hysteresis Voltage 100% Load Maximum Input Current No-Load Input Current 24Vin 8 8.5 8.8 48Vin 16 16.5 17.5 24Vin 7.7 8 8.3 48Vin 15.5 16 17 24Vin 0.5 48Vin 1 Vin=9V, Full load 24Vin 1.2 Vin=18V, Full load 48Vin 0.6 Vin=Nominal, Io=0A Pi filter All Inrush Current (I2t) As per ETS300 132-2 All Input Reflected Ripple Current P-P thru 12uH inductor, 5Hz to 20MHz All Vdc Vdc A See Model Number Table Input Filter Vdc mA 0.1 30 A2 s mA OUTPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Voltage Set Point Accuracy Vin=Nominal, full load, Tc=25℃ All Output Voltage Balance Vin=Nominal, full load, Tc=25℃ Dual Min. Typ. Max. Units -1.5 +1.5 % -1.0 +1.0 % ±0.5 % Output Voltage Regulation Line Regulation Vin=High line to low line, full load Load Regulation Full load to no load Cross Regulation Load cross variation 25%/100% Temperature Coefficient Tc=-40℃ to 85℃ All Single ±0.5 % Dual ±1.0 % Dual ±5.0 % All ±0.03 %/℃ 75 mV 100 mV Output Voltage Ripple and Noise (5Hz to 20MHz bandwidth) 3.3Vo Peak-to-Peak Full Load,20MHz bandwidth 0.1uF Ceramic capacitor 5Vo 12Vo 15Vo Output Current Range Vin=Nominal Over Current Protection Auto recovery See Model Number Table All Short Circuit Protection External Load Capacitance www.cincon.com All Full load (resistive) 120 % Continuous, Auto Recovery See Model Number Table 3 A uF REVISION: V17 EC6AW PARAMETER Output Over Voltage Protection NOTES and CONDITIONS Zener or TVS Clamp Device Min. Typ. 3.3Vo 3.9 5Vo 6.2 12Vo 15 15Vo 18 ±5Vo ±6.2 ±12Vo ±15 ±15Vo ±18 Series Max. Units V EFFICIENCY PARAMETER NOTES and CONDITIONS 100% Load Vin=Nominal, full load, Tc=25℃ Device Min. Typ. Max. See Model Number Table Units % DYNAMIC CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Typ. Max. Units Output Voltage Current Transient Error Band Recovery Time Turn-On Delay and Rise Time Turn-On Delay Time, From On/Off Control Turn-On Delay Time, From Input Output Voltage Rise Time 75% to 100% of Io_max. step load change di/dt=0.1A/us (within 1% Vout nominal) Full load (Constant resistive load) Von/off to 10%Vo_set, Remote on All All ±5 % 500 us 2 ms Vin_min. to 10%Vo_set, Power up All 2 ms 10%Vo_set to 90%Vo_set All 1.5 ms ISOLATION CHARACTERISTICS PARAMETER Isolation Voltage (100% factory Hi-Pot tested @2sec.) Isolation Resistance Isolation Capacitance NOTES and CONDITIONS Device 1 Minute; input to output All Input to output All Input to output All Min. Typ. Max. Units 1500 Vdc 1000 MΩ 1000 pF FEATURE CHARACTERISTICS PARAMETER Switching Frequency NOTES and CONDITIONS Vin=Nominal, Io=Io. max. Device All Vin=Low line, Io=Io. max. Min. Typ. Max. 200 Units KHz 100 On/Off Control, Positive Remote On/Off Logic, Refer to -Vin Pin Logic Low (Module Off) Von/off at Ion/off=1.0mA All Logic High (Module On) Von/off at Ion/off=0.1uA, Pin open=on All 0 3.5 or Open Circuit 1.2 V 36 V 36 V 1.2 V 1 mA 30 uA 4 10 mA Typ. Max. Units On/Off Control, Negative Remote On/Off Logic, Refer to -Vin Pin Logic High (Module Off) Logic Low (Module On) On/Off Current (for Both Remote On/Off Logic) Leakage Current (for Both Remote On/Off Logic) Off Converter Input Current Von/off at Ion/off=0.1uA, Pin open=off All Von/off at Ion/off=1.0mA All Ion/off at Von/off=0V All Logic high, Von/off=15V All Shutdown input idle current All 3.5 or Open Circuit 0 0.3 GENERAL SPECIFICATIONS PARAMETER NOTES and CONDITIONS MTBF Io=100% of Io_max.; MIL-HDBK - 217F_Notice 1, GB, 25℃ Weight www.cincon.com 4 Device Min. Single 1.5 Dual 1.3 M hours All 18.4 grams REVISION: V17 EC6AW Series GENERAL SPECIFICATIONS Case Material Black Coated Copper Base plate Material Non-Conductive Base Potting Material Shock/Vibration UL 94V-0 Base: Copper Plating: Nickel with Matte Tin MIL-STD-810F/EN61373 Compliant Humidity 95% RH max. Non Condensing Altitude 3000m Operating Altitude, 12000m Transport Altitude Thermal Shock MIL-STD-810F Fire & Smoke EN 45545-2 Compliant Pin Material EMC SPECIFICATIONS (External components required, please refer to application note.) EMI Meets EN 55032 & EN 50155 Compliant (with external filter) ESD EN 61000-4-2 Level 3: Air ±8kV, Contact ±6kV Perf. Criteria A Class A Radiated Immunity EN 61000-4-3 EN 61000-4-4 Perf. Criteria A Perf. Criteria A Conducted Immunity EN 61000-4-6 Level 3: 80~1000MHz, 20V/m Level 3: On power input port, ±2kV, external components required (EN 50155) Level 3: Line to earth, ±2kV, Line to line, ±1kV (EN 50155), external components required Level 3: 0.15~80MHz, 10V Interruptions of Voltage Supply EN 50155 Class S3: 20ms interruptions Supply Change Over EN 50155 Class C2: During a supply break of 30 ms Fast Transient Surge EN 61000-4-5 Application Note Link Perf. Criteria A Perf. Criteria A Perf. Criteria A Perf. Criteria A EC6AW Series App Notes Packaging Information Link Packaging Information Immunity to Environmental Conditions Phenomenon EN50155; 2017 Reference Clause(s) Reference Standard Low Temperature Start-up test 13.4.4 EN 60068-2-1 Dry Heat Test 13.4.5 EN 60068-2-2 Low Temperature Storage Test 13.4.6 EN 60068-2-1 Cyclic Damp Heat Test 13.4.7 EN 60068-2-30 Random Vibration Test 13.4.11 EN 61373 Simulated Long Life Test at Increased Random Vibration Levels 13.4.11 EN 61373 Shock Test 13.4.11 EN 61373 www.cincon.com 5 Test Conditions Class OT4 Temperature: -40℃ Duration: 2 hrs Class OT4 & Cycle B Temperature: 70℃ Duration: 6 hrs Extended temperature: 85℃ Extended Duration: 10min Temperature: -40℃ Duration: 16 hrs Temperature: 25℃ - 55℃ Humidity: 90% RH Duration: 48 hrs Temperature: 25℃ +/- 10℃ Humidity: 50% +/-25% RH Frequency range: 5 ~ 150 Hz Vertical: 0.98 ⁄ Transverse: 0.44 ⁄ Longitudinal: 0.69 ⁄ Duration: 10 min / axis Temperature: 25℃±10℃ Humidity: 50% ±25% RH Frequency range: 5 ~ 150 Hz Vertical: 5.72 ⁄ Transverse: 2.5 ⁄ Longitudinal: 3.96 ⁄ Duration: 5 hrs / axis Temperature: 25℃±10℃ Humidity: 50% ±25% RH Frequency range: 5 ~ 150 Hz ±Vertical: 30 ⁄ ±-Transverse: 30 ⁄ ±Longitudinal: 50 ⁄ Duration: 30ms x18 (Each axis 3 shocks) Result Pass Pass Pass Pass Pass Pass Pass REVISION: V17 EC6AW Series EN45545-2 Fire & Smoke Test Conditions Item Standard EN 45545-2: 2013 EN ISO 4589-2: 2006 EN 45545-2: 2013 EN ISO 5659-2: 2013 EN 45545-2: 2013 NF X70-100: 2006 EN 45545-2: 2013 EN ISO 4589-2: 2006 EN 45545-2: 2013 EN ISO 5659-2: 2013 EN 45545-2: 2013 NF X70-100: 2006 EN45545-2: 2013 EN ISO 4589-2 EN 45545-2:2013 EN 60695-2-11:2001 EN 45545-2: 2013 EN 60695-11-10: 2013 Oxygen Index Test R22 Smoke Density Test Smoke Toxicity Test Oxygen Index Test R23 Smoke Density Test Smoke Toxicity Test R24 Oxygen Index Test R25 Glow - Wire Test R26 Vertical Flame Test Hazard Level HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 CHARACTERISTIC CURVE Power Derating Curve EC6AW Derating Curve (Vin=Nominal) 120% Output Power (%) 100% 71 -40 80% 60% 40% Natural Convection 20% 0% -40 -20 0 20 40 60 80 100 Ambient Temperature (℃) www.cincon.com 6 REVISION: V17 EC6AW Series Performance Data EC6AW-24S33 Eff Vs Io @25 Deg. C EC6AW-24S33 Pd Vs Po @25 Deg. C 4 Power Dissipation (W) 100% Efficiency (%) 90% 80% 70% 60% 50% 9V 40% 24V 30% 36V 20% 10% 9V 24V 3 36V 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC6AW-24S05 Eff Vs Io @25 Deg. C EC6AW-24S05 Pd Vs Po @25 Deg. C 100% Power Dissipation (W) 4 Efficiency (%) 90% 80% 70% 60% 50% 9V 40% 24V 30% 36V 20% 10% 9V 24V 3 36V 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC6AW-24S12 Eff Vs Io @25 Deg. C EC6AW-24S12 Pd Vs Po @25 Deg. C 4 Power Dissipation (W) 100% Efficiency (%) 90% 80% 70% 60% 50% 9V 40% 24V 30% 36V 20% 10% 9V 24V 3 36V 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC6AW-24S15 Eff Vs Io @25 Deg. C EC6AW-24S15 Pd Vs Po @25 Deg. C 4 Power Dissipation (W) 100% Efficiency (%) 90% 80% 70% 60% 50% 9V 40% 24V 30% 36V 20% 10% 9V 24V 3 36V 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% Current Load (%) www.cincon.com 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 7 REVISION: V17 EC6AW EC6AW-24D05 Eff Vs Io @25 Deg. C EC6AW-24D05 Pd Vs Po @25 Deg. C 4 Power Dissipation (W) 100% Efficiency (%) 90% 80% 70% 60% 50% 9V 40% 24V 30% 20% 10% 36V 9V 24V 3 36V 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC6AW-24D12 Eff Vs Io @25 Deg. C EC6AW-24D12 Pd Vs Po @25 Deg. C 4 Power Dissipation (W) 100% Efficiency (%) 90% 80% 70% 60% 50% 9V 40% 24V 30% 36V 20% 10% 9V 24V 3 36V 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC6AW-24D15 Eff Vs Io @25 Deg. C EC6AW-24D15 Pd Vs Po @25 Deg. C 4 Power Dissipation (W) 100% Efficiency (%) 90% 80% 70% 60% 50% 9V 40% 24V 30% 36V 20% 10% 9V 24V 3 36V 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC6AW-48S33 Eff Vs Io @25 Deg. C EC6AW-48S33 Pd Vs Po @25 Deg. C 4 Power Dissipation (W) 100% Efficiency (%) 90% 80% 70% 60% 50% 18V 40% 48V 30% 75V 20% 10% Series 18V 48V 3 75V 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% Current Load (%) www.cincon.com 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 8 REVISION: V17 EC6AW EC6AW-48S05 Eff Vs Io @25 Deg. C EC6AW-48S05 Pd Vs Po @25 Deg. C 4 Power Dissipation (W) 100% Efficiency (%) 90% 80% 70% 60% 50% 18V 40% 48V 30% 75V 20% 10% 18V 48V 3 75V 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC6AW-48S12 Eff Vs Io @25 Deg. C EC6AW-48S12 Pd Vs Po @25 Deg. C 4 Power Dissipation (W) 100% Efficiency (%) 90% 80% 70% 60% 50% 18V 40% 48V 30% 75V 20% 10% 18V 48V 3 75V 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC6AW-48S15 Eff Vs Io @25 Deg. C EC6AW-48S15 Pd Vs Po @25 Deg. C 4 Power Dissipation (W) 100% Efficiency (%) 90% 80% 70% 60% 50% 18V 40% 48V 30% 75V 20% 10% 18V 48V 3 75V 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC6AW-48D05 Eff Vs Io @25 Deg. C EC6AW-48D05 Pd Vs Po @25 Deg. C 4 Power Dissipation (W) 100% Efficiency (%) 90% 80% 70% 60% 50% 18V 40% 48V 30% 20% 10% Series 75V 18V 48V 3 75V 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% Current Load (%) www.cincon.com 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 9 REVISION: V17 EC6AW EC6AW-48D12 Eff Vs Io @25 Deg. C EC6AW-48D12 Pd Vs Po @25 Deg. C 4 Power Dissipation (W) 100% Efficiency (%) 90% 80% 70% 60% 50% 18V 40% 48V 30% 75V 20% 10% 18V 48V 3 75V 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC6AW-48D15 Eff Vs Io @25 Deg. C EC6AW-48D15 Pd Vs Po @25 Deg. C 4 Power Dissipation (W) 100% Efficiency (%) 90% 80% 70% 60% 50% 18V 40% 48V 30% 75V 20% 10% Series 18V 48V 3 75V 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) MECHANICAL SPECIFICATION NOTE:Pin Size is 0.02±0.002 Inch (0.5±0.05 mm)DIA All Dimensions In Inches (mm) Tolerances Inches: X.XX= ±0.02 , X.XXX= ±0.010 Millimeters: X.X= ±0.5 , X.XX=±0.25 PIN CONNECTION SMD Packages DIP Packages SEE NOTE Pin 1 2,3 BOTTOM VIEW Single Output -V Input TOP 4,5 NP NC VIEW 9 NP NC 10 NP 11 12 13 14 15 16 20,21,24 22,23 Dual Output DIP SMD DIP SMD Remote Remote Remote Remote on/off on/off on/off on/off NC -V Input NP NC Common NP NC -V Output NC NP NC NP NC NP +V Output NP NC +V Output NP -V Output -V Output NP NC +V Input +V Output NP NC Common NP NC +V Input * NC-NO CONNECTION WITH PIN * NP-NO PIN E-mail: sales@cincon.com.tw Web: www.cincon.com 10 REVISION: V17
EC6AW-48S05 价格&库存
很抱歉,暂时无法提供与“EC6AW-48S05”相匹配的价格&库存,您可以联系我们找货
